Question about tire temperatures | FerrariChat
Discussion in 'Technical Q&A' started by DonC, Apr 12, 2011.
  1. DonC
    DonC Rookie
    Feb 11, 2005
    45
    I just returned from a Chicago - Boulder - Chicago round trip in my 07 612. In four days.
    My question is this: my car has both the tire pressure and tire temperature system. I noticed on the return that while the tire pressures were all about the same, the right rear tire consistently ran 20 degrees warmer than the right left. The fronts were the same left and right. There was a strong tailwind left to right, but that is the only reasons I can think of. A visual inspection revealed nothing abnormal with the tire. High tire temperature in the right rear ran about 120 degrees.
    Any thoughts or similar experiences?
  2. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,673
    Pittsburgh, PA
    Matt F
    Nice grand touring trip, Don!
    My guess would be that, at a constant highway speed, the right rear is getting most of the driving power. (The LSD doesn't come into play.) But just a guess.
  3. DonC
    DonC Rookie
    Feb 11, 2005
    45
    Interesting, and makes some sense.
    And, yes, it was a terrific trip. One day there, one day back, and two days in the mountains driving around. And the sound echoing off the canyon walls in the mountains was epic.
  4. 308steve
    308steve Formula Junior
    Sep 5, 2010
    304
    The crown of the road can have an effect on individual tire temperatures and maybe on a longer trip you would see a higher temp on the outside drive tire. Just a thought.
  5. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    All things being equal... Crown of the road, alignment or corner weighting. Did you have something heavy in that corner of the car??
    Rick
  6. DonC
    DonC Rookie
    Feb 11, 2005
    45
    Nothing different about the corner weight. And, strangely, as I approached Chicago and the outside temp came down (as did my average speed) the temps went back to parity. Maybe just the car giving me something to keep my mind occupied during a 14 hour drive??
  7. Cribbj
    Cribbj Formula 3
    Perhaps that wheel/tire has just a bit more runout or imbalance than the left rear? Or possibly that wheel bearing has a bit more play in it?
    It would be interesting to put both wheels on a Hunter GSP9700 and see if there's any difference when road force is applied.
