Quicker 328 steering rack? | FerrariChat
Discussion in 'Technical Q&A' started by GrigioGuy, Feb 27, 2004.
  1. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    32,612
    E ' ' '/ F
    Merritt Tockkrazy
    The steering rack on my 328 is just over 3 turns lock to lock. That works great on the road but I was hoping to get something a bit quicker. I looked in the archives, and it seems that Superperformance in the UK has a quick (2.5 turn) steering rack for 308s.
    Is that rack compatible with the 328? Has anyone tried it? Any 308 owners with it want to give a review?
  2. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Fitted one to a 308 just a few weeks ago. Makes a great improvement. Steering weight goes up considerably, so consider the pro's cons etc first.
    Can be fitted in about a day of labour if rack is otherwise healthy. If passenger side rack bush is worn, it takes an extra few hours to dismantle the rack casing to replace the bush (for a solid bronze/alloy instead of plastic).
  3. CarlH
    CarlH Karting
    Feb 5, 2004
    81
    MD
    Carl H.
    My passenger side bushing is very worn......Going to attempt a replacement at a minimum, or more likely a rebuild of rack. Any suggestions on sources for the bushings or rebuild kits?
    Thanks!
    Carl
  4. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Carl
    The stock bushing on PAX side is very small (maybe 3/8 inch tall if you lay it on its side) and made of a nylon or similar material. Unfortunately it wears quickly as you, me and others have found.
    In the archives there is a discussion of a (Honda?) part, I believe available from Norwood Performance that you can press fit into the housing.
    I had a 2 1/2 inch long bushing made, pressed in and then honed for a perfect fit by a machinist near by (I am in the Chicago area).
    In thinking about the rack otherwise, evaluate the wear in the center of the rack between the mid-section and the pinion. Typically this also wears, and while you can shim it tighter, you'll find it gets quite tight at the extremities if this is the wear pattern.
    On the original question, I'd guess they are the same (328 & 308 rack and housing) but you might shoot Mike at Superformance an email to see if he knows.
    On is it a good choice, this is a personal opinion. Personally, I find the accuracy and feedback through the stock rack is good. Sometimes it can be harsh (hitting a pot hole) with major kickback. This tendency will only be exaggerated with a faster rack. I track my car a lot and left it at the stock ratio, but as I said, it is personal choice.
    Philip
  5. nautique
    nautique Rookie
    Nov 1, 2003
    20
    Los angelas, CA
    Craig Tempelton
    Carl,
    The bushing is available from Norwood. I used it and it works great. The Honda part is a seal for where the steering shaft enters the rack. It works great also.
    There is nothing else to rebuild. Just add oil and boots and your ready to go. Don't lose the shims when you take off the access panels
  6. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,673
    Pittsburgh, PA
    Matt F
    Is there any room for steering quickeners to be used in 308s?
    These are used in reverse for landspeed racing, in order to slow down the steering when travelling at triple digits. They increase (or decrease) the ratio by 1.5 or 2.0.
    --Matt
  7. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    You could probably make room for the quickener, but it would involve some surgery.
    For track use, a quick rack is probably not worth a lot as steering wheel movement is generally quite small, but for road/rally use, where you may be going round numerous hairpins, and perhaps sliding more etc, the quick rack is invaluable.
