quote box | FerrariChat
quote box
Discussion in 'Other Off Topic Forum' started by sparky p-51, Mar 23, 2005.
  1. sparky p-51
    sparky p-51 Formula 3
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    How do you open the gray quote box's when refering 2 a previous thread?
  2. Horsefly
    Horsefly F1 Veteran
    May 14, 2002
    6,929
    Click on the QUOTE icon at the bottom right hand corner of the posting that you wish to quote. You can also manually type in the following notation:
    [ QUOTE=sparky p-51 ] at the beginning of a quoted text and
    [ /QUOTE ] at the end of a quoted text to bring up the gray box.
    You actually type sparky p-51 or Horsefly or whoever you wish to quote.
    (Note that in the above manual examples, there is a space between the brackets and the words QUOTE. I had to type it that way or the software will make my explanation appear as a quote itself. Delete the spaces and the software makes the gray box appear.)
  3. Mario Gonzalez
    Mario Gonzalez Formula 3
    Apr 13, 2004
    1,333
    Out of my mind
    wow it works
  4. sparky p-51
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    lets see if it works...
  5. sparky p-51
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
  6. sparky p-51
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    If i dont want 2 recreate entire msg, let say just a part, how is that done? much thanks HORSEFLY.
  7. Aureus
    Aureus Formula 3
    Mar 8, 2004
    2,126
    Louisiana,California
    The {quote] command opens the "box" the {/quote] command closes the "box. You can type anything between quotes and it will show up normally.
    So if I only wanted to quote part of your statement I would do thus
    {quote=sparky p-51]If i dont want 2 recreate entire msg[/quote]
    where as if I wanted to quote the entire message I would
    {quote=sparky p-51]If i dont want 2 recreate entire msg, let say just a part, how is that done? much thanks HORSEFLY.[/quote]
    note the first { should be a [ to work.
    Other useful commands are highlighting the text and pressing ctrl+c on your keyboard to copy text and pressing ctrl+v to paste the copied text.
  8. sparky p-51
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    Thanks Areus. I dont have the angular ( sign ). Will use the entire quote for now. At least im half-way there.( Perhaps half-witted ).
