Might be easier just to invest in ceramic coating for your aftermarket headers though mainly to save you the headache and time.
I am a metal worker by trade, it seems like a simple shape to hand form. if I make them to fit Tubis for $100 each would you like to see one?
Thank you but most of Tubi's manifold come pre-shelled from the factory so no reason to make them fit our manifolds.
Just another option: My Ferrari dealer repairs the manifolds. Big $ saving and you can stay OEM. Not that difficult to get the shells off and re-weld. I got the shell off my manifold to find the crack but then scored some good challenge headers so went that route. Once repaired just bin the lower rear brackets (the cause of the header failure) and you're good to go.
I'm about to install my Tubi manifolds. Looks like they won't be as easy as others due to the air rail, but I'm going to give it a go. I had 2 shops quote installation, but were about $1000 labor. I bought all new Ferrari OEM gaskets, studs (jic), nuts and clamps. Seems like a decent price, and both shops said they could get it done in one day. My issue is that much of the time I take my car to get worked on, I find something not right or the quality of work inconsistent with my expectations. Since this isn't complicated, just frustrating (it seems), I plan to try myself.
What are you going to use to remove the studs from the head . Also see if u can find some ceramic lubricant for the stud threads, a lot better than copper anti seize. The book has a torque for the nuts but no chance with engine in car so its just a judgement call on tightness
Thanks for the tip on the ceramic lube, I’ll look. Once I have the manifolds out I’ll either double nut the studs or use my stud puller tool. Then again, if they stay put and look good, I may leave them well enough alone. Sent from my iPhone using FerrariChat
Reason i ask about getting the studs out is that trying double nuts is a waste of time as not enough room to get the spanners in, what is a stud puller tool ? I can let you have a drawing of a stud box if u can get one made locally, very small and easy to use in confined spaces. My ferrari garage always change the studs as known to break after time, not a good idea to leave old ones in.
Very short length of hex bar, tapped full length with stud thread. Then short allen screw in one end. You lock this onto the stud like 2 nuts but a lot easier to use in confined space and it does not slip on the threads.
