Questions about AK-47s | FerrariChat
Discussion in 'Other Off Topic Forum' started by 96impalaSS, Dec 7, 2004.
  1. 96impalaSS
    96impalaSS F1 Rookie
    Dec 8, 2003
    3,524
    Hell
    Chris
    I plan on buying one in a month and I was wondering if anyone knew anything about them on this site. I know some things like there really durable but I was wondering about accuracy. From what I know there not too acurate but I'm probally only going to use it to shoot old microwaves with anyways and maybe coyotes. Any info on them would be much appreciated. Such as if ones from one country are better than ones from another.
  2. UroTrash
    Jan 20, 2004
    40,535
    Purgatory
    Clifford Gunboat
    There won't be much left of your squirrels that you've been hunting! :)
  3. 96impalaSS
    Dec 8, 2003
    3,524
    Hell
    Chris
    Ha.
  4. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    Greetings.
    They are not that accurate. They are superbly reliable. They were designed with mechanized warfare in mind. They were to be issued to simple line troops of the Motherland. The Sov's realized that most engagements occured at short range. -Well less than 400 meters. The infantry was to support the steamroller waves, of T-62 and T-72 tanks penetrating the Fulda Gap etc.... The AK is an excellent weapon to have, from 50 to 150 meters. - Nothing can go wrong. It will always work. It is almost a sub-gun.
    I have heard that you can get much better accuracy; if you are willing to reload your own ammo. Most shooters of AK 47s, use old military ball. The Kommies, did not extract much accuracy from their military ball.
    I would say the Yugoslav AK-47s, are amongst the best ones you can obtain. The Finnish is way up the ladder. An original Valmet M-62S, can run in the very hi 2K+ area. The Yugo AK can be found in the low 2k range (perhaps less ?). The Egyptian Madi is also a nice item. It is pretty much identical to the Russian AKM. They can be found in the low $1,200 range. Be sure it is an original rifle. Another consideration is also the Hungarian FEG pre-ban. The Chinese rifles (original pre-ban) are probably around $600 and up. There are alot of put together post-ban rifles. Most important. - Make sure you are not buying a post-ban rifle, that is dressed up to look like a pre-ban.
  5. gentry
    gentry Guest
    They are plenty accurate when you get used to how far off they are in general.
    Figure on firing up and to the right alot (at least that is how mine is).
    The thing is, no pun intended, bullet proof.
    When you do buy one though, make sure to get one that has machined parts and not stamped parts. It will last you much longer and will feel much more solid.
    Good luck and enjoy.
  6. infraredline
    infraredline Formula 3
    Mar 15, 2004
    1,036
    San Francisco
    Are the sights not adjustable?
  7. gentry
    gentry Guest
    they are, but I dont have a sight tool for the AK, and, the last time I sighted it with a buddy of mine that works at the range, it lasted about 300 rounds before they were off again.
  8. RacerX_GTO
    RacerX_GTO F1 World Champ
    14,770
    Oregon
    Gabe V.
    pfffffttt, yeah, that's all its good for, CQB of 50 yards or less. But VERY reliable. You can get dirt, mud, grime in the thing and it will still fire.
  9. Murcielago03
    Murcielago03 Formula Junior
    Jul 5, 2004
    428
    Montreal
    Shaan
    Aren't they illegal to own in the own in the US??
  10. gentry
    gentry Guest
    no, they are only illegal if they are post ban automatics.
    Mine is semi-auto.
  11. jharkercfduc
    jharkercfduc Karting
    Sep 4, 2004
    133
    riverside california
    jonathan harker
    sks is another option, it does not have the retractable stock, but shoots the same round and has all/ or most of the same moving parts. if you want accurate, I would buy a bolt action rifle, if you like shooting stuff up just for fun, ak/sks are fun. also the larger the magazine, the more likely they are to jam due to the spring in the magazine. also if you know what you are doing, you can alter the sear in the triger mechanism to make it fully auto if that does it for you. china sks i think are the cheapest version of the ak/sks.
  12. infraredline
    Mar 15, 2004
    1,036
    San Francisco
    Ahhh I see - I probably won't be picking up a rifle anytime soon, but the M16 vs AK47 argument has always facinated me.
    I was recently lucky enough to shoot an AR15 back to back with an AK. Although the carbine had a more precision feel, I was amazed at how accurate and easy to shoot the AK47 was with a nightsight scope. Plus it felt much better to hold for my 6'3" frame, and although heavier than the AR, it wasn't too heavy at all.
    My impressions so far are that the AK47 is like a vette - reliable and can take a pounding, while the M16 feels more like a ferrari - superbly engineered and built to tight tolerances, but more demanding of its owner.
  13. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    14,002
    MO
    Omar
    I like 74 variants better personally with the 5.45x39mm.
  14. Forzaholics Anonymous
    Forzaholics Anonymous Formula Junior
    Aug 23, 2004
    679
    So Cal
    Mike B
    I had a Norinco Type 56-s in .223 and a MAK-90 in 308 short.
    They were surprisingly accurate from a benchrest- around 2 MOA, which for the cost, was pretty amazing.
    I fed them handloads with 55gr Speer FMJ. The cases were all of similar weight and length and I miked each round after seating the bullet. If they were .005 off, i used the round in a different gun or pressed the bullet in a little more. It was like making benchrest loads for a semiauto...just something to try for the sheer heck of it.
    Ahhh, to have the time to handload again........
  15. ronr
    ronr Formula Junior
    Oct 30, 2002
    813
    DFW, TX
    Ron
    If you want Intelligent and accurate information on AKs, try AK47.net, not a car site....
  16. thecarreaper
    thecarreaper F1 World Champ
    18,080
    Savannah
    buy a Dragunov 7.62x54mm
  17. thecarreaper
    18,080
    Savannah
    by the way. the milled reciever guns are more desireable than the stamped ones. if you look at my pics , the all black gun has a "square" in the reciever above where the mag goes in. this is how you tell a milled steel reciver from a stamped one. though the stamped guns will also last forever too, the milled ones have a better feel and are more accurate.
    i would suggest a Romanian ak47 with the scope rail, the Dragunov scopes can be purchased seperately. i need to find batteries for my scopes, but i think there is a common camera battery that will replace the Russian vintage one.
  18. gentry
    gentry Guest
    Keep that man away from clock towers.
  19. 96impalaSS
    Dec 8, 2003
    3,524
    Hell
    Chris
    Thanks for all the input guys.
    As far as redline was saying about AK-47s and M-16s. My M16A2 I had in the Marines was very accurate. I could hit the target at the 500 yard line at least 8 out of 10 times. And that was with iron sights. But the damn thing would jam with even the slightest sand in the chamber. Every time we'd take a rest I would have to pop out the pin and remove the bolt carrier group and clean the whole damn thing very thoroughly. If you ever get a M16 remember these 3 words. Tap, Rap, Bang.
  20. gentry
    gentry Guest
    Wow, you are Chevy Chase? If you'll be my body guard, I can be your long lost pal...call me Al.
