Well Guys, As I was ordering the rebuild kits in preparation for the rebuild and Lee from T. Rutlands suggested, no he urged, that I simply remove the top of the carb to see if it was in fact that badly gummed with gas deposits. Apparently he has rebuilt a few 40DCNFs and remarked that he'd seen my exact example......What he heck, I'll give it a try. I mean they worked fine before I let them set for a while. In short, I bought the rebuild kits but can't find a WEBER book to save my life! Can anyone help me with the parts that I'll need to replace to start?? Just to get it running..... Thanks guys, Chris
Check with this guy: http://carburetor-manual.com/index.php You might want to E-mail them, as I didn't see your specific model in the list, but they may still be able to help you. As I mentioned earlier, I have a complete Weber DCOE manual in pdf form, that might serve as a guideline when used with the 40 DCNF parts list I inked you to in a previous post. I also have another Weber factory manual, but I am currently scannerless, my flatbed recently having gone toes up.
Chris,this is the book you want... http://cgi.ebay.com.au/Haynes-Weber-Carburettors-to-1979-Tuning-Overhaul-Specs_W0QQitemZ120335831984QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item120335831984&_trksid=p3286.m63.l1177 I have it and it is pretty useful,although slightly vague when it comes to tuning.
I appreciate your help. I'll look at the links and see if I can put them to good use! As far as cleaning, can either of you give me advice on what parts to clean without removin the entire carb? Thanks Guys, Chris.
If any of the ducts are gummed up, from gasoline evaporating and leaving the varnish deposits behind, there really is no recourse but to remove and soak them. I recommend the NAPA solution I posted earlier. This guy has some nice (general, not Ferrari or Weber specific) tips: http://www.dansmc.com/carbs.htm
What I'll do is open her up and see what the damage is since I bought a rebuild kit. BTW: dennis McCain sold me a kit that services ALL four carbs for $48.00 +shipping (which turned out to be more than the cost of the kit, as I needed it next day...bummer). When I open them up, which areas are suspect for problems as shown on the diagram by number? Thank you very much. Regards, Chris.
Sorry, I'll try it again as I could use by diagram number the areas to review as suspect. Hopefully the attachment will now attach. Thanks, Chris.
Don't know how many times you've told us you're a perfectionist about your F-car. Really can't understand you trying to find a short cut on the webers. There isn't one. Over-haul them properly. Its not that difficult and certainly the smart thing to do.
I was actually preparing myself for the removal and rebuild, it was only when I was chasing down the kits, both sales associates from T.Rutlands and G.T. Car Parts spoke against it. So you can probably see why I would have been on the fence. Having never worked on a carburetor before I was just a little timid and looking for an easy way out since they worked well prior to allowing gas to sit in them. Thank you for the reply and advice, we'll give it a shot this weekend and I'll post experience. Thanks again to all the offered assistance. Regards, Chris
These pics are courtesy of Carl Jones http://autos.groups.yahoo.com/group/ferraritech/ Im sure he wont mind me posting them here are also some pics of NOS 40 DCNF's some more links http://emelbon.tripod.com/308_carb_rebuild/ http://www.fca-se.org/carbs/ http://ferrarichat.com/forum/showthread.php?t=60757 http://www.birdmanferrari.com/index.htm Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Hi Chris, Chis, my engine is obviously different from yours. Once I took out the first carb., I loosend everything on the other 2, but left them in place so that I could just focus on the one carb. When you take one apart and finish what you set out to do, put it back together again once you do this for a while you will become adept with the assembly. Practice taking them apart and then reassemble and do nothing else for a while. Most of these guys here are experts at this, but for the beginner it's a process of learn and relearn till you have it memorized. Dealing with multiple carbs from the getgo would have been a problem in the beginning for me. Now it's a walk in the park Chris! I hope this helps....Merry Christmas Ciao, George Image Unavailable, Please Login Image Unavailable, Please Login
Excellent tutorials! This is going to help a bunch! I downloaded EVERY link you provided! Many-many Thanks! Chris.
Thanks, I thoijnk that is the approch I'll take as a fellow novice, I think that was excellent advice! Thank you, Chris.
Hey Guys, Before I start, I should probably be concerned with "Torque Settings." I would think I'll needing settings for all the components during the rebuilding process and settings for the carburetor reinstallation process. If anyone could share these settings, I'd be grateful! Also, are there any parts of the carburetor that I'd want to keep from carburetor spray or solvent? Does the carburetor spray / solvent eat cad/zinc/chrome finishes? Thanks again Guys, almost ready. Chris
Hi Chris, I didn't have any problem with zinc or cad finishes using Berrymans-12. BUT it will definitely F**K up your paint. My garage is a small one car and i accidentally got a bit of spray on my 360 wheels and it left some indellible ugly spots. probably would do bad things to any other paint as well. Be carefull, have good ventillation. I particularly like the bit of advice on doing one carb at a time. The linkage pieces can be a real PITA if you have all off and you get the sequence wrong. I talked to Mike at Pierce manifolds and he strongly recomnmended replacing the throttle shaft bearings with sealed units. I filed off the split throttle plate screws - Keep the throttle plates in their orriginal location and orrientation. Take the time to make them light tight. This involves a lot of fussing with moving the plates just a tiny bit and tightening the screws carefully. If there is too much daylight around the plates, you will have a tough time syncing the carbs. To stake the screws, i installed a long phillips #2 bit in the vise Tightly and carefully lowered the carb down over the bit so the tip was firmly seated in the new screw head, then used a SHARP metal chisel to Stake the screw. The back up is particularly important, so you don't bend/bind the throttle shaft. A second pair of hands would help hold things steady. hth, chris
Thanks for the advice, I'll take a look at them when I pulle them, to see if they're that bad, if so, I'll replace them as you did. On another note: What did you use for "Torque Specs?" Both on assembly of the carb (during rebuilding) and installation. Thanks, Chris! Chris.
Chris, Sealed bearings are definitely a good thing. Air may seep past the regular bearings if not properly greased. Several things to take under consideration though before disassembly IMHO. What do the throttle bearings look like once you have soaked the carb. Make sure all the screws/bolts are out, accelerator pump diaphragm and top cover off also prior to the soak. Once you see what kind of shape the bearings [the ball bearings/race] are in and the throttle shaft moves smoothly as it did on mine, then just repack it with good quality bearing grease. Push the grease into the bearing and turn the throttle shaft back and forth, and repack again till a fair amount has been accepted, then reassemble. Once this is done, air wil not get past those bearings. Shoot carb. cleaner or even lacquer thinner to really clean things out into all the passages, then blow it out with compressed air. If the bearings look shot, and the action is not smooth, then I would replace the bearings and only then. Messing with those screws, throttle shaft, and throttle plates was not worth the hassle since everything looked fine in my case. Pay attention to the jets, since my replacements were all wrong [wrong sizes and one was incorrectly milled]. I kept and reinstalled my originals. I kept and cleaned the fuel filters since it was all metal, not like the plastic replacements in the kits. Make sure you take out and clean the the metal mesh screen found on the bottom of the cold start unit. I left the fuel inlet to the top cover alone, no leakage there and the fuel filter cover will need to be loosened with the carb on the engine since its has a significant torque on it. Once the carb. is finished slide it over the mounting studs and torque[the fuel filter cover] it down by hand till it's tight. All other bolts can be tightened by hand, should not be a problem. Once finished, have someone start the car [fire extinguisher handy of course] and check for leaks, then tighten as needed. Ciao, George
One again, you've given me more good advice, I wouldn't have thought to save the metal screens! Thank you, ' Chris.
Well Boys, I just got a nice little surprise when I opened up my first carb., the bowl was absolutely spotless and clean. I would have thought that I would have had all kinds of junk in there resembling sawdust from the gas deposits. The only thing I did notice is that the fuel float was discolored. It could possibly clean its self with new gas over time; maybe its not a big deal. Ive included a few photos of what my carbs looked like prior to my disassembling. I also noted that the carbs (bodies) themselves seem to be of a O.E. cad/zinc-yellowish/greenish color rather than what others have mentioned the raw aluminum color. Let me know of your thoughts. Thank you very much Guys, Chris. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Chris, Sometimes, you just get lucky. Maybe you should've just serviced them in situ, and saved all the trouble of removing them for a later date? I definately agree with George; you can do more harm than good by messing with the throttle shafts. Chrismorse, That's a very good tip on staking the butterfly screws, should removing them be required. An easy way to get the plates centered in both bores, is to tap the shaft back & forth with the screws barely snug. I've had good results, wasting a minimum amount of time with that method.
Robert, Those pictures from Carl Jones are pretty impressive, but I don't trust myself to not get the components mixed up between the assemblies; I like everything to go back in the same spot it originally came from (common screws being the exception, but you know what I mean). Lots of good links; in one (1) post, you outdid all the rest of us
