Question related to 348s | FerrariChat
Discussion in '348/355' started by ceb39, May 6, 2014.
  1. ceb39
    ceb39 Formula Junior
    Sep 17, 2012
    483
    San Francisco Area
    Chuck B
    Some time in April there was a post related to 348s. Specially it described how to remove and lubricate the shafts (which are within tubes under the car) which are used to change gears. Can not remember whether it was on F Chat or elsewhere.
    Should have printed it out, but I knew I would not have any trouble finding it again. So much for depending on my memory.
    ceb39
  2. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    You mean paul's video (Pnichollsan on fchat)
    https://www.youtube.com/watch?v=mIvAhIBVzBA
    Really good tutorial and I actually did this yesterday (but without a ramp).
    348 DIY "Restoration" - Page 149
    If I may I'd like to just a couple of things....
    1) In the video it mentions to apply the lubricant to where the cable goes thin which I di as per video. However, I noticed that after doing that you could get even more (as in extra not instead of) freeness of the cable by apply lubricant into the "cup" and wiggle in the cable up and down.
    2) If your struggling with that very inaccessible 8mm bolt to undo the spacer plate undo the 4 13mm bolts holding the bottom of the gearchange mechanism plus the 2 set screws holding the H gate inside and the mechanism will drop about 5mm making it much easier to do :)
  3. AceMaster
    Feb 6, 2009
    34,786
    Ontario, Canada
    Always check the "348 do it yourself " thread at the top of this forum
  4. ceb39
    Sep 17, 2012
    483
    San Francisco Area
    Chuck B
    Thank you, thank you, thank you.
    Forgot it was on You Tube.
    ceb39usa
