QV Cut Off Valve Direction Help? | FerrariChat
Discussion in '308/328' started by PhilB, Dec 14, 2009.
  1. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,315
    Southern New Jersey Shore
    Phil
    #1 PhilB, Dec 14, 2009
    This is a diagram/photo of the Air Injection system on a US Spec 308 QV.
    The Cut Off valve shown in the photo, is in-line between the air filter box, and the elbow hose that connects to the "Tee" that splits the air piping to the check valves that run into the exhaust manifolds.
    Not sure operationally if anything would have been wrong with the car if this valve was in backwards, but without a doubt, when I removed this valve from the car, to change the hoses, the arrow pointed TOWARDS the air filter box.
    This doesn't make sense to me. If the air filter box brings air into the system, then the air flow should be heading through this valve and into the "Tee". Therefore the arrow on the valve should point into the "Tee".
    Correct? Can anyone take a look at their car to verify.
    Thanks,
    Phil
  2. MBFerrari
    MBFerrari F1 Veteran
    Jul 2, 2008
    6,057
    NoVA
    Matt B
    Sorry Phil, but my system has almost been completely surgically removed from the car for lack of use and weight removal.
    Anyone else?
    MB
  3. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,315
    Phil
    I'm still pursuing this and am waiting for a call back from a local dealer service department. If/when I find out I'll post here.
    Phil
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,809
    Cerritos, CA.
    Phil, I just confirmed it with my QV. It's hard for me to take pic and show it to you but I've used a mirror and saw an arrow on the side of the valve and it's pointing towards the TEE, away from the engine, and toward the left side of the car. Does this help?
  5. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,315
    Phil
    Mike, thanks. It certainly confirms my suspicion/theory, that mine was installed backwards. Goes hand-in-hand with the four cam journals I found installed backwards during a recent service...so much for trusted dealer service.
    Phil
