Question for first-timers | FerrariChat
Discussion in '348/355' started by 330cic, Aug 30, 2014.
  1. 330cic
    330cic Rookie
    Jul 1, 2006
    25
    I'm one of those "dreamed of Ferrari from childhood" types and am thinking about selling my beloved 50k miles '04 BMW 330 convertible and finding a nice 348/355.
    However, so many questions lurk. So I figured I'd ask those who jumped into this model as a first Ferrari and find out a few things.
    1. Maintenance - the numbers that get thrown around range from "not so horrible" to "national debt". Is budgeting around $5k/year reasonable? I expect to put on around 3k miles a year.
    2. Speed bumps (aka sleeping policemen) - they love these here, both on roads and in parking lots. The last thing I want is to rip off an air dam or something.
    3. AC - folks who live up north store their cars over the winter because of the weather. Down here in Texas I would likely not drive much in the dead of summer. But if I did venture out in 100 degree heat, would the AC be able to handle it?
    4. Breakdowns/Reliability - these are fickle beasts, but do I need to concern myself about getting stranded somewhere? Do I need to say a quick prayer each time I turn the key?
    5. Convince the wife - she's a CPA and the idea of spending that much on a "used car" that would turn into a "money pit" doesn't fly. Do you suggest flowers or candy?
    Thanks!
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    AC works fine
    $2500 year high side over a 5 year span lots less if you do it yourself
    Ride height is adjustable I am low, have no issue on SoCal streets
    Cars are rock solid
    Get a girlfriend :)
  3. 330cic
    330cic Rookie
    Jul 1, 2006
    25
    Thanks for the info! The cost of a girlfriend would dwarf the price of any car!
  4. F1moving
    F1moving Formula Junior
    781
    BUCKeYe!
    Marcus
    Have you tried searching? This gets asked once a week! Being a member since 2006 I'm surprised you have. It stumbled across one!
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    If wife is a CPA the $2500 you save on maintenance a year needs to go somewhere LOL
    Really, the 355 is fully depreciated already and no where to go but up so at worst you will stay even at value.
    They are not so bad a pretty solid car as long as you have patience and understanding like any great relationship. If your a "hands on" car guy you will have nothing but enjoyment
  6. joshtownsend
    joshtownsend Formula Junior
    Jul 12, 2007
    421
    H-town...TEXAS
    I think its is worth mentioning that although the price for maintenance does come out to $1500-$2500 depending on whats done and when, That if you pay someone to do the engine out, and it will happen at some point in those 5 years, that the majority of that "budgeted" money will be spend then.. so you will have something like this
    Year 1 $6000 engine out
    Year 2 $200 oil change
    Year 3 $200 oil change
    Year 4 $600 oil change, misc
    Year 5 $500 oil change, misc
    So that's $1500 a year, but $6k at one time... hope that helps.. then you repeat the cycle all over again
  7. Garvin
    Garvin Rookie
    Jul 15, 2012
    34
    Cambridgeshire
    1. Maintenance can be expensive if you don't select a well looked after example. Make sure the service history is good and always, always get a pre-purchase inspection performed by a reputable expert before parting with your heard earned. A well maintained example should not break the bank but will never be cheap.
    2. Fit a set of skid plates (readily available) under the front valence. These become sacrificial items that require replacement every five years or so but are a relatively modest cost compared to the other running costs.
    3. Can't really help with this one as, living in the UK, the temperature rarely, if ever, gets to 100F. However, I have been in mine in mid 90'sF and it seemed to cope OK.
    4. When well looked after and maintained they are pretty reliable vehicles. However, need to check that the primary causes of significant expense - worn valve guides, cracking headers etc. are examined during the PPI. Best to ensure a compression test and leak down test are conducted as part of the PPI for the former and failed exhaust bypass valve can be a contributory factor for the latter.
    5. Can't help with this one. My OH always knew I would acquire a Ferrari some day. She also has the car she wants as well which helps!
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Great comments already but I'd say it's a rare 348 (with converted a/c system) that can handle the heat of a mid-summer in Texas, or anywhere in the south for that matter.
  9. joshtownsend
    Jul 12, 2007
    421
    H-town...TEXAS
    I drove the car the other day in Houston heat.. around 3 pm..with the ac on high for more then an hour, had no issues what so ever. I believe my system is still r12.. but i'm about to convert is over as well.. Good clean water and working fans is what is needed.. after be sure that the radiators haven't suck up anything like plastic bags and such.
  10. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    See the link in my sig
  11. WATSON
    23,689
    WI
    ^^^^ This. My wife is a CPA as well. But bring a nice bottle of wine with you. ;)
  12. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    #12 hank sound, Aug 30, 2014
    Hi Josh,
    As regards your AC. If it is working properly, leave it be till the time that it is no longer doing so. Anyway, a good working R12 system is perceived to be colder than a good working 134 system ........... so why rush into the expenditure of (properly) converting to 134?
    Cheers,
    Hank
  13. wildcat767676
    wildcat767676 Formula Junior
    May 20, 2011
    531
    Gilbert, Arizona
    I live in Phoenix and mine is black! The AC was a worry of mine too but still being R12 it works pretty well in 100+ degrees this summer. I had a PPI done and came out great but just having the major done cost me $7000. My cam drive bearings were shot and I had to pay a lot for updated bearings and tenshioner that wasn't expected. Also when out they found some melted wires under the intake, so off came intake and wiring repair. Also found a tiny street crack in one radiator that was easily fixed but had to be sent out to a specialist. However, no leaks whatsoever and runs awesome now! Shouldn't have to spend much for quite a long time. '90 348 TS btw with 15,000 miles. Also, I hated the hard shifting Trans and after upgrading to redline superlite shockproof oil it's much improved! Can use second gear almost immediately now.
  14. sevminasyan
    sevminasyan Formula 3
    Jun 24, 2008
    1,156
    Glendale, CA
    Steve
    Slap on some CPA decals on it and claim it as business use to attrack high end clientel. She will love it, you will get the car, her clients will spend more money, the IRS will/should see it as liget business exp. Bin this case you will need to claim actuall expenses instea of mileage. 5 k miles a year will ge you about 2700 in exp and if u don't spend more u r good
  15. JAYKAY
    JAYKAY Formula Junior
    617
    Naperville, IL
    Jim K
    I agree whole-heartedly with this thought. Oddly enough, I had a 2004 330 convertible as well, and the 355 is my first Ferrari. It was a 6 speed car in Orient Blue with black and black. There was a Lotus Elise in between and part of me still misses it, but still.
    My advice is to do your homework on what items should come with the car (tools, books, covers, etc), get the best one you can afford and then drive it like you stole it. My car has been with me for two years as of this weekend and I've yet to encounter any real drama. I live near Chicago and drove the car back from Seattle. Since then I've put about 7k on the clock.
    As for your wife, just remember that as you get older none of this silly crap gets more practical. If it seems marginal now, what will it look like in 5 years? Also, as long as you want something and she won't let you have it there will be a tension in your relationship. On the other hand, if you buy it without consulting her, there will always be a tension in your relationship. The only difference is that in the second case, you have the car. Therefore, the tension is a sunk cost and cannot be included in the Total Cost analysis. As a CPA, she will certainly understand...
    JK
  16. Christian Sasfai
    Dec 31, 2012
    140
    Heath, Texas
    Christian Sasfai
    I have an F355 spider in north/east Texas (spend time in the city and in the country). The Ferrari resides mostly around Dallas. My son and I drove it today, which was not that hot (96 degrees) but the humidity was high. We were cool as cucumbers driving around in traffic - and that was despite the spider top which has NO insulative properties. As for driving in the city, most of the roads are fine, but I have only one way in and one way out of the parking garage at my office. There are a couple speed bumps that I know would catch a front bumper and probably high center the car and the other transitions from street to driveway are too steep and will tear up the front bumper.
  17. 330cic
    330cic Rookie
    Jul 1, 2006
    25
    Mystic blue over sand leather with black top for me. 6 speed of course! Got a Hyundai Elantra GT with a BHSR* for the daily commute.
    *BHSR = Big Honkin Sunroof (panorama)
  18. joshtownsend
    Jul 12, 2007
    421
    H-town...TEXAS
    Hmmm.. I will have to look into to this.. I am fixing to have the compressor rebuilt, so I can do either, but if its going to be colder, then I just keep it as is.. thanks for the info.
  19. fluffekins
    fluffekins Karting
    Jul 21, 2014
    62
    UK Herts/Essex/Londo
    Russell
    I'd save your time with the prayer, give you more time to drive. Oh, and it don't think there's anyone listening.
    Go for it.
  20. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    348's have AC in them? Oh, mine just isn't hooked up.
    In Texas, you can drive around in the summers, but be home by noon. At least that's what I do, sans AC.
