Quick question: does the F512M have dual or single rear coilovers? | FerrariChat
Discussion in 'Boxers/TR/M' started by SSNISTR, Nov 26, 2014.
  1. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Curious? I know the Testsrossa did. Also is the ride height on a F512M adjustable?
    Thx.
  2. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    2 shocks per side on rear, I believe they are ride-height adjustable but not 100% sure.
  3. Llenroc
    Llenroc F1 Veteran
    5,495
    Colorado
    Vern
    Adjustable height only, no shock adjustment
  4. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    So single coilovers in front, dual coilovers in the rear. Adjustable for ride height too...
    Thanks fellers.
  5. JohnAbrams
    JohnAbrams Karting
    Nov 12, 2014
    87
    FL & NY
    If I recall...Testarossa not height adjustable, 512TR and F512M are height adjustable.
    There was suspension changes (during the Testarossa run I think) but as far as I remember they all have two coilovers per side on the rear.
  6. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,074
    LA
    Todd
    Do we know why Ferrari went with dual dampers for the rear?
  7. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,532
    romano schwabel
    it was not only a problem of the 2 dampers, more of the 2 springs and the heavy weight on the rear axle. same has been on the BB.
    I think it would be ok only 1 damper each side, but how you would put the spring in then?. so 2 dampers with springs makes sense
  8. Steve Magnusson
    26,806
    Because they copied Jaguar? ;)
    The downside to using a single coil-over damper at the rear is that the bottom end has to be attached above the rear axle so the whole package gets taller (although they made this work on 2X6/3X8 coachwork), and a single large coil spring has a lower self-resonance (and the steels used in coil springs of that era weren't like they are today so they tended to be much larger/massive things for the same spring rate - compare a 4" 308 spring to a modern 2.5" spring). Using the dual design was the known/straight-forward/low-risk path at the time.
  9. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    #9 Todd308TR, Jul 14, 2015
    Two good pictures to show this.
