Any updates and pictures?
Interesting difference between the US and the European version. We found this difference quite late. First picture = US version, second picture European or ROW version. A correct convertion from the US version to the European version is a quite demanding job. Image Unavailable, Please Login Image Unavailable, Please Login
Reproduction of the fuel tank straps. To create 100% correct straps we were building a special tool. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Test installation of the engine compartment panels Image Unavailable, Please Login Image Unavailable, Please Login
All panels where if necessary repaired and then primed and painted. According to factory pictures and the look of the installed panels the factory was painting the after the installation in the chassis. Image Unavailable, Please Login Image Unavailable, Please Login
Parts ready for the installation. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
No!! Nobody will be able to bear driving it more than hour with none at all... And totally forget having a woman in it for any amount of time.
We found on more spots surface corrosion on the chassis. If we would not remove all the skin and panels we would never be sure about its real condition. But I agree the refitting of the aluminium skin is a very demanding job. As I orientate only on the quality of the final result and I am not forced to be quick or cheap I took the decision to "undress" the chassis completely. The positive side effect is that we generate this way a lot of unique Countach experience and engineering data that we will use for the next projects.
A little late but the relayboard and fuseboxes look exactly like mine - 88.5 FI I could use one of those plastic fuse MTA fuse covers if someone has an extra...
Test fitting of the skirts. They were wrapped and we had to replace the lower part of the skirts. Image Unavailable, Please Login Image Unavailable, Please Login
Main fiberglass panel after paint removal and repair. Image Unavailable, Please Login Image Unavailable, Please Login
