QV shifter / transmission questions | FerrariChat
Discussion in '308/328' started by James in Denver, Mar 1, 2008.
  1. James in Denver
    James in Denver Formula 3
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    Ok, I took my car out earlier this week, and will take it out tomorrow (its going to be 70 degrees in Denver tomorrow!). I have some questions about the shifter and the transmission.
    1) I rest my right hand on the shift knob (almost like an armrest), especially when travelling on the highway or over longer distances at the same speed. I dont bear down, but it does put pressure on the shifter. Will this hurt the alignment of the shift linkage? Could this hurt the transmission itself or weaken the transmission mounts/motor mounts? I dont think it would hurt the trans, but I have heard its not good to do this in a front engined car.
    2) When I rest my hand on the shift knob, I can feel it move a bit if I let off of the gas or when i step on the gas. Is this normal? I've heard with front-engine cars, this can be a sign of weak mounts, but I'm not sure about a mid-engine car.
    Thanks for any feedback
    James in Denver
  2. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    James I don't know about #1,but #2 I get the same thing happening in my 85qv I think Its nothing to worry about,I remember in my 71 240z I would rest my hand on the shifter and would get the same feeling when I pressed on the gas and let off
  3. rtking
    rtking Formula Junior
    Mar 5, 2006
    703
    Huntington Beach, CA
    Bob King
    James,
    If you put any forward or revers pressure on the shifter (e.g. moving it forward and backwards within the shift gate), you are going to wear your synchros. It's also poor driving practice to rest your hand on the shifter. The Bondurant school chastized me for doing that. Hands are to be on the wheel at all times except for when you need to shift.
    Bob
  4. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,617
    Gates Mills, Ohio
    Jon
    I concur.
  5. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Not a good habit to get into. The shifter movement results from engine movement. Too much indicates engine mount issues. Plus, too much movement will tend to spill you beer.
  6. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    I fixed this problem by putting my scotch on the rocks in a sippy cup while driving. But I still don't rest on the shifter.
  7. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I believe that it wear out the shift forks, not the synchros. A bad deal in any case. And the shift forks are probably more expensive.
  8. jsa330
    jsa330 F1 World Champ
    10,059
    75225
    Scott
    I'm guilty of being a hand-on-shiftknob guy as well.
    It's a been change from my 330 2+2 with the direct, in-gearbox shifting mechanism and precise, snick-snick type action when warmed up, to the remote mechanism of the 308...it's obvious by feel that the gearbox is a ways from the lever, but I don't dislike it, just took a little getting used to.
    The gated shifter is a very neat feature. Like the 330, it's a pleasure to go through the gears when warmed up; the 308's second gear synchro is also much harder to beat.
  9. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,302
    Colorado
    Dave
    James,
    #1 is a no no. Two hands on the wheel.
    #2 some movement is normal. Too much indicates worn mounts, could make it harder to shift,
    Dave
  10. Andrew Bolton
    Andrew Bolton Karting
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    Help! I guess that I'm guilty too. I notice that in the mornings my second gear, and, to a lesser extent, my third gear, is a bit touchy until warmed up. In my driving practice: as I approach an intersection, I pull my shifter from its gear into neutral without using the clutch. Am I wearing out the synchronizers with that practice?
  11. irondogmike
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    today I took her out for an hour and I check the movement in the shifter and its rock solid no movement as I thought there was b4 so I'm happier and I kept both hands on the wheel
