Question: Alternator pulley/nut removal? | FerrariChat
Discussion in '308/328' started by christopher, Jan 16, 2014.
  1. christopher
    christopher Formula 3
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    #1 christopher, Jan 16, 2014
    Hey Guys,
    I’m having an issue of getting this nut and pulley off so that I can tear into this alternator. It there a special tool that won’t mare the pulley and/or nut when attempting to screw off the nut?
    Thank you for your help Guys!
  2. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,322
    Dumpster Fire #31
    SMG
    strange, normally on the ferrari alts there is an allen key in the shaft. must have been replaced at some time during a rebuild with something else.
    it's not left hand threaded is it?
    otherwise the pulley should be key'd to the shaft normally, but with what looks non-oem to me I don't know if that's still there.
  3. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    Put a screwdriver between the fan blades and then remove nut with a socket or offset wrench. Impact wrench works even better. The nut is not reverse threaded.
  4. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I would try the screwdriver only after holding the fan with a rag or towel and trying that first. I think the screwdriver risks bending the fan.
  5. Hank Rose
    Hank Rose Rookie
    Mar 8, 2012
    29
    When I did mine I used penetrating oil, grabbed the fan with a thick wad of rag and used the impact wrench. Came off easily no damage to the parts and (equally important) my hands.
    waymar likes this.
  6. Pero
    Pero Formula Junior
    825
    Sweden
    Peter R
    Impact wrench. Buy one, very useful on the car. Never used it on wheel nuts but many other places such as alternator.
    Peter
  7. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hey Guys,
    Appreciate the advice, but I did actually try the screwdriver in the fan, until which time I could see the potentiality of bending the fan blades. I also tried the rag over the fan blades applying pressure (with hand) while attempting to undo the nut…I even when as far as using PB Blaster on the nut…still nothing.
    I was wondering, is there a special tool that you can use that maybe I’m unaware of?
    Thank you,
    Chris.
  8. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Like Pero said, use a impact wrench. The easiest way and no damage to parts. Been doing this for 30 years and never had a problem.
    waymar likes this.
  9. Ehamilton
    Ehamilton F1 Rookie
    2,634
    Durham, NC; USA
    Eric Hamilton
    Try using the old alternator belt, cinched tight, to hold the pulley after you've let the PB Blaster soak in overnight. And as everyone else has already said, use an impact wrench - the half-inch electrical that Harbor Freight sells is adequate for once-in-a-while use.
  10. i-velocita
    2,520
    Colorado
    James
    I have a cheapo Harbor Freight electric impact wrench and it works great. I bought it on sale for around $35.
    1/2 in. Electric Impact Wrench
    I have never had an issue with bending the cooling fins using a screwdriver. Some of the other methods (towel/belt) sound like good methods too.
    Really consider getting an electric impact wrench. I have a quality pneumatic wrench also but use the cheapo electric one more and more due to convenience.
  11. jagmanv12
    jagmanv12 Karting
    Aug 25, 2010
    236
    Surrey UK
    Mark
    As ehamilton posted. Old belt pulled tight round pulley and held in vice. Then impact wrench or even socket/wrench on nut.
  12. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    I'll give it a shot! Thanks guys!
  13. Weaselwee
    Weaselwee Formula Junior
    Dec 20, 2005
    320
    Long Island
    Jim
    Thread hijack...
    Does anyone know the correct size of the alternator pulley for the 81 GTSi? I bought a new belt, correct part number, and it seems to be too small for the WP/Alternator. Even with the alternator pulled back I cannot get it on. I compared it to another belt I had and it is slightly smaller. Is it possible that the previous owner put a larger size alternator pulley on? I had a belt already, but bought a new one as a spare.
  14. Weaselwee
    Dec 20, 2005
    320
    Long Island
    Jim
    By the way, use an impact wrench for the nut
  15. Steve Magnusson
    26,780
    #15 Steve Magnusson, Mar 13, 2014
    Or a whole different alternator (other makes, with lower RPM engines, tend to use a larger alt belt pulley). What is the Gates PN for the (too short) belt that you bought - 7M975 or 7M1000?
  16. Weaselwee
    Dec 20, 2005
    320
    Long Island
    Jim
    I bought part #117435 from Superformance. I will check the actual part number tonight..
  17. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,808
    Cerritos, CA.
    I change mine to a smaller pulley so even at lower RPM Alt. still spinning fast, no more dim light at idle speed.
  18. Steve Magnusson
    26,780
    Please do. I thought the carbed cars used the 975mm long belt and the 308i/308QV with the single WP+alt belt used the 1000mm long belt (so 107971) -- didn't know that there was/is a third possibility (AFP shows that 117435 PN as being 7M950 so it's shorter than both?: http://www.allferrariparts.com/117435.html).
  19. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    #19 SeattleM5, Mar 13, 2014
    The shaft on my 328 alternator had the allen key recess as described by smg2 but I didn't use that to remove the nut. Instead, I separated the front and rear case of the alternator. Then I took the pulley/front case/rotor unit and secured the rotor portion in a vice. Make sure to protect the rotor by using rubber blocks or wood between the vice and the rotor. Then I took a 24mm socket and removed the pulley nut. The torque spec for that M16 x 1.5 nut is 25-32 ft/lbs. Good luck.
  20. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Any sign of locktight perhaps requiring some heat to break?
  21. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    I've had good success with a nifty little belt-wrench that I picked up at Sears a few years back. It is basically a handle with a long rubber belt. You wrap the belt around whatever you want to hold or turn (I've used it on oil filters, alternator pulleys, etc.), feed the belt into a slot, and twist. I used it to hold the pulley and then used an impact wrench to get the nut off the alternator, as suggested. It is kind of like using the old alternator belt, but the handle of the belt-wrench allows for you to exert more force, gives more leverage. Just a thought.
    p.s. The alternator pulleys on the Ferraris are specially designed, so try not to damage it or lose it. You can't just go out and pick up any old replacement at any parts store or alternator shop. When I had a problem with my 328 pulley, I was able to get a new one from Daniel at Ricambi America. Otherwise, they are hard to find.
  22. Weaselwee
    Dec 20, 2005
    320
    Long Island
    Jim
    I bought the 7M950 (superformance part 117435). On their website, it stated this was for a 308 GTSi. The 1000mm is listed as a QV, so I did not buy it. According to Gates' website, there is a local distributor near me. I will see if I can get one. Again, this was a spare to keep so no big deal. It will probably cost me more to return ship it. Anyone need a 7M950, good price?
    P.S. Ricambi also lists the 308GTSi as the 117435.
  23. Weaselwee
    Dec 20, 2005
    320
    Long Island
    Jim
    old belt is 975mm
  24. Weaselwee
    Dec 20, 2005
    320
    Long Island
    Jim
    7M975 received and installed, works like a charm
  25. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,294
    Ventura, California
    Robert Garven
    Is that M16 x 1.5 nut is 25-32 ft/lbs. correct I have a $$$ rebuilt unit and need to put the pulley on my very knowledgeable good friend suggested an impact wrench to reinstall but I dont want to mess this up. It is off the car and does not have a allen shaft...
