Question on 400 | FerrariChat
Question on 400
Discussion in '365 GT4 2+2/400/412' started by Franc308, Nov 1, 2007.
  1. Franc308
    Franc308 F1 Rookie
    Sep 23, 2006
    3,276
    Netherlands
    Franc
    Today I went to have a look at a 1980 400 carb'ed version, automatic. It was in a very good condition.
    However, I did notice cracks in the 4 corners of the body where the bonnet fits in, all about 1 inch long. Surely the paint was cracked, but I believe the body work as well.
    Is this a known weak spot of the body and something you would see more often ? Is it something to be concerned about?
  2. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    My understanding is that this is very common w/400s, stress fractures, and I wonder how many people take the initiative to weld a backing plate at these point before their repaint jobs.
  3. fez1238
    fez1238 Karting
    Sep 5, 2007
    170
    Yes its a known problem - but as far as I am aware its the paint only. This is because they are quite large panels and some are quite 'flat' and therefore normal stress conditions cause the paint to crack.
    As far as the metal cracking I doubt it . It could be due to rust causing weakness after the paint has cracked. Not a big deal as, if Im correct, the chasis and frames that gives the car its load and stress bearing strength.
    Hope this helps
    Andrew
