355 - Quickjack on 355 | Page 5 | FerrariChat
355 Quickjack on 355
Discussion in '348/355' started by C'dwic, Oct 10, 2023.
  1. Qavion
    Qavion F1 World Champ
    14,681
    Ian Riddell
    It was the only option I had in my current (tiny) garage. I have only had limited use of it (and then only after I created some short wooden ramps to get the car high enough)
    I recall only having an issue with tyre interference when the jack has been put in backwards. i.e. with the ram pointing away from the engine. The smaller Quickjack would have been a better fit, but someone on the forum recommended the 5000 because of the reason explained earlier.
    (EDIT: I think my tyres might be a few mm smaller than OEM, creating less ground clearance, so perhaps that is a contributing factor)
  2. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    I dont remember all the details but you basically place it so it clears the front tire when lifting. The rubber blocks fall into the green zones on the image above. The back ones sit on an angle snug to the underbody angle and they just it in the quick jack tray. I was able to remove the center section under panel no problem. I dropped the fuel pump and everything with no drama.
  3. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    The prior 5000 mode slx? Or something had a lot more adjustability in the trays for the blocks.. the 355 lifting points are very close together. Thats why theTL model is harder to work with since the trays are shorter but wider apart. Still it works and ill take the extra couple inches of lift.
    C'dwic and Qavion like this.
  4. C'dwic
    C'dwic Formula Junior
    Apr 23, 2021
    493
    France
    There is a 2 cm difference in length between the 5000 and the 7000, let's not talk about the height, that works with ramps, could the 2 cm extra on the 7000 really annoy us?
  5. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    C'dwic likes this.
  6. C'dwic
    Apr 23, 2021
    493
    France
    There are 3cms more in width for the 7000, which can make it easier this time to choose the location of the rubbers…
    So 7000 or 5000 ?
  7. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    I can't say without getting it setup and checking. Earliest that will happen is probably a month away. Do you need 7000 for some reason? All i can say is 5000 works. I've done it numerous times. Sat lifted all last winter while i did a bunch of work.
  8. C'dwic
    Apr 23, 2021
    493
    France
    #108 C'dwic, Oct 15, 2023
    I have a GLA 250 e, and a G63 AMG, and I think car will be more and more heavy in the future so…
    Like everybody I don’t want to buy several QuickJacks for all different cars…
  9. Qavion
    14,681
    Ian Riddell
    There's another issue with the Quickjacks, too. If you don't put large enough rubber blocks on top of the trays, you can get interference with the sills
    (not my photo)
    Of course there are other general issues, such as feeding the hydraulic hoses under the car and to the rams. If you mess this up, you can crush the hoses.
    ShineKen and C'dwic like this.
  10. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    Try this hopefully clearer photo. Image Unavailable, Please Login By some Christmas miracle i have this photo. Just happens to have blocks and their orientation shown. Now i recall. When the jack is far enough back to clear the front tire. The back block is all the way forward on the back tray and sits on the angle. I can't stress enough it "just" works barely.
  11. C'dwic
    Apr 23, 2021
    493
    France
    Is this where you install your quickjacks? and you say that it is extremely difficult to have a convincing result?
  12. C'dwic
    Apr 23, 2021
    493
    France
  13. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
  14. C'dwic
    Apr 23, 2021
    493
    France
    For the story of the choice of the Quickjack, I ordered the 7000, if it is to be bored with the front wheel whether with the 5000 or the 7000, you might as well install the Quickjack transversely and go with the most powerful…
  15. Qavion
    14,681
    Ian Riddell
    Don't tell us we didn't warn you :D
    By the way, I see that the 7000 jacks weigh 46 kilos. I thought the 5000 was heavy at 35 kilos. They have wheels, but you wouldn't say they were easy to move or "portable".
    Let us know how you go, especially with oil changes and wheel removals (and if you need small ramps to get the car high enough). As mentioned before, the rubber blocks have to be high enough to clear the bodywork
  16. C'dwic
    Apr 23, 2021
    493
    France
    Works perfectly, the only thing is to be careful point anchor.
    Take there where is green.
    I use ramps dismantled… to make it easier
    Model is 7000 TL
    Qavion likes this.
  17. Qavion
    14,681
    Ian Riddell
    Did you have any problems getting the car to go up the rear ramp? Or is your photo showing the ramp after you dismantled and removed the sloping section?
  18. C'dwic
    Apr 23, 2021
    493
    France
    yes that's it, I dismantled the inclined part to pass the Quickjack aside more easily
    I still forgot to pay attention to the left rear anchor point, you have a hose that crosses the place of the anchor bridge, be careful not to crush it
    Qavion likes this.
  19. Qavion
    14,681
    Ian Riddell
    So is this before you jacked up the car? And after the quickjack was placed under the car, did you refit the ramp? i.e. Is the quickjack completely inboard of the ramps?
  20. C'dwic
    Apr 23, 2021
    493
    France
    I install the car on the ramps, so it is raised by 7 cm. Then I dismantled the tilting part of the ramps at the rear to slide the Quickjack ramps from the side. I use a skate that is flush with the ramp, another block and a hockey puck. It is not possible to crush the flat bottoms like this
    ShineKen and Qavion like this.
  21. Qavion
    14,681
    Ian Riddell
    Thanks...of course.
    Sorry.. early morning here.. Haven't had my coffee yet.
    The ramps look like the perfect size. I have some wooden ones about that size, but you can't dismantle them. I also have some huge 3 part ramps which I have trouble getting the car onto (even though the slope is relatively shallow).
    C'dwic likes this.
  22. C'dwic
    Apr 23, 2021
    493
    France
    No problem Qavion and thanks for all advises you gave me before. That helped me a lot in the choice of Quickjack
  23. ShineKen
    ShineKen Two Time F1 World Champ
    20,202
    Southern California
    Nostradamus
    Now we need to know if an engine out can be done :).
    C'dwic likes this.
