348 - QuickJack | Page 2 | FerrariChat
348 QuickJack
Discussion in '348/355' started by Fguy, Mar 9, 2023.
  1. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
    I have a MaxJax and it's been awesome to have. It takes 15 minutes to setup and it goes high enough to drop the motor onto a cart for an engine out. It takes up a small area when not in use and just needs a 4" thick concrete pad.
    steved033 likes this.
  2. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Weird. I have to raise my 348SS slightly to get a Quickjack under there. But it works and I definitely use jack stands. Once you witness a jack failing, any jack, you will be convinced.
    26street and Qavion like this.
  3. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    20-30 min to set up? Should be called the Slow Jack
  4. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,479
    Atlanta, GA
    Steve D.
    I just did my car yesterday...5 mins to lifted from pulling the car in. I had to adjust an exhaust donut.
    sjd
  5. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    It's slow to setup due to car being really low and at lease in my experience the newer model has a very small success envelope for placement. That and you really should get it nice and square. It ends up being a lot of laying with your head on the ground getting it in place.. then up and over to the other side to do it again.. get a tape measure in place to verify and then back to the other side to move it a smidge back n forth.. 20 minutes later and 10 times back n forth you got it and you're beat from the up and down workout. On any normal height vehicle it would be 5 minutes.. and if you had a helper and 2 tape measures (one front one back) it may even be quicker.
    Like I said.. if you make a jig or sorts to make the positioning quickly repeatable it could be done in about a minute.
  6. Fguy
    Fguy Karting
    Oct 4, 2011
    69
    Sarasota, Fl
    Julian Angus
    Thank you. Costco has the new improved version for $1,500.
  7. Fguy
    Fguy Karting
    Oct 4, 2011
    69
    Sarasota, Fl
    Julian Angus
    Great picture. Good help. Thank
  8. seabass23
    seabass23 Karting
    Nov 6, 2016
    158
    St Albert, Alberta
    Matt
    Here's one more data point for all those considering the use of a Quickjack for their major service.
    I just used the 5000TL for my first major on my 348 and.....IT WORKED WELL.
    There is lots of clearance for pulling out the engine using your standard furniture dollies. You still have to rotate the engine to clear the shock towers but no big deal.
    A few notes. A smooth/clean garage floor will make your life easier since it will be so much easier to position the engine. Those dolly wheels rolled very poorly on my weathered Canadian concrete. Next time, I will upgrade the dollies to higher quality and slightly larger wheels. I pulled the engine by myself but putting it back took some help because positioning is tricky (the car moves backward as the jack lowers). Consider painting alignment marks for the dolly wheels on the floor when you first take the engine out (it will save you time on the reinstall).
  9. PaulK
    PaulK F1 Rookie
    4,814
    Michigan
    Paul
    This is great news for me, even though I have a F355. What kind of furniture dollies did you use? Do you have any pictures that show how much clearance you had?
  10. mr.windupbird
    mr.windupbird Rookie
    27
    San Diego, CA
    Having done an engine out with a quickjack, do you think it was a good purchase? I’m thinking about doing my own engine out services and was curious if it’s equivalent to using a traditional lift. I also noticed that they’re on sale on their website right now. So I would like to take advantage of that if I can.
  11. ShineKen
    ShineKen Two Time F1 World Champ
    20,162
    Southern California
    Nostradamus
    Getting it out is one thing. Getting it back in is another. Was discussed in other quickjack thread.
  12. seabass23
    seabass23 Karting
    Nov 6, 2016
    158
    St Albert, Alberta
    Matt
    I used a pair of these carpeted dollies. These are from the Canadian equivalent of Harbor Freight. They worked ok but rolled poorly on my floor. As I said in my post, next time I would upgrade the wheels to something slightly bigger for easier travel. I would probably also link the two dollies together.
    I don't have a picture but I can tell you that there was several inches to spare once I rotated the engine 90°.
    The 355 could be slightly different but you can use the same "emergency plan" that I had ready if the clearance was tight: I would have used jack stands to support the body at the highest position, then dropped the Quickjacks down, inserted additional rubber jack pads, then lift again. This process would buy a couple more inches (but again, I wouldn't expect any problems).
    PaulK likes this.
  13. seabass23
    seabass23 Karting
    Nov 6, 2016
    158
    St Albert, Alberta
    Matt
    Not sure what post you refer to. Getting it in took some alignment effort, but nothing more. With the jacks down low, I marked the rough alignment position of the mounting points on the floor with a paint marker. I called my wife and son out to the garage and we wiggled the engine back and forth to align it, dropping the car one inch at a time. Eventually, the car and the engine mounting points aligned right above the paint marks. As the car dropped and moved backwards, we moved the engine backwards. I was sweating afterwards but never had any regrets about using the Quickjack.
    If you are referring to the other thread where a jack and custom cradle was used, then all I can say is that's another way to do it (but not the only way)!
    ShineKen likes this.
  14. seabass23
    seabass23 Karting
    Nov 6, 2016
    158
    St Albert, Alberta
    Matt
    Yes, I think it was an excellent purchase. I think that a traditional two-post lift would be better if you have the space. It would allow you to put the engine on a much taller structure (so you could save your back when working on it).
    I've used the QJ to get under my e39 M5 and my son's Focus. The worst part is getting the alignment figured out for the first time with each vehicle. I store them hanging up on the wall of my garage so they take almost no room when not in use. I also don't have room for any other fancier options. I think the proof is in the fact that this was the first time I took the engine out of ANY car.
  15. NepTunes9
    NepTunes9 Rookie
    38
    Carlsbad, CA
    Dave Barberree
    The 5000TL has now been replaced by the 6000TL. The tire spread for the the 6000TL is 70" or more, I measure 74" tire spread on a 355 so it should slide in between wheels.
    The lift point spread may be a challenge. I measure 32-36" at the jack points. The 6000TL has a 37" minimum lift point spread. I am thinking if you use the other jack point locations mentioned by Dave L. on the underbody instead of the jack points, it can still work (on a F355).
    I have a 6000TL arriving Thursday. I may be selling it for cheap on Friday.
  16. ShineKen
    20,162
    Southern California
    Nostradamus
  17. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,945
    Richmond
    Pete
    I went with one of these instead. Image Unavailable, Please Login
    Note the boards for clearance. The arms move a decent amount but I used regular jack stands to do the under tray before and after being on the lift.
  18. NepTunes9
    NepTunes9 Rookie
    38
    Carlsbad, CA
    Dave Barberree
    Is that a MaxJack? What underbody access do you have with a lift like that for annual maintenance or a major service?
  19. NepTunes9
    NepTunes9 Rookie
    38
    Carlsbad, CA
    Dave Barberree
    The lift operator (me) is the weak point in doing an engine-out today. Perhaps in a few years I will have built up those skills. I started with a full "annual service". It required a few lift point moves to drain radiators vs removing under body panels as one or another are blocked by lift arms
  20. INRange
    INRange F1 World Champ
    12,943
    Virginia/Florida/Caymans
    JD
    That is not a MaxJax by Bend Pak.
    I have both the MaxJax and the Quick Jack. The MaxJax is awesome if you have the space for it. It is a substantial car lift but at least mine is occupied with a restoration project. So I bought a Quick Jack to handle oil changes, tire, suspension and tune up work.
    The Quick Jack I learned takes some time to set up for a given car. I ended up with a 6000TL which is the only version that really works for the 355 and my wife's Porsche 718 Boxster. It takes a few times to get the block height right so that you can remove the under panels. Although......once you get it figured out......it isn't really a hassle.
    It also helps to do what @NepTunes9 did by doing a partial lift and putting wood blocks under the tires, lowering and then blocking the lift to the height you want.
    Anyway....I give the MaxJax 5 stars and the Quick Jack 4 1/2 stars.
  21. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,945
    Richmond
    Pete
    It's a portable 6k lbs mid rise scissor lift, bendpak makes one but I can't remember what brand this one is. I used my 4 post lift for my last major but this should make it easier, access is good to pretty much the whole engine underneath. I did motor mounts and exhaust on it, both were fairly easy. The nice thing is that it's easy to move around and has no anchors, unlike a 2 post. Between this and the 4 post I can tackle pretty much anything, though I do have a tendency to leave stuff half apart on the 4 post (my 400 is sitting on it sans engine right now).
    NepTunes9 and INRange like this.
  22. WATSON
    24,042
    WI
    INRange likes this.
  23. INRange
    12,943
    JD
    Yup.... A+ on the locations he used. The back lift points are key on the 355. If you use the factory lift points....the car is unstable and very tail heavy. He is 8-10" further back from the rear factory lift point which is still solid frame area.
    WATSON likes this.
  24. WATSON
    24,042
    WI
    Interesting and good to know.
    I never liked using the lift points with the u-channel, but reluctant to 'experiment'.
    Learn something new every day.
