355 - Quickjack on 355 | Page 7 | FerrariChat
355 Quickjack on 355
Discussion in '348/355' started by C'dwic, Oct 10, 2023.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,202
    Southern California
    Nostradamus
    HF = Harbor Freight?
    F355Berlinetta likes this.
  2. ShineKen
    20,202
    Southern California
    Nostradamus
    Might have to move some weight off the system if the hydraulic lift is borderline at capacity: Brakes, suspension arms, dampers, clutch pumpkin, etc… good time to refresh bushings :)
  3. ShineKen
    20,202
    Southern California
    Nostradamus
    Is the engine back in?
  4. ShineKen
    20,202
    Southern California
    Nostradamus
    F355Berlinetta and Qavion like this.
  5. Qavion
    Qavion F1 World Champ
    14,672
    Ian Riddell
  6. Qavion
    14,672
    Ian Riddell
    I meant in the double piston "OMER" brand.
    I wonder what the minimum height is (of the KATOOL brand lift).
    Looking at the review, it's not plug and play.
  7. F355Berlinetta
    F355Berlinetta Formula Junior
    Yes the engine is back in. It took forever to get the sub-frame bolts aligned, but its back in and now I have to connect hoses and wiring.
    ShineKen likes this.
  8. ShineKen
    20,202
    Southern California
    Nostradamus
    Million dollar question … would you do it the same way again with the Quickjack?
  9. F355Berlinetta
    Great question. Since I now have a set of Quickjacks, yes I would use them again. I had issues with the Quickjacks lowering unevenly and had to fiddle around more than expected, but this was the only problem...a few extra inches of lift would have been nice too. If you have used the old 2 jack method for engine-out service in the past and are looking for an upgrade, I would bypass Quickjacks for a better lift.
    ShineKen and Qavion like this.
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
    Eventually, you get the tricks and it is faster.
  11. ShineKen
    20,202
    Southern California
    Nostradamus
    Lowering of Quickjack was the issue I envisioned. How confident are you the frame is bolted up square with the car at this point?
