Quick timing question 1978 GTS | FerrariChat
Discussion in '308/328' started by mike hal, May 4, 2010.
  1. mike hal
    mike hal Rookie
    Jul 15, 2009
    21
    I am setting the timing on a completely stock US model carbed GTS. The manual says to connect the strobe light to #1 and #5. The cam covers and wires are both labeled 1-4 on both sides. So is this how they are numbered?
    ----- front of car -----
    [Cap] - 5 6 7 8
    [Cap] - 4 3 2 1
    ------- rear of car ------
    Next question: The 3+/- degrees ATDC specified in the manual -- should that be for BOTH 5 and 1? Or does 5 get set differently?
    Final question: I'm not seeing any marks on the flywheel. I'm looking through the long, thin slit on the rear-facing joint of bellhousing to block; I can see the teeth of the ring gear and what looks like part of the clutch; are the marks supposed to be on that thin bit of flywheel between there?
    Thanks,
  2. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    From the distributor side of the engine, there is a plate in front of the oil filter. Remove the bolts and remove the plate. That will expose the timing marks.
  3. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,030
    I don't know if this was designed in, or just worked out that way, but a great heads up to be at TDC #1 on the power stroke (as opposed to TDC on the exhaust stroke) is to look thru the oil fill cap, and you can see the 1-4 intake cam alignment mark. Comes in very handy if you remove a distributor.
    There are two groups of markings for the 2 distribs. they get set to their corresponding mark.
  4. Steve Magnusson
    26,822
    #4 Steve Magnusson, May 4, 2010
    Yes, that's correct.
    The 3 deg ATDC spec only applies if your R2 points are still present and working. If you only have the R1 points, you'd set both banks to 7 deg BTDC. There are two sets of marks on the flywheel -- one set will be labeled PM1-4 (for the 1-4 bank) and the other PM5-8 (for the 5-8 bank).
    Yes -- you'll wish your marks were as clear as these:
    but they typically look more like this (so Mechanics often add some corresponding paint, or nail polish, dabs to the pressure plate housing to be able to see them when running -- and maybe use different paint colors for 1-4 vs 5-8):
  5. Jdubbya
    Jdubbya The $10 Trillion Man
    43,203
    PNW
    Thanks for those pics Steve. I've been having issues with setting timing on my '78 also and this helps a lot!!
  6. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    But also remember, there are four diff. timing on the 308:
    1: front bank valve timing
    2: front bank ignition timing
    3: rear bank valve timing
    4: rear bank ignition timing
  7. BigTex
    79,380
    Houston, Texas
    Bubba
    #7 BigTex, May 5, 2010
  8. BigTex
    79,380
    Houston, Texas
    Bubba
    Well, yea, but the flywheel is for ignition!!
  9. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Well, yea, but you do need the flywheel for valve timing too, since you have to be sure you are at TDC when you are playing around with the cam gears, belts, etc.
  10. miketuason
    Feb 24, 2006
    15,811
    Cerritos, CA.
    +1, You can't get an accurate/true ignition timing even if your valve timing is off by a tooth,
    which I think is about 4deg.
  11. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,850
    Atlanta
    John!
    Adding a little something to this regarding tdc. On my own engine I found that true tdc is about 1 degree to the right of what Ferrari has marked as tdc. I was running initial timing at about 12, when it was actually 11. Total timing wad at 38 when actual was 38. Food for thought.
  12. Jdubbya
    43,203
    PNW
    Right but in my case if the car was running, I pulled the distributors and am putting them back in.... the cam timing should not have changed. All I needed was a better picture of what it is I'm trying to decipher down in that little hole!
  13. BigTex
    79,380
    Houston, Texas
    Bubba
    Total is certainly more important than idle, unless you drive around REAL slow.....LOL!
  14. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    I will add that what helps me are not marks on the housing, which are helpful for seeing what's what while rotating the crank, but putting the paint or nail polish on the mark itself such as the AF7 mark really helps when using the timing light.
    And, yes, in a real (driven) car it's hard to make out that stuff.
