Question for the code experts | FerrariChat
Discussion in '348/355' started by TrojanFan, Sep 27, 2013.
  1. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,158
    So. CA & NV
    Peter
    My car has no CL's and hasn't for at least 6 months now. I need to have my "smog check" done in about 30 days so I hooked up the obdII and the Torque program and ran for fault codes. I am showing the following 3 PENDING codes: P0410 (secondary air injection), P1448 & P1451.
    Does pending mean that these will become CL's?
    Will any of these cause a smog check failure while still a pending fault?
    What are these codes?
    Any suggestions on clearing the before they become faults?
    Any other concerns that I should have with these items pending?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,664
    South East
    Jimmie
    The basic meaning of each code can probably be checked by looking at the other threads referring to them - try putting one at a time into search and a vast wealth of previous advice will normally appear
  3. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,324
    Palos Verdes
    Vince V
    Clear the codes and drive it around to see if they reappear. I think those last 2 were some of the same ones Ketel was throwing at my house and have to do with the smog stuff.
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Check the fuses under the passenger kick panel, there is a air pump fuse that blows a lot, think its 15 amp
    When you cold start you will here a whinning sound for 2 mins, thats the air pump injecting air to get the cats warmed up fast
  5. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    pending codes, different codes turn the cel after the computer recognizes fault conditions a preset number of times. for instance a misfire may trigger a cel after one detection, other items like a downstream 02 sensor may trigger a cel after the computer recognizes the fault after 6(or more) engine starts. they are called monitors. usually factory repair info has a monitor chart which states how many times a fault has to occur before triggering a cel . codes will stay in pending , if the fault is not recognized in the required number of start cycles , lets say breifly unplugging a temp sensor then quickly reattaching the plug, the computer generates a code, stores it in pending , then looks for the condition to reoccur . if it does not,then the computer will remove the code from pending.obd2 emission testing requires that these " monitor" conditions be met to pass an emission test, thus, you can not reset the cel right before an emission test. each monitored system has a different number of start cycles with no pending codes before the system monitor is met. some monitors such as downstream 02 systems require as many as 20 to 30 start cycles with no faults recognized before the monitor is met. most systems such as upstream 02, maf, temp sensors, are 3 start cycles with a pending code and the cel will illuminate
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    1448 is bypass valve
    1451 is secondary air pump circuit.
    Your bypass valve is not opening or closing as it should, or the related TCU is bad.
    The secondary air pump is not turning on due to a blown fuse, I bet. Note the blown fuse may be due to a bad / stuck pump.
    Good luck.
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Isn't the bypass valve controlled by the main engine ECU? Opening is dependent on RPM and gear selection and throttle position, no?
  8. TrojanFan
    Nov 17, 2008
    5,158
    So. CA & NV
    Peter
    Should any of these pending codes cause problems for a smog check?
  9. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    The ECU sends a signal to activate a vacuum port which activates the bypass valve. Once opened, hot exhaust air goes to the other side of the valve and changes the air temperature which is picked up by a Thermocouple attached to the muffler. The thermocouple also goes to the Thermocouple Control Unit which is attached to the wiring harness back to the ECU completing the feedback loop.
    When the valve is stuck, and the TCU does not see the exhaust temperature in the bypass valve, it throws a CEL code. If the valve works and the TCU is bad, it also throws a CEL.
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Don't quote me but. I believe they will cause you problems. Do a search I think you are allowed 1 pending. Code only in California. If you search your state and smog it will tell you the conditions.
  11. johnk...
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Ok. That makes sense.
