Questions after a few recent US Airways flights | FerrariChat
Discussion in 'Aviation Chat' started by RWatters, Nov 16, 2010.
  1. RWatters
    RWatters Formula 3
    Feb 21, 2006
    1,075
    Kansas
    #1 RWatters, Nov 16, 2010
    During a honeymoon fiasco (that was our fault, passport troubles on a flight to Cancun Mexico) we ended up taking six different US Airways flights. As strange as it sounds I have to say their customer service was nothing short of amazing which will come as a shocker to most I'm sure.
    Anyways, I noticed on all six flights that the plane would taxi on one single engine. The pilot would fire up the other engine shortly before takeoff. I also noticed on each of the flights that once we were in the air and approaching cruising altitude that the plane would slow very rapidly all of the sudden and then fly normal. The rest of the flight you could hear a very low-frequency humming and vibration noise that sounded exactly like an engine at idle. As we began landing procedures you'd hear that engine come back to full steam. Each time the engine went back to full steam you would see a flicker of lights and the inside air would kick off for a few moments exactly like it does when they're firing an engine up on the ground.
    Is it normal to cruise essentially on one engine under full power and the other idling? We flew on A319's and A320's the entire trip so it was different planes and they were still doing it. If that wasn't the case, any ideas what it might've been?
    BTW, A319's have to be the most uncomfortable plane I've ever flown on. The seats are garbage! A320's have the most annoying-sounding turbine engines at full-song I've ever heard as well. Sheesh. It would get into your head and about drive you nuts the entire time they were taking off. I couldn't stand it! I missed flying on 737's the entire time that's for sure!
  2. Chupacabra
    Chupacabra F1 Rookie
    3,564
    Behind a drum kit
    Mr. Chupacabra
    Yup. No Airbus is very comfortable, IMO, at least none I've been on. Can't comment on the other stuff, but I wouldn't imagine the FAA would let something like operating an air carrier on one engine slide. Someone please tell me I'm right??!!
  3. JLF
    JLF Formula 3
    Sep 8, 2009
    1,708
    #3 JLF, Nov 16, 2010
    They crank only one engine to taxi to save fuel, i cant speak for the Airbuses but the 717 burns about 105 gallons an hour per engine at idle so i would think the airbus was similar maybe a little more.
    They do not run on one engine in flight...not ever, unless of course there is a failure. The humming and rumbling is normal as the two engines may not have been completely in sync, engine syncs sometimes stop working so great as a plane gets older.
    On approach its typical for the engines to go to idle now and then and then come back in with the power, as they start producing power the flow control valves modulate to keep the bleed air pressure within tolerences to the air conditioning packs thats why the air conditioning modulates like that also the generators are spiking a little with the power changes to cause the lights to flicker most likely.
  4. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,693
    Washington State
    Brian
    Seats have nothing to do with the aircraft - that's the airlines choice. Airbus (as will Boeing) will put any FAA approved seat in the plane the airline wants.
  5. 903L
    903L Formula Junior
    Aug 13, 2009
    703
    S. Calif. / Arizona
    Marty K
    Thats why they call them, "SCARE-BUSSES". If it ain't Boeing, I ain't going!
