Quick Jack Lift | Page 6 | FerrariChat
Quick Jack Lift
Discussion in '360/430' started by whatheheck, May 11, 2018.
  1. neil e dale
    neil e dale Formula Junior
    367
    Tucson AZ
    neil e dale
    up to you ! to measure and sink a few anchors in concrete is pretty easy stuff! easier than working on a Ferrari! many 4 post aren't even anchored ! they are movable! but i can understand the caution exercised by hiring a pro to do it whilst later standing under a few thousand pounds! LOL
  2. Glassman
    Glassman F1 World Champ
    If I was going to do the two post I would drill all the way thru the concrete slab and epoxy the bolts in place.
    greg328 and neil e dale like this.
  3. neil e dale
    367
    Tucson AZ
    neil e dale
    yes, sadly true, not available in the backwaters of the Sonoran desert ! ( not that we have much water either ! ) LOL
  4. griffith500
    griffith500 Karting
    62
    NJ
    Tom
    Dbone, Neilg, whatheheck and 3 others like this.
  5. Glassman
    I bought one and got it operational last weekend. I like it a lot but on a 308 if you position the ramps with the warning stickers to the front of the car it is very unstable. So I flipped them around and was able to get better lift points and it is very stable lifting that way.
    greg328 and I'm 360 Canuck like this.
  6. Dicecal
    Dicecal Formula 3
    1,851
    Phoenix, AZ
    Rob
    Just got one from Costco too, will use it on my 430. 8” ceilings in my garage, wish I could do a 4 post!
    greg328 likes this.
  7. Glassman
    8" ceilings is going to be a problem!!!!!!!!:)
    neil e dale likes this.
  8. FrankForrest
    FrankForrest Rookie
    Nov 12, 2016
    49
    Pacific Northwest
    Glen
    I just got one from Costco too. Merry Christmas to me.
    whatheheck likes this.
  9. newbwrx
    newbwrx Karting
    Feb 3, 2007
    150
    PNW
    I bought one from Cosco last month, before leaving on vacation. Oil changes and car detailing will never be the same. :)
  10. neil e dale
    367
    Tucson AZ
    neil e dale
    I just ordered one !
  11. cfensty
    cfensty Formula 3
    1,094
    South Carolina
    I bought a 7000 model direct from QJ so I can use for all of my vehicles including Jeep GC SRT. Can’t wait to get it set up!
  12. neil e dale
    367
    Tucson AZ
    neil e dale
    just saw quick jack slip on track extender so we can use our model 5000 for longer cars if we need want to ! ?? Image Unavailable, Please Login
    SLX Frame Extension Kit
    $195
    IN STOCK NOW!
    • Set of 2 Extensions
    • Adds 6" length to SLX frames
    • Fits 5000SLX & 7000SLX
    • Easy to carry
  13. Lotaz
    Lotaz Formula 3
    Nov 18, 2016
    1,537
    Las Vegas
    Scott
    I have a 3500 I use with my Lotus, I love it.
  14. Neilg
    Neilg Karting
    Feb 16, 2001
    241
    Accokeek, Md.
    Neil Green
    Thanks for the great post - I just ordered one from Costco as sale ends today 12/16 - $999 after $100 discount with tax came to $1,054.99.....can’t wait to get it for the 360!
  15. BlacktopRacing
    BlacktopRacing Formula Junior
    996
    Pittsburgh
    Dale
    I picked up the 5000 SLX about a month ago from Summit Racing while they had their 10% off any purchase over $150, so it ended up costing me $1005 delivered. I don't think it matters which way the lifts are facing, as I've had my F430 all the way up facing both ways.
    I'm 360 Canuck, neil e dale and HH11 like this.
  16. neil e dale
    367
    Tucson AZ
    neil e dale
    I am having a garage built and plan to have a old -fashoined pit in one of the bays so that w/ these quick jack lifts and we should be set for most any repair! and we will have a offset arm lift in the other bay someday !
  17. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,210
    Shorewood, MN
    Kevin
    I recently received my QuickJack from Costco, and gave it a try last week with my 360.
    I highly recommend placing the tracks with the sticker parts towards the REAR of the car. I initially set up the system the other way, and it was not stable, utilizing the car's jack points. The fronts of the tracks were actually lifting off the ground due to the weight imbalance. Switched them around, and it worked perfectly.
    I'm still having issues with the air cylinder. I have a screw-on type air compressor. I fill the cylinder up to 50 or 55psi. The cylinder then loses air as I unscrew it as fast as I can! By the time I'm done, I'm left with only around 25psi per cylinder. Is there anything I can do, short of buying a different air compressor??
    Thanks!
    Kevin
  18. Glassman
    Yes......stickers forward is scary unbalanced. I would get a fitting for your compressor so you can use a regular air attachment. I can get mine loaded to 50psi easily, but I am trying to find a couple of small diameter gauges that will fit on the air cylinder so I can easily see what PSI I have.
    kes7u likes this.
  19. cpep
    cpep Formula Junior
    437
    new york
    CHARLIE
    kes7u likes this.
  20. Mimmo Blue
    Mimmo Blue Formula Junior
    Apr 17, 2018
    324
    Stoney Creek, Ontario, Canada
    Dom
    I used a tire inflater fitting to fill my air cylinder. I had mine stickers facing forward and had no stability issues with my 360. The rubber pads should be evenly spaced on the lift as well front to back. With stickers facing forward and the lift down flat on the floor it was positioned forward so that the front most part of the lift with the stickers was only about an inch or less away from touching the front tire.
  21. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,210
    Shorewood, MN
    Kevin
    Thank you both! Not sure why I never thought of an attachment. I will look that up right now....
    Kevin
  22. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,210
    Shorewood, MN
    Kevin
    WOW!! I can't believe this worked for you. The further forward the lift is placed, the more of the weight of the car is hanging off the back. I didn't even have mine this far forward, and the fronts were lifting well off the ground. Although this worked for you, I would still highly recommend placing them the other way, as it is a more stable configuration for this car.
    Kevin
  23. Mimmo Blue
    Apr 17, 2018
    324
    Dom
    #148 Mimmo Blue, Dec 24, 2018
    My understanding is that the centre point of weight on the car is at the rear lift point. I have read that if you put a regular jack under the car you can lift the entire side form the one rear lift point
    Here is a short video using the Quick Jack the first time on my car . You will hear the unit whine and seem to struggle That occurred because I had forgotten to open the air valve on the hydrolic tank. I've since put a big sticker on the unit to remind me to open the valve when in use. When not in use I close the valve to make sure the tranny fluid does not absorb moisture .
    greg328 and DefunctNeurons like this.
  24. cpep
    cpep Formula Junior
    437
    new york
    CHARLIE
    I have mine the opposite of that. My car goes towards the rear when lifting. Never had a problem. You use brake fluid in your system?
    kes7u likes this.
  25. Glassman
    I set the rubber block right at the rear factory lift point on my 308. When lifted I pushed down on the rear bumper and the sticker end to the front lifted about an inch off the floor. I thought I was going to have a bad day. I won't ever do that again!!!!!
