questions for Ducati enthusiasts | FerrariChat
Discussion in 'Motorcycles & Boats' started by IROC_DIS, Mar 23, 2006.
  1. IROC_DIS
    IROC_DIS Formula Junior
    Jun 22, 2004
    859
    Columbia, SC
    craig w.
    its sort of a weird question, but would you guys mind explaining the general differences between the base, S, and R models? I know that the 748 had all three, as did the 998, and now the 749 and 999. did the 916 have them? were there any others that had them?
    also, i'm not quite sure how to word this, but how different were/are the 1000cc bikes from the 750cc bikes of the same year. like a 2000 748 vs a 2000 996, or a 2002 748 vs 2002 998, or brand new 749 vs brand new 999. is it like comparing 1000cc vs 750cc japanese sportbikes where both are retardedly fast, just the bigger one weighs a little more?
    are there any models that were more mechanically reliable than others? or any specific years? thanks!
  2. DesmoDog
    DesmoDog Karting
    Jan 2, 2005
    102
    Dexter, MI USA
    Craig Kenfield
    To break down the different models year by year, model by model, would take more knowledge and time than I have... In general the base, S, and R will have different suspension components and engines. I could be wrong but IIRC the R isn't legal for road use in the US.
    The 750 vs 1000 question varies for year too. The 7xx base will often have lower end components than the 9xx base. They pretty much have to do that to keep cost down, I'm guessing it doesn't cost significantly more to build a 1000 over the 750, but you can't easily sell them for the same price... (The 750 Ducs are typically compared to the 600cc four cylinders BTW, and the 1000 to the 750 fours, until recently anyway.)
    I don't think any of the Ducs are retardedly fast... but yeah, they're all fast enough to hurt you. The smaller bikes are preferred by some because they rev quicker/higher, and handle differently. The bigger bikes are preferred by others because they are seen as more of the "real deal".
    All of the 4 valve superbikes are high maintenance. As for reliable, you'll hear horror stories but I've never been stranded by a Ducati. Then again, I've only been riding them for 15 years now though. ;-)
    I get the feeling you're thinking of buying one? Forget about the S or R models unless you're looking for bragging rights, the base model will be more than enough for the street.
  3. KTG
    KTG Formula Junior
    May 16, 2005
    820
    Chicago,IL
    I'm not exactly sure what you are looking for, but here is some stuff:
    998: (436lbs) 123hp, Showa front suspension
    998 S: (412lbs) 136hp, 43mm Showa front suspension (167mph)
    998 R: (403lbs) 139hp, 43mm Ohlins front suspension (174mph)
    All had Ohlins rear suspension, same gear set, injection, brakes, tires
    Total production 916-998 racers and all: 38,403
    748 Strada: (440lbs) (95-99')98hp (00-02') 97hp (149mph)
    748 SP: (436lbs) 104hp (155mph)
    748SPS: (427lbs) 104hp (155mph)
    748R: (422lbs) 106hp (158mph)
    43mm Showa front suspension all except (00-02') 748R which had 43mm Ohlins.
    Length changed though in 97' from 80.7" to 79.9"..and height from 42.9" to 42.5" and width from 27" to 30.7"
    Differences
    748 (final drive... 2.71:1) (compression 11.5:1)
    748 SP,SPS (final drive...2.64:1) (compression 11.6:1)
    Total production 748 racers and all: 25,174
    Chassis sizes between the 748 and 916 were the same, but the 748 had a lower profile front tire and narrower rear tire. In 2000 the 748R still used the standard Showa front, but in 01' got Ohlins...The R's also had Slipper clutches. All 9's and 7's use Dry clutches, which create a hell of a sound on their own!
    The 999 continues the tradition...Base, S, R
    999 (more and) (Less and) Showa
    999S (more) (Less) Showa
    999R (HP) (weight) Ohlins
    And the whole 749 vs Japan 600cc, It all comes down to hp and torque...The 4-cylinders create such easy power from their tiny pistons smashing away, but the Ducatis Twin is a tad more lagged...good torque though and a hell of a sound! The 999 now runs against the 1000's........
    Also R's can be used in the usa...
    Thats my Ducati fetish of the day!
  4. IROC_DIS
    Jun 22, 2004
    859
    Columbia, SC
    craig w.
    haha nah, not anytime soon. i was just curious about it. on another board a member had visited a local bike dealership, and took a picture of a 998R that had 0 mile on it, in fact had never even been turned on. i guess they didnt even have it for sale, they were keeping it as some sort of trophy to show off. so it piqued my curiosity. are the R versions just that rare?
    edit// thanks for the late night info guys :)
  5. KTG
    KTG Formula Junior
    May 16, 2005
    820
    Chicago,IL
    I'm not sure how many 998R's were made, I could tell you just about any other....In the USA(I was wrong 1st post) the 998R is NOT street legal. They haven't really published an exact number of 998R's made...I believe it to be quite low.
  6. IROC_DIS
    Jun 22, 2004
    859
    Columbia, SC
    craig w.
    any ideas on what the redlines were for the 7XX vs the 9XX?
  7. desmomini
    desmomini F1 Rookie
    4,111
    Upstate SC
    Jeff
    Interesting question when dealing with Ducatis...
    My Monster 750 isn't even equipped with a tachometer. The L-twins Ducati uses are very different in power delivery from the peaky inline-4s of the Japanese manufacturers. Ducati's motors are very torquey, so you don't worry about wringing them out to redline, you just try to keep the front wheel on the ground as you start out, then follow the method of shifting whenever the power starts to drop in any gear.
  8. sherpa23
    sherpa23 F1 World Champ
    10,009
    Rocky Mountains
    Bastuna
    That's wrong. The 998R was street legal (as is the 996R). I should know because I had one. And it was registered on the street. There was a limited number (I can't remember how many).
  9. sherpa23
    10,009
    Rocky Mountains
    Bastuna
    748: 11,500
    998: 10,500
    It may be the other way around as I can't remember now. I haven't had a Ducati street bike in 2 years.
