QV Timing Belt Cam Locks | FerrariChat
Discussion in '308/328' started by marcro, Dec 6, 2012.
  1. marcro
    marcro Karting
    Oct 25, 2007
    68
    Canada
    Mark Cross
    Does anyone make a set of cam locks for doing the belt changes on a QV? Birdmans contact the last time I emailed him only had a set avialble for the 2V which has a wider space behind the cam gears and it wont work on my QV.
    I could make my own I guess out of wood but would really like a proper set for the tool box.
    Has anyone made up drawings for the wooden set if I have to go that route?
  2. tatcat
    tatcat F1 World Champ Owner Silver Subscribed
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    there really is much made about this simple object.
    i made mine from an old 3/8" thick teflon cutting board and a screw.
    just cut the board to the width of the gear and the distance between the two cams.
    one for the top, one for the bottom.
    hold a straight edge and mark where the screw will pass through then drill.
  3. Brian Harper
    Brian Harper F1 Rookie Owner Silver Subscribed
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Tatcat is right. No magic here. I took a scrap of wood and spent 15 seconds on the bandsaw to make a couple of wedges and used a wood screw to clamp them together.
  4. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
