Question regarding shift alignment | FerrariChat
Discussion in 'Technical Q&A' started by christopher, May 30, 2006.
  1. christopher
    christopher Formula 3
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hello Gentlemen,
    I'm attempting to align me shifting fork (inside the trans) to the correct position. Can anyone tell/show me how the fork (inside the trans) should look when the shifter is in neutral?
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    The actuators for all 3 gears should be lined up, with the lever operated by the shift rod centered in the middle actuator.
    Have you made up something that keeps the detent balls & springs in place while you're doing this? If not, make one out of a piece of hard wood.
