QV EFI Intake | FerrariChat
QV EFI Intake
Discussion in '308/328' started by masonfamliy04, Jan 31, 2012.
  1. masonfamliy04
    masonfamliy04 Karting
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
  2. barnyard
    barnyard Karting
    Aug 25, 2009
    61
    PLEASE tell us all about this,really cool
  3. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Never mind that. I want to know more about the washer. :D
  4. masonfamliy04
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
  5. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Hey, no fair. You already have it installed.
    But anyways, looking good. (thumbs up) :)
  6. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    +1 that looks really neat & tidy.
  7. masonfamliy04
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
  8. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Bill on those AN fittings, what angle are they? 30d, 45d?
  9. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    I like it, but would have went for wrinkle paint instead of gloss.
  10. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Very cool front brakes.
    Who made the hats and caliper adaptors??
    IIRC, the 360 calipers have 38-42mm pistons, which is one step up fromthe standard 308 brembo big brake kit, (36-40mm).
    How are you adjusting for the relatively weaker rear brakes??
    When i put 360 wheels on my 308, i found the stock wheels to be 7.5 fronts & 10.5 rears. Can you tell us how you are doing the adaptation?? I agree that the 360 wheel is a good look on the 308.
    looking good !!
    chris
  11. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    That is a mean looking 914. What engine are you using??
    The rear frame looks like it will not flex much.
    Do you have a link to the 914 work??
    I had a 72 4 banger with s front brakes and 6 rear brakes, (identical to the 308 rear set up), and a 2.4 lightened engine with a front mazda cooler, big bars, Koni comp shocks. and 8 inch wheels with slicks - a real slot car.
    curious,
    chris
  12. masonfamliy04
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
    The AN fittings are 45* Let me know if you need any AN fitttings, a local speed shop was going out of business and I bought all of his aeroquipe fittings for penny's on the dollar.
    As for the front brakes, I got the hats and rotors from a fellow F chater. It took a lot of machining to make it all work. I'm using a tillman brake adjuster. I found the 360 front calipers on craigs list for $300.00
    I am using BBS 80mm wheel bolts in the front and 80mm in the back that press into a 1" wheel spacer. The spacer is bolted to the hub. To make room for the rims you have to use modern coil over shocks. I'm using QA-1 race shocks that I purchased on ebay for $230.00 I bought the (paper waits) from a fellow F-chatter to make it all work.
    The 914-6 has a 3.2 or a 3.8 turbo!
  13. 328turbo
    328turbo Formula Junior
    Jun 15, 2009
    306
    nyc
    Intake looks sweet
    Esp. The fuel rails and tbody.
    Are you gonna finish the cam & belt covers to match?
    I thought I saw a turbo behind the motor of the 914:)
    real nice projects.
  14. masonfamliy04
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
    Should I make the valve covers match the intake.
  15. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Nah, too much red. That being said I have seen natural aluminum with red highlights on the cover that looked pretty good. There are pictures of this somewhere on the site. If I can find them I will repost them or the link. Found it, the cover looks ceramic coated but you get my drift.
  16. masonfamliy04
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
    I realy like that, but after 8 years I just want to drive it!
  17. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    You asked. But I can't blame you. I start jonesing after a week, can't imagine 8 years.
  18. 328turbo
    Jun 15, 2009
    306
    nyc
    I have to respectfully disagree.
    Red covers to match the intake, and even red wiring looms would have a dramatic visual effect against the black paint. If the car were red, I'd likely agree with crowndog. But with the black, every time you open the lid, the red is gonna exaggerate the motor and attract your eye to the 'heart'.
    Your $$, your car, just throwing it out there.
    I can certainly understand your anxiety, tho!
  19. masonfamliy04
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
    What make spark plug wires are you guys using with the Electromotive?
  20. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Taylor 8MM Sprio Pro Series Part # 73255 - As per Electomotive, change the wires every 2 year (IIRC)
  21. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Have an unopened set if interested
  22. masonfamliy04
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
    Yes let me know how much you want. Do you still run plug extenders? Thanks Bill.
