QV Rear Trunk Cover | FerrariChat
QV Rear Trunk Cover
Discussion in '308/328' started by Labman, Apr 10, 2017.
  1. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    My original trunk cover's zipper failed so I replaced it with a high quality aftermarket one. It has the upgraded zipper on it. My question is, when I enter it in a concours (FCA) will I get points off for it not being original? I'm not even sure you can get those OEM ones with the thin zippers that fail anymore.
  2. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    No one knows this? I'm sure many of you out there have entered your 308's in a concours. I just need to know if I have to now look for an OEM trunk cover with the weak zipper.
  3. Rifledriver
    37,178
    Without a picture how would anyone be able to give an answer?
    Don't be so impatient and post a photo so a real answer can be given.
  4. scudF1
    scudF1 F1 Rookie
    2,918
    Long Island, NY
    Billy
    Lol. Easy with the attitude.
  5. FrannyB
    FrannyB Formula Junior
    May 20, 2014
    293
    Arvada, CO
    I was having trouble with that original zipper too... I checked out a few YouTube videos on zipper repair and turns out that the driver had just separated a bit. I was able to use a pair of needle nose pliers and got it to work again. A little dry lube helps too. Maybe you can get the original to work?
    Franny
  6. Rifledriver
    37,178
    Good quality reproductions that look just like the originals are available. If a zipper lasts nearly 30 years it is very hard for me to criticize the quality. Typically the vinyl tears at the corners before the zipper becomes a problem.
    I have no idea what an "upgrade" is but I see no need.
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,815
    Cerritos, CA.
    #7 miketuason, Apr 11, 2017
    You're absolutely right Brian! My vinyl is original (33 years) and the zipper was replaced once five years ago and now the left corner is tearing. :(
  8. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    #8 Labman, Apr 11, 2017
    You are right. I should have posted pictures but figured all the replacements were the same. I got this from one of the Fchat members here. I forgot who and it came from Europe. The zipper is heavy duty and has these leather tassels on the end as shown. Brian I know you are a judge at the Cavallino Classic so I'm glad you saw this post. Would I lose points for this cover?
  9. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,611
    California SF bay area
    Paul
    I can't answer the question on concours but I took a girlfriend on a picnic last Sunday and my biggest worry was that I might end up looking like an idiot who couldn't get the chow out of the trunk of his Ferrari on account of a jammed zipper. :-/
    Fortunately that didn't happen but I might be interested in an upgrade or maybe a bit of graphite lube will help because it has been acting up on occasion.
  10. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    #10 i-velocita, Apr 11, 2017
    Looks like a nice replacement cover Steve but definitely not to original spec. I doubt a judge would ding you for it though.
    Things I notice at a glance are the leather zipper pulls, the arc shaped stitching around the latch openings, the border stitching around the latch openings, and the way the raw vinyl edges cover the zipper. Latch opening shape is also a bit more square than factory. Finally, there should be hard arc-shaped backer board reinforcement around the latch openings beneath the vinyl.
    A perfect reproduction cover is hard to make since the originals have two rows of genuine stitching on each side of the zipper PLUS two rows of embossed stitching.
    Again, wouldn't expect a judge to ding you for these small issues but I'm sure Brian will chime in with the final word.
    I happen to be aware of all the details because I obtained an original unmolested cover to use as a pattern for my covers.
  11. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    I got a point deducted for a small nick where one of the latches had been catching on the vinyl.
    That cover pictured looks very different from the original. I would be surprised if that doesnt get a deduction because there does not have been any effort made to reproduce the original as exactly as possible.
    Brian will know more but in my experience as an entrant, replacement non-Ferrari parts are fine as long as some effort has been made to produce accurate reproductions.
  12. 4re308
    4re308 F1 Rookie
    4,893
    Woodstock, GA
    Mitch D
    When I worked at Rutlands I was able to buy the last OEM factory rear trunk cover they had. Its correct with the blue lines on the inside of the material. I was lucky to get it because now they are not available. Those guys at Rutlands are concours judges and are extremely sharp and they did mention to me last year that they will deduct for a non-OEM trunk cover.
  13. Dr Tommy Cosgrove
    36,506
    Birmingham, AL
    Tommy
    You aren't there anymore?
    crap
  14. Rifledriver
    37,178
    #14 Rifledriver, Apr 12, 2017
    A deduction for sure. It is not a good fit.
    Whoever made the cover used a straight zipper and made it bend, or used one with the wrong curve radius. That is doomed to failure. On top of that on installation wrinkles were left in the cover buy not slightly stretching it in the correct places during installation.
    Many try and use heavy brass zippers made for Jeep doors with precurved zippers but the big heavy duty zippers just don't look good and the Jeep zippers are the wrong curve radius.
  15. Rifledriver
    37,178
    That may be but I have bought and installed several perfectly made aftermarket covers. I have one sitting in the trunk of my 328 now waiting for me to install it. I have also seen good upholstery shops make them beautifully for not a lot of money. Just because OEM is NLA is no reason to settle. OEM parts for 250 GTOs have not been available for a very long time and somehow it has not prevented them from being repaired.
  16. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    Thanks Brian. I guess I will have to change the cover. Can you let me know where you got your aftermarket cover? I will have to look into all options.
  17. FrannyB
    May 20, 2014
    293
    Arvada, CO
    I have kind of a dumb question: Is there a "correct" position to leave the two carriers? Would that be the center or both off to one side?
    Thanks,
    Franny
  18. Rifledriver
    37,178
    Brian Keegan got it for me some time ago. He is now with T Rutlands. Talk to him.
  19. Rifledriver
    37,178
    No.
  20. scudF1
    scudF1 F1 Rookie
    2,918
    Long Island, NY
    Billy
    It seams that we all will have to go thru with replacing them since they are notorious on failing.
  21. i-velocita
    2,520
    Colorado
    James
    Here is a bit of advice on finding a high quality replacement trunk cover. Confirm that the latch area reinforcements are waterproof backer board and either laser cut or die cut. Some less particular upholsterers will cut the reinforcement pieces with snips or other imprecise means. They aren't a perfect match to each other much less the factory pieces. Also, check that zipper is YKK or Dunlap brand. Lots of cheap import alternatives available today. Hope this helps!
  22. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,819
    Australia
    Mark R
    I leave my zip holders touching in the middle but I have OCD. :)
  23. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    Say I get it to fit better....still a deduction for wrong style? Before I replace it I just want to be sure I need to.
  24. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,236
    Gold Coast, Aust.
    Patrick
    I've always left them in the middle - seems the obvious spot. If they're to one side, it throws out the corner weights :)
  25. scudF1
    scudF1 F1 Rookie
    2,918
    Long Island, NY
    Billy
    I do the same thing. Always in the middle.
