Questions regarding the removal of 40DCNF carburetors?? | FerrariChat
Discussion in 'Technical Q&A' started by christopher, Oct 27, 2008.
  1. christopher
    christopher Formula 3
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hello Gentlemen,
    Well, I think I’ve been talked into sending my carburetors to Pierce Manifolds for rebuilding, which brings me to ask for a little tutelage: I’ve not removed carburetors on a 1979 308GTB, much less anything else, might there be any thing in particular that I should be advised of, or it is a simple removal?
    My other quest is once a send the carbs to Pierce, might there be anything I should ask of them to restore them to O.E. condition? Perhaps, plating, cading and etc? I’d like them to be as original as possible.
    Thanks Guys, appreciate the help.
    Regards,
    Chris.
  2. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    #2 Artvonne, Oct 27, 2008
    The best advice I can give of is not to drop anything down inside them, or the manifolds after the carbs are off. Take your time. There are a couple nuts that are rather difficult to downright impossible to get to until you remove one of the adjacent carbs. Best to take a picture and make some notes so you remember which carb goes where, or (in case they mix them up), which set of linkages go where. Once you have the airhorns and airbox removed, remove the fuel lines (pull the fuel pump fuse in case you accidently turn the key on), disconnect all the throttle linkage (this is another "fun" job), and then start removing carb nuts and washers. A magnet is a handy tool to have nearby. Once they are off, put some duct tape over the manifolds to keep anything from dropping in.
    You may want to consider redoing the coolant hoses in the engine valley under the carbs (while your in there).
    As Pierce are the noted experts, I would imagine you could ask what they generally do with them, but I would believe they would come back like new.
  3. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Chris,
    It is pretty straighforward, but watch out for all of the little parts that can fall into the engine or down the carbs. When you lift the air filter housing, there are pads under there with spacers. Those can fall out and down into the carbs. I put some clean shop towels into the carb throats to keep things from falling in, and I was glad that I did. Some of the nuts that hold the carbs to the top of the intake manifold can be buggers to get to also, but persistence pays off there.
    I'd also suggest you take some pictures of how the carbs sit, how the various wires and pieces are attached. Then after you put them back together and reinstall them, do Birdman's carb balancing procedure. You car will thank you for it.
    Cheers,
    Steve
  4. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Gentlemen,
    Thank you for taking the time to break-it-down for me! I will proceed as you advise.
    Thank you very much.
    Regards,
    Chris.
  5. BigTex
    79,406
    Houston, Texas
    Bubba
    You grind down the nose of a long socket to get the trumpet hex nuts off, I think that's what Paul means...
    And yea, of the 16 brass bushings that ride the studs in the base gaskets, at least one will already be lost so you need to spend two days worrying and looking for that......
    Then you ha veto sync them when they return all shiny, an art in itself!
    HTH.....
  6. FasterIsBetter
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    I second Paul's suggestion on changing the hoses in the valley and generally cleaning that whole area up while the carbs are out. It's the easiest time to do that work.
    I had no problem removing the nuts that hold the trumpets, but I used a 1/4" drive socket and extension. They were small enough to fit in without any problems. Since they are not all that tight, you don't need a lot of effort to get them off. But, again, be very careful. And watch out for those brass bushings. When they go flying, they will make your heart stop.
  7. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,526
    Raleigh
    Kevin
    There must be a patron saint of Ferrari carburetors, mustn't there be? I mean one to pray to in times like these? :):) Good luck, Chris.
  8. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    St. Venturi, Maybe?
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    That joke really sucks wind.
  10. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,664
    Engine Bay, Georgia
    George C.
    Hello Chris,
    Just some general comments about rebuilding DCNFs. If one is rebuilding the carbs as a labor of love that is one thing, if on the other hand it is just to get them up to general specs, then that's an altogether different scenario. I know that the Pierce folks are the ones to go to. I would conjecture that the returned carbs would be like new. I don't know if they use the yellow zinc chromate [that I believe was OEM] or the more durable cadmium in their plating process. Either way, both are sacrificial metals, and they will deteriorate [some parts faster than others, don't know why though] over time. That is a bad thing.
    Have Pierce rebuild them and then redo the fine points yourself as a possible option. You could always powder coat the re-plated parts and then reassemble. Powder coating in translucent gold over a polished bracket/bolt/washer literally gives you an impervious finish for life that looks like OEM. Powder coating is so cheap and easy! Polishing the aluminum truly makes it look awesome as well. Then you can always file and polish out casting seams on the intake to improve air flow...Pierce I guarantee will not do that for you. You could rebuild them yourself if you are looking to do it for the experience....key words here are research, faith, and patience. All of this may be irrelevant to your needs, however, I just had to throw in my two cents worth, OK maybe a nickels worth then.
    Take many, many pictures, and download all of Pierce's PDFs on the 40s just to get acquainted with the parts. My rebuild kit had the wrong jets in it. I would check what is originally in your carbs. If things were running well then make sure your idle jets and main jets remain the same size on the rebuild. I kept my original fuel filter as the new one was plastic junk IMHO.
    If this business interests you check out Russ's thread about the 44 DCNFs float setting in this technical section.....lots of amazing info. that Russ and his fellow DCNF gurus have put together.
    Ciao,
    George
  11. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Very good advice. Seriously, carbs are actually very simple, and not hard at all to disassemble and clean. But obviously if you dont feel confident or dont have the time, an expert isnt a bad idea. Just out of curiosity what does Peirce get to overhaul four of these carbs? And do they drill out the lead plugs?
  12. Glassman
    Glassman F1 World Champ
    If you are expecting to get them back ready to bolt on make sure that Pierce understands that. My 36DCL's came back needing total adjustment before they could be tuned. Throttle plates not closing, bottoms not flat, etc. But the price was really right.
  13. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,286
    Black Forest Germany
    Martin N.
    #13 Martin308GTB, Oct 28, 2008
    what's often overlooked is; make sure, that the shop who rebuild the carburettor - is aware of those myriads of lead plugs... if they don't drill them out anyway, like Paul stated. Most carbs are damp and this is mostly caused by those leaking plugs and not by any gaskets.
    Ultrasonic cleaning makes things worse - and it is mandatory to restake the plugs while rebuilding the carbs.
    There's either a Weber special tool for performing this, but also a simple alternative method. But I know the disappointment when seeing freshly rebuild, nice clean carburettors, maybe with freshly plated hardware, leaking like hell, just because noone thought about those plugs.
    Best Regards from Germany
    Martin
  14. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Well I have the air cleaner canister off and the nuts weren't (thankfully) a problem.....I'll press on....
    Thanks for the advice!
    Chris.
  15. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hey Seamus, it would appear so,huh? It looks as if there a lot of people that have this down!
    Take care Seamus!
    Chris.
  16. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Thank you vrey mcuh for the detail of your experience. You actually raise a few good questions regarding O.E. finishes! I wouldn't know what these babies look like new. I mention this becaulse I'd like to have a guide as to how they look in order to replicate them....
    Thank you very much!
    Chris.
  17. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Pirece quoted me arond $250.00 for ea. card., which isn't bad, I'd just like to replicate O.E. finishes. Might anyone have a picture(s) of what they may have looked like new for a 79 308GTB? PS: Thank you for your confidence in me, I might take a stab at it still!
    Regards,
    Cnris.
  18. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Very good to know, I would have not thought to mention that!
    Thanks,
    Chris.
  19. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Ich Will frage das, gut information!
    danke, Chris.
  20. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hey Guys,
    I’d like to open this question to the group:
    Might anyone have any pics of 40DCNF carburetors in there excellent original condition, or in restored condition?
    The reason for the request is that since I’ll be having my rebuilt, I’d like to replicate any O.E. finishes.
    Thanks a lot Guys,
    Chris.
  21. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    Buy the Haynes Weber book.
  22. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    What retailer would be the best sourse for the 40DCNFcarbs?
    Thanks for the advice.
    Chris.
  23. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I got four 40 DCNF-12 new from GT Auto Parts in Az for a very attractive price. Worked terrific.
  24. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,664
    Engine Bay, Georgia
    George C.
    #24 gcmerak, Oct 30, 2008
    Hi Chris,
    My carbs are 44 DCNFs [close enough]. They had approx 20 K on them when I started the rebuild [work still in progress]. I've had a lot of discussion about those plugs. None of my plugs were leaking, so I'm leaving mine be.
    As stated before, it's not hard to bring them to pristine condition, as well as doing it better yourself when compared to a shop doing it for you.
    Basically, the following items should be either plated/powder coated or for the DIYs polished/powder coated: bolts, washers, screws, springs, and all levers. That should be about 20 items per carb IIRC. Since mine were 28 years old, but with low miles it was easy to see what was originally plated.
    FWIW here are some pictures of a 44 DCNF. I'm still not finished with this one, will post a completed carb soon, but you get the general idea.
    Ciao,
    George
  25. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    I'll get it from them!
    Appreciate the lead.
    Regards,
    Chris.
