QV Pistons, and Liners | FerrariChat
Discussion in '308/328' started by wilkrod, Dec 24, 2020.
  1. wilkrod
    wilkrod Karting
    248
    Ocala, Fl
    Hi all,
    So my 83 QV engine is completely striped down, so my question.
    Can I use the JE pistons #36226 which state "Bore-3.209" with steel liners 1st oversize which equals 3.2087"?' Or do I need the second oversize steel liner?
    I have never tried using after market pistons, so I am not sure what the specifications actually mean.
    Jeff
  2. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    What does your current bore measure?
  3. GordonC
    GordonC F1 Rookie
    4,166
    Calgary, AB, Canada
    Gordon
    Why steel liners - is there something wrong with the original Nikasil-coated aluminum liners?
  4. wilkrod
    wilkrod Karting
    248
    Ocala, Fl
    JE does not make high compression pistons in std bore size, hence the question of which bore size liner to go with their pistons.
  5. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,230
    Gold Coast, Aust.
    Patrick
    Mate, while you're in there, go as big as possible in bore size, and as high as possible in CR. I know that the CIS doesn't like wild cams, but I think high CR is OK - perhaps an expert can chime in here. Anyway, if you're going to put new pistons and liners in, you might as well get some free horsepower.
  6. wilkrod
    wilkrod Karting
    248
    Ocala, Fl
    I am using Jenvey ITB's with EFI, and ignition. Will sort out the cam situation once I figure out the piston/liner issue.
    My problem is I do not know how to spec. the correct piston o.d. with the correct liner i.d..
    Can anyone lend guidance?
