Question for Rifledriver and any other engine Guru | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by 308 milano, Dec 9, 2009.
  1. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,329
    Montana
    Kim
    Guys, yesterday went down to this engine builders shop and was having a cup of coffee and just more or less wasting time. In the corner of the shop was a really nice Chevy 350 engine on a stand. I asked Rob what it was going in, and he said that the owner had just pulled it out of his street rod and brought it back into the shop. Rob said that he put that engine together two years ago and that the owner never fired it and it sat inside a shop but because of the temperature always fluctuating and the engine never being run that the heads and pistons were covered with rust and needed to be tore back down. Keep in mind that it always sat inside! I'm no mechanic but I'm getting a very high reading on my BS meter. Can this be? and if so what does that say for Ferrari Owners that let their cars set for prolonged periods of time.
  2. VGM911
    VGM911 Formula 3
    Apr 8, 2007
    1,379
    New Jersey
    Cars age, even when they're not being used. Moisture can and does make its way into the engine and fluids (e.g., brake fluid). Introduce moisture to metal parts and you get rust.
    I believe that what he told you is likely true. Storage or light use seems to be a smart way to preserve a car, but dangers lurk.
  3. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    I'm no guru, but I say use it or lose it.
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I had a Jag Etype here a couple of months back that had spent 15 years in dry storage.
    The engine was froze up from surface rust on cylinder walls.
  5. the_stig
    the_stig F1 Rookie
    Sep 19, 2005
    3,497
    #5 the_stig, Dec 9, 2009
    Guess the storage wasn't as dry as it was supposed to be, eh?
    Edit: I live by the ocean - can't store anything, everything gets eaten by the salt.
  6. Pass
    Pass F1 World Champ
    13,162
    Salida Colorado
    Mark Passarelli
    This is true for all cars but especially for the 300SL; The happiest cars are the daily drivers. They seem to never need much in the way of work. I have had fresh restorations that were parked for several years and the owners cant fiure out why the car wont start, run good and smokes even though there is less than 300 miles on the car.
  7. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    #7 PAP 348, Dec 9, 2009
    Totally believeable. :D:D
    I received a Ford 351 Cleveland from my old boss many years ago for free that was freshly machined, that we both put back together. (I was doing my 1st year of my apprenticeship back then and it was a present for me, I think.) :):)
    Anywho, this engine was all back together, sealed up and sitting at my Mum's house in the spare bedroom. It was complete, minus the inlet manifold and carby that I had to source myself. Every internal part was brand new. :):)
    This engine sat sealed up from the elements for over 5 yrs. I never once put oil down the plug holes and turned the engine over to stop it from seizing. The engine was FULLY lubed up when we assembled it to stop it from surface rusting etc..etc.
    5 yrs had passed and I still had not used this engine, so I decided to give it away to another friend of mine. He was actually GOING to fit it into his Ford, where I was just too damn busy to get around to fitting into my car at the time. :(:(
    I gave him the donk and he was going to fit it that weekend. Didnt need a hand, so I left him and his mates be. He called me around 1 hr later saying he looked down a plug hole with a telescopic bore camera and the bores look like they have rust in there. He said he was going to pull the heads off to inspect. He found surface rust up top, so he pulled the engine apart and nearly every inch of that engine internally was covered in surface rust. From the combustion chambers down to the crank and sump. :D:D
    No problem though, he ripped it back apart and sent the parts away to get acid dipped again. A few days later, got all the parts back like new again. New gasket kit and it was put back together again and fitted to his car. :D:D
    Goes like the clappers too, I knew I should have kept that engine. :(:(
    I still have my Ford and now I have plenty of time to fit that engine......................bugger!!! :eek::eek:
  8. Rifledriver
    37,235
    #8 Rifledriver, Dec 9, 2009
    It happens. Real problem on aviation piston motors especially something like a Merlin. Sparky here sent me a picture a few months ago of his P51 motor being rebuilt. The cylinders were red with light surface rust and it had not been that long since the thing had run. Short exhaust stacks contribute to the problem I guess. I have a Queen Mother motor here now that is siezed from rusty cylinders from sitting for too many years.
  9. volkster999
    volkster999 Karting
    Sep 22, 2005
    86
    CT
    Neil Volkmar
    A lot of rust happens from condensation and condensation happens when the temperature of an object drops below the dew point. It doesn't matter if the object is inside or outside. This is why you can see condensation on a window in your house or on your tools in the garage. Basically, if an object is colder than the dew point then any warmer moist air will cause condensation. This is all because of the fact that the warmer the air the more moisture it can hold, or said the other way, colder air can only hold less moisture so when warm moist air comes in contact with a colder object (below the dew point) the air gives up its moisture to the colder object, i.e. condensation (often followed by rust). Accuweather.com will give the dew point with its hourly forecast, other sites probably do something similar. So net, net an unused engine, even stored inside, can rust over time.
  10. 308 milano
    Jan 15, 2007
    5,329
    Montana
    Kim
    WOW! We have a fairly dry climate here, would never have thought that a sealed up engine setting inside for a few years would end up such a mess. (guess I need to get a new BS meter)
  11. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    FWIW, I once saw a rust bucket of internal engine components from pistons to bearings in an otherwise pristine TR at a Ferrari shop. Apparently, another owner subscribing to the theory that the best preserved Ferrari is the one not driven. I am sure that bill probably equaled the GNP of Paraguay :)
  12. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    I agree...cars are made to be driven, not parked
  13. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Rust Never Sleeps...
  14. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    This is exactly the reason that all US Military Arms Rooms, which store weapons for extended periods of time, have a dehumidifier. I even keep a dehumidifier in our rehearsal room where all my amps, keyboards, guitars, etc., are...
    Rust, truly, never sleeps...
    Mike in Kuwait
  15. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    I'm rebuilding a 308QV engine now that sat for an extended period of time (greater than 10 years). The piston rings have "pt marks" on them from corrosion...and we won't even begin to speak of the damage the coolant did from sitting in the block!
    David
  16. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Ah, to own a P51 Mustang......
  17. bernardo66
    bernardo66 The Crazy Cat Man
    Dec 14, 2003
    26,554
    Montreal Canada
    Bernie
    #17 bernardo66, Dec 10, 2009
    I gotta ask.....what's with the boxes of Tide detergent lying around? ;)
  18. tazandjan
    39,256
    Bernie- You can mix it with gasoline and make low grade napalm?
    Taz
    Terry Phillips
  19. mseals
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    yes, you can... works well for Field Expedient purposes.
    :D
    Mike in Kuwait
  20. Rifledriver
    37,235
    Not my shop but it does work pretty well in large hot water washing machines like we use to clean blocks etc.
    And then there is that napalm thing.
  21. Italian Lover
    Italian Lover Formula Junior
    Oct 26, 2006
    553
    Italian Lover
    Not shown in the pic, but next enters a gorgeous bikini gal and she uses the Tide w/ sponge or maybe wire brush in this case, to clean ? Bernie, just let your imagination go to work. w/ smiles Jimmy
  22. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    BS meter probably had condensation -- need to use it more.
  23. ztunelover
    ztunelover Formula Junior
    Oct 1, 2009
    641
    Calgary, AB
    Krish
    HAHA good one.
    I have seen rust here in a notchtop stang w/ a 302 in the summer, and trust me it gets dry here in the summer. That includes the last 10 years it hadn't moved, nothing a good chemical bath won't sort out.
  24. bernardo66
    Dec 14, 2003
    26,554
    Montreal Canada
    Bernie
    :eek:
  25. bernardo66
    Dec 14, 2003
    26,554
    Montreal Canada
    Bernie
    Is she wearing heels? ;)
