R-134 LEAK F512M | FerrariChat
R-134 LEAK F512M
Discussion in 'Boxers/TR/M' started by HOU, Apr 29, 2015.
  1. HOU
    HOU Karting
    May 2, 2009
    89
    Houston, Texas
    John S
    slow but increasing Freon leak. where should I look first ? any experience with the dye to locate the leak ?
    thanks.............
    js
  2. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    If the previous tech put in the dye, go to any Pep Boys, Autozone etc. They sell a cheap light that illuminates the dye. Pull it into the garage, turn out the lights and start following the ac lines. I would start in the trunk area on the drivers side and work from there.
    But unless you have a vacuum kit, gauges etc. It might be worth it to take to an AC shop. The TR system isnt magic, they can quickly find the leak and fix it. Hopefully its an o ring.
  3. clinton
    clinton Rookie
    Feb 16, 2013
    39
    Houston
    The seal on the compressor.
  4. Turbopanzer
    Turbopanzer F1 World Champ
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    If you have a black light you can follow the dye( if installed) and trace the leak. If not I would recommend a A/C freon sniffer. It produce a signal beep until the leak is located then it produces a loud signal screech indicating the source of the leak. Costs some money, but highly accurate and work both when running or not.
  5. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,263
    Mel
    Treat her as any normal car .... :) -> get it to the AC expert next door !
  6. Rifledriver
    37,098
    A spray bottle with soapy water works quite well.
  7. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Reminder that R134 will pass through the walls of older R12 refrigerant lines (smaller molecules). Have you replaced the lines with barrier hose?
  8. Rifledriver
    37,098
    It has been a long time since I have done A/C work on an M so I don't remember but according to the book they came with 134.
    But we know how Italians are with hoses.
  9. Turbopanzer
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    footloose and fancy free? :D
  10. Rifledriver
    37,098
    More like low bidder crap.
  11. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Interesting.
  12. Turbopanzer
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    Agree. They never heard the word....silicone hoses!
  13. HOU
    HOU Karting
    May 2, 2009
    89
    Houston, Texas
    John S
    thanks everyone.
    the M came with r134. before i take it to a shop i am going to put in a can with dye and look for it with the black light.
    my experience with r134 domestic systems is most leaks are around the service fittings which are usually a simple fix
    js
