Question for F430 F1 owners | FerrariChat
Discussion in '360/430' started by redduke, Jul 1, 2014.
  1. redduke
    redduke Karting
    Apr 19, 2011
    146
    Silverstone - UK
    Tim
    #1 redduke, Jul 1, 2014
    How long does it take to prime your F1 hydraulic system from opening the driver's door to the F1 pump going silent?
    When warm, mine runs for 5 seconds at a constant pitch then shuts off. When cold it seems to run for 8 or 9 seconds with the pump decreasing in speed towards the end.
    I also find that I get 4 gear shifts between activations of the pump.
    I'm wondering if this is normal or whether my F1 pump motor is on its way out. It's a 2005 car that has covered 24,000 miles.
  2. CAracer
    CAracer Karting
    Oct 26, 2012
    228
    Pflugerville, Texas
    John Blanor
    I have a 2005 also and It takes about the same time you experienced.
    Sounds normal...
  3. futureferraribuyer
    futureferraribuyer Formula Junior
    Jun 23, 2010
    296
    I have 05 with 21K miles. What do you mean 4 shifts? Otherwise sounds about the same as mine.
  4. redduke
    redduke Karting
    Apr 19, 2011
    146
    Silverstone - UK
    Tim
    With engine off and the F1 system primed I can shift from 1st - neutral - 1st - neutral - 1st, then the pump kicks in again to re-pressurise the system. I guess this is a measure of the hydraulic accumulator's capacity more than the pump's effectiveness?
    Thanks for the feedback so far. I'll put my credit card away on the basis of that!
  5. Joegnsx
    Joegnsx Formula Junior
    Dec 1, 2012
    958
    Valrico, FL & Franklin, NC
    Joe Gliksman
    My 05 acts about the same as yours--I have never tried the 4-shift "test" you mention....do you think this is diagnostic?
  6. Labman
    Labman F1 Rookie
    3,801
    Long Island, NY
    Steve
    8 or 9 seconds at cold seems a bit long. Mine primes for about 5 seconds when cold.
  7. RonnieRenaldi
    RonnieRenaldi F1 Rookie
    Aug 16, 2004
    2,686
    With engine off but key in position 2?
  8. redduke
    redduke Karting
    Apr 19, 2011
    146
    Silverstone - UK
    Tim
    Yes that's correct. It's easier to hear what the pump is doing with the engine off.
    I should also mention these tests are performed with a brand new fully charged battery.
  9. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Up to 10 seconds is about right if it's been sitting overnight.
    Alan
  10. skip737
    skip737 Karting
    Dec 31, 2008
    115
    Lodi, New York
    WJH
    My 16M pump works exactly the same as you describe. 5 seconds when used recently, and up to 8-9 seconds when the car has not been driven recently, or when it is cold. Not to worry.
  11. redduke
    redduke Karting
    Apr 19, 2011
    146
    Silverstone - UK
    Tim
    Great to hear guys. Thanks for letting me know!
