Question about water temp switch and oil temp switch | FerrariChat
Discussion in 'Boxers/TR/M' started by alex_kay, Jun 9, 2024.
  1. alex_kay
    alex_kay Karting
    Apr 7, 2024
    56
    Central Switzerland
    Alex
    Hi,
    I was wondering about the optimal temp switch for water and oil.
    1. Radiator (water) temp switch:
    The original has the parts number 101507 which seems to have been superseded by 168008. The 168008 however sends a signal for the fans to come on at 85 or 86 degrees celsius (185 Fahrenheit) and shuts them off at 75 or 76 degrees C (167 F).
    I read somewhere that in the Testarossa the fans normally only come on at around 90 C (195 F). That would be a bit higher than the 85 C (185 F).
    What is the optimal temp for the water fans to kick in? I think my water fans actually kick in slightly above 90 C (195 F).
    2. Oil temp switch:
    The parts number I guess is 123277.
    I have no idea when that one kicks the oil fans on. Anyone know that?
    @turbo-joe once posted something about the oil temp switch here: https://www.ferrarichat.com/forum/posts/141881570/
    "switch closes at 102 °C, so the fans are running
    switch opens at 93 ° C, fans will stop"
    I have read here https://www.ferrarichat.com/forum/posts/136095492/ that the Intermotor 50172 replaces the 123277. But the temps are completely different:
    Intermotor 50172
    closes - 87 degrees C
    opens - 82 degrees C
    M14 x 1.5 Thread
    Would that one from Intermotor still work?
    Just for reference: In my Porsche 997.1 Turbo the water temp usually sticks almost glued to 80 C (176 F) and the oil temp somewhere between 80-95 C (176-203F).
    Best, alex
  2. Steve Magnusson
    26,624
    #2 Steve Magnusson, Jun 9, 2024
    IMO, you are worrying needlessly about this ;). You can't compare those temperature values so directly because the thermoswitch controlling the relays for the water fans is mounted in the bottom of the LH radiator (after the coolant has been cooled) while the thermister controlling water temp gauge in the dash is mounted in the pipe where the hottest coolant exits from the top of the cylinder heads. Additionally, the accuracy of all of these components is only plus or minus several degrees C. About 90 deg C on the dash water temp gauge (or even a little above) for the cooling fans to come "on" is A-OK (and the TR cooling system is so over-designed that, unless it's a very hot day, the water temp on the gauge should drop a little after the water fans come "on").
    Also, be aware that when you turn the exterior lights "on", it's normal for the temperature and pressure gauge needles will all move up a needlewidth or two -- so don't let that concern you when driving at night.
    Rifledriver, alex_kay and turbo-joe like this.
  3. alex_kay
    alex_kay Karting
    Apr 7, 2024
    56
    Central Switzerland
    Alex
    Thank you. That puts the whole thing in perspective :)
    Then there is only the question left regarding the Intermotor 50172 switch. That one would seem to come on at definitely lower temps than the original Ferrari switch, or am I wrong?
    For your info: I am always trying to quote every possible parts number. Maybe it'll help someone in the future because it is easy to find then in the search and via google
  4. lagunacc
    lagunacc F1 Rookie
    4,151
    This aftermarket one sold for the TR is also 87/82 C
    https://awitalian.com/product/oil-temp-switch-123277.html/
    The one on the fparts uk site is a honeywell 2455r type
    alex_kay likes this.
  5. Rifledriver
    36,866
    As far as the oil goes its pretty unusual for the oil cooler fan to come on at all. Ferrari decided not to even install one on most versions on the 512TR and it was a good decision. Considering modern oils can tolerate temperatures in excess of 300 F the fan is just excess weight.
    alex_kay and Steve Magnusson like this.
  6. Steve Magnusson
    26,624
    #6 Steve Magnusson, Jun 10, 2024
    Completely agree that those switching temps for the Intermotor 50172 seem far too low -- and agree with Brian that the usual complaint for the TR oil temperature is "why is my oil temperature always so low?". The only information I have about 123277 is a note that I wrote in my TR SPC from the same turbo-joe post that you've already quoted, and his temperature values seem far more reasonable to me.
    Totally agree! If you do a search using the F part number of "123277" you should get most of the available prior threads on the subject.
  7. alex_kay
    alex_kay Karting
    Apr 7, 2024
    56
    Central Switzerland
    Alex
    Thank you for all the replies. I guess living in Switzerland makes a big difference when it comes to oil temperature. We have three states of traffic here:
    1. Driving slowly on a motorway with very restrictive speed limits (120kph) -> oil stays too cool.
    2. We are stuck in traffic (too many people, too little space because of the mountains) -> oil gets warm/hot very quickly.
    3. Sporting the Testarossa up a windy mountain road -> oil gets hot very quickly :)
  8. Rifledriver
    36,866
    101507 was originally for a long list of cars built over many years. 168008 was originally designated for the F40.
    I just pulled and read both factory service manuals and the on/off temperatures are exactly the same.
    Your source of information is incorrect .
    22mm temperature switches are very ubiquitous and I suspect many suppliers are just selling generic parts.
  9. lagunacc
    lagunacc F1 Rookie
    4,151
    What's quickly and in what ambient temp?
    Generally it takes forever to warm up.
  10. Rifledriver
    36,866
    Even on a race track I have never seen 300 degrees in a Testarossa. And with 100+ MPH wind going through the cooler all a fan is going to do is restrict air flow.
  11. ago car nut
    ago car nut F1 Veteran
    5,477
    Madison Ohio
    David A.
    Might be a little bit of worrying to much.
    Rifledriver and turbo-joe like this.
  12. lagunacc
    lagunacc F1 Rookie
    4,151
    One with partially blocked oil passages would heat up faster wouldn't it?
  13. Steve Magnusson
    26,624
    #13 Steve Magnusson, Jun 10, 2024
    Your being at a relatively high elevation (low density air) won't help the situation, but still surprised that you are having any issue. Are you sure that both water fans are working well? When the oil gets hot, does the water also get abnormally hot? A test you can do is remove relay I (for the oil fans) and connect a jumper wire from the female metal terminal 30 in the relay socket to the female metal terminal 87 in the relay socket like this:
    The oil fans should run even when the key is "off". You can do the same test at relays H & L for the water fans. Won't test the thermoswitches operating those relays, but will test everything else (fuses, wiring, connections, motors). Just putting your hand in front of each rear wheel should give you an good indication of the airflow (e.g., do both water fans have about the same airflow discharge, or not).
  14. Rifledriver
    36,866
    As soon as I ever hear of it happening I'll let you know. TR oil cooler is far bigger than needed. BB had no oil cooler and the race cars, the BBLMs had a smaller cooler than TR. F40 made more power and had a smaller cooler and we had trouble getting those up to temperature. The only complaint ever heard is it runs too cool. On 40 degree days the only time the needle moves is if I let it idle for a long time. As soon as I get moving it crashes back to the bottom.
  15. lagunacc
    lagunacc F1 Rookie
    4,151
    Was referring to engine oil passages.
  16. Rifledriver
    36,866
    #16 Rifledriver, Jun 10, 2024
    When that happens heat isn't the problem. Scrap metal in the oil pan and a seized engine is. You do not clog a single passage without it costing you a motor within a minute or two tops.
    If you deprive anything in the engine of enough lubrication it results in a measurable heat increase the engine is being destroyed. Biggest cooler in the world will not change the outcome.
  17. lagunacc
    lagunacc F1 Rookie
    4,151
    But you could have a partial obstruction that goes on for a while before the engine is destroyed.
    A bit of sealant or filter piece that moves along until it blocks enough of the flow, most likely to the heads.
    Hypothetical, not saying it applies to his car.
  18. Rifledriver
    36,866
    #18 Rifledriver, Jun 11, 2024
    Hypothetically Elvis was abducted by aliens.
    WTF does your imagination have to do with oil temperature?
    And why do you insist on wasting time discussing it?
    The passage feeding the heads in less than 1mm. When it gets clogged the 1st and only symptom is the engine is now running on 6 cylinders.
  19. lagunacc
    lagunacc F1 Rookie
    4,151
    That's the final stage. Before that happens you could have a long period of partial obstruction.
  20. Rifledriver
    36,866
    You don't know enough to know how stupid your statements are
  21. lagunacc
    lagunacc F1 Rookie
    4,151
    Maybe not. Yes, when it gets to the heads, it's all over, but before that, there can be partial blockage.
    How long do you think it would take for bits of excess sealant between the engine and the transmission (a la that Boxer that's being restored - you saw the pics about a month or two ago) to come off and enter the oil passages.
    And once they come loose what's the route they would take?
    https://www.ferrarichat.com/forum/threads/testarossa-camshaft-seized.44299/
  22. alex_kay
    alex_kay Karting
    Apr 7, 2024
    56
    Central Switzerland
    Alex
  23. boxertt
    boxertt Rookie
    11
    Switzerland
    Stefan
    Hi Alex,
    What is the difference ? Displayed temperature is lower, or ?
    Cheers,
    Stefan.
  24. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,432
    romano schwabel
    difference between what?
  25. boxertt
    boxertt Rookie
    11
    Switzerland
    Stefan
    Hi Romano,
    I meant, what is the difference after replacing the old thermoswitch with the new thermoswitch. As far as I understand, Alex bought the new thermoswitch because he thought it would help with his oil temperatures.
    Cheers,
    Stefan.
