Quick timing belt change question | FerrariChat
Discussion in '308/328' started by FasterIsBetter, Dec 16, 2009.
  1. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Will the cam lock for the 308 QV engine work for a timing belt change on a 328?
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    #2 miketuason, Dec 16, 2009
    Yes,QV and 328 are identical. What cam lock are you using or do have?
  3. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Mike,
    My friend Paul has one that we've used to do timing belts on his QV engine. Made of nylon if I recall correctly. That's why I was asking, since he has one that we have used successfully on his engine.
    Thanks,
    Steve
  4. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    Recently another Fchatter and I did his belts. We ditched any of the tools in place of using the rubber mounts from the AC compressor and a bolt. Simply put one rubber mount on the top of the two cam gears (they're triangular shaped and its intuitive as to which way to insert it between the cam gears), and the other on the bottom. Hold them together with a bolt and nut and you are done. Cheap, simple, and in stock if you have an AC compressor on your car.
  5. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    Do you have a pic you can post?
  6. DenisB
    DenisB Formula Junior
    Jul 21, 2007
    511
    Cape Cod Ma.
    Denis B.
  7. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    Why is everyone so paranoid about locking cam gears in place?
    On my 2V car, the only one that might move a little bit is the 5-8 Exhaust bank and I can't get the new belt on unless I slip it back in the right direction. Also, I checked and before I removed the old belts all the marks were lined up perfect so if I do put it on wrong, it will not line up and I now I'm off a tooth.
    Are the QV cars just more prone to moving around a bit?
  8. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    Should be less.
    Thanks for a good post. We tend to raise these engines/cars to religious levels when in fact, they're just hardware. Mark 'em, change the belts and put 'em back in service.
  9. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    It's helpful anytime you change a belt/chain on a car to put the engine at TDC first. That way, if something does move, you have a reference. However, much of the time this is not done and mechanics just remove the old belt/chain and put the new one on in the present position of the pulleys/gears position.
    Setting the tension on a cam belt is very important, of course, and it's worth noting that belt tension on any car with a mechanical tension device is set at the tightest portion of the belt travel. In other words, you rotate the engine and new belt to the point that has the least amount of deflection and adjust the tension at that point. If you adjust the tension at the loosest point, for example, you risk shearing teeth or, at minimum, wearing out the belt long before it's time.
  10. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    #10 mike996, Dec 17, 2009
    It's not about the valves and the tension it takes to open them. Belts/chains are not true and neither are pulleys. You could remove the valves completely and just spin the engine/belts/cams and you would see that at some point in the rotation the belt is tighter than other points in the rotation. If you tighten the tension at the belts loosest point, it then becomes too tight at it's tightest point. All belts, chains on any device are adjusted this way - you rotate to find the tightest position and adjust the tension. This includes fan belts, water pump belts, motorcycle drive chains, etc. Putting the tension on the loosest point just wears the belt/chain out faster and overly stresses the bearings involved.
    So basically, after installing a new belt/chain you rotate the parts, checking the deflection at the same spot in the run but every 1/8 turn or thereabouts. When you find the rotation point where there is the least deflection of the belt/chain at the adjustment measuring position, you set the tension to whatever deflection or other tension spec is applicable.
  11. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    I'm not so sure. If you set (lock) the tensioners at the least deflection, won't the belt become (excessively) loose at the point of the most deflection?
  12. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    #12 CliffBeer, Dec 17, 2009
    This works just fine - and, by way its function, can be used with very little lateral tension. Less than is used with tapered blocks and a bolt.
    As to belt tension, there is one designed-in tension spec which reflects the nature and physical properties of the drive system (chain or belt). It's a waste of time to get hung up on what point in the rotation there's more/less tension on the belt. Set it to the spec with the thing at TDC (or pick your own darn point) and be done with it.
  13. fgcfire8
    fgcfire8 Formula Junior
    Jan 19, 2008
    459
    Montpelier Va
    Frank Castelvecchi
    that looks like good way to hold em thanks as belt replace in due in 2010 for mine
  14. miketuason
    Feb 24, 2006
    15,810
    Cerritos, CA.
    #14 miketuason, Dec 17, 2009
  15. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Could you please elaborate on: "As to belt tension, there is one designed-in tension spec which reflects the nature and physical properties of the drive system (chain or belt)."
    Thank you.
  16. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    Yes.
    And you get erratic valve timing also with too loose of a belt.
    The valve spring pressure wants to accelerate the cam(s) forward in certain areas or rotation, just as the springs want to retard movement in other areas of rotation. Setting the tension with the belt at maximum deflection sets the tension at valve opening and keeps the cam from over running the crank during valve closing.
    Doug
  17. tuttebenne
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    #17 tuttebenne, Dec 18, 2009
    Next time the car is apart :)
    But actually, now that I have seen the C-clamp method, it is superior to what any of us are doing.
  18. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    #18 Brian Harper, Dec 19, 2009
    I'm guessing here, but it seems to me that on each cam of a DOHC 4 or 8 cyl. car you have four lobes (or lobe pairs for you QV guys). I'll speculate that they are evenly spaced across the circle, so one lobe every 90*. So if the cam is fully opening a valve it will probably stay put, but if it is on a ramp it will want to snap down that ramp until another lobe is stopped by its valve spring. So I would expect a maximum of 45* of rotation from valve springs. And I would expect that there are four areas of high tension (ramping open a valve) and four of low tension (valve spring pushing the cam along). It is probably very sine wave looking, depending on your cam profile. OK, so you have this tension sine wave operating on the belt from one cam and a nearly identical operation, at some phase offset also operating on the belt. I think the reality is that there are points where the cams are pushing the belt in the same direction, points where they are pushing in opposite directions. Depending on what side of the cams you are measuring tension on you will see the action of the valve springs tugging or pushing the belt unless you have landed in a valley between lobes or at the peak of a lobe. On the 2V apparently you are there at #1TDC on three cams.
    I've never tried it, but on a pushrod V8 where one cam is opening and closing everything can you easily turn it because all of the valve actions try to cancel each other out? I'll have to ask the muscle car guys I know. I'll bet the cam drive stress on a DOHC motor is under multiples more stress than a cam-in-block V8.
  19. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Yup, exactly right. And when the whole thing is rotating at 1,000 or 7,000 rpm the spring-loaded tensioner is doing a good job of ensuring the belt has a reasonably decent and consistent tension at roughly the designed spec such that slack and/or harmonic vibrations don't build up and cause the belt to skip a tooth or two.
  20. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    #20 FF8929, Dec 19, 2009
    I'm not trying to be picky but, to be precise, the tensioner (when in use) is not "spring loaded", as it is clamped down after adjustment. The spring only sets the original, static, tension on the belt, after that, the spring has no function. The idler/tensioner pulley rotates but its centerline never moves. It cannot control the tension variances.
    "RIFLEMAN": Imagine this: You're on a desert island, in combat conditions, with ONLY a metric socket set and, if you wish, a pry bar. How would you set the belt tension?
    (This should be very illuminating)
  21. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Of course, on these engines, there is no need to fool with determining the tight/loose point because the factory setup "automatically sets" the tension when following the service instructions.
  22. miketuason
    Feb 24, 2006
    15,810
    Cerritos, CA.
    Are you guys not relying on the belt tensioner anymore?
  23. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Fred, you're absolutely correct. I wasn't being clear. What you said - ie. the tensioner sets a spec tension regardless of where in the rotation the belt/camshafts are. Yes, at some points it'll be a little tighter, at some points looser, but overall, when the thing is turning 7,000 rpm the tension is in the spec range and does a good job of ensuring no skipped teeth. It's generally other things that cause belt failure (not tension) such as oil or road debris invasion, contamination, aged/deteriorated belts, seized cam bearings, overrevving, etc....
  24. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    I knew you knew, I just wasn't sure about others.
    Here's what scares me, do you tighten the tensioner at its max extension, its min extension or in beween the two? When I first got my 308 QV Mondial, I replaced the belts and tensioner pulleys. I set the tensioners at max extension. About a month later, a drive pulley outer bearing let go and 16 valves went with it! Maybe max extension is too much? This is why I want "Rifledriver" to address my (above) desert island, combat conditions, scenero.
  25. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Why not just follow the service manual - page B 40/41 of the 328 manual describes the procedure - by rotating the engine two full turns by hand with socket/breaker bar with the lock nut on the tensioner loose and then, keeping tension on the belts with the socket/breaker bar, tighten the tensioner nut. This automatically ensures that you have set the tension at the belt's tightest point.
    This is the way any belt/chain is tensioned, whether it is done completely manually or "semi-auromatically" as in this case.
