R12 freon | Page 2 | FerrariChat
R12 freon
Discussion in 'Technical Q&A' started by rumen1, Oct 29, 2025 at 2:17 PM.
  1. raemin
    raemin Formula 3
    Jan 16, 2007
    2,411
    Lyon (FR)
    R. Emin
    Dirtier than US is a far stretch... Europe is the only area in the world that has reduced significantly its emissions footprint since the Kyoto agreement.
    Like many I've bought a wood pellet boiler as we had to reduce gas imports from Russia. Works quite well actually. It's just like freon: if I am asked to refrain from using one type of commodities, and offered to use a substitute that works reasonably well at an afordable cost, I am fine with that.
    If we can afford our expensive toys, let's not pretend we cannot afford a proper AC shop that will recharge the car with a legal gas. Back then POE oil and r416 ended up at 250€, and the car was holding the charge 3 years later. Hydrocarbon is even cheaper.
    Does it really make sense to grab some illegal gas that has been stored in dubious rusty containers for the last 20 years? I would personnaly never refill my car with the ugly looking r12 cans that were spoted on ebay.
  2. Rifledriver
    37,350
    And what exactly is illegal about R12 being sold on Ebay? I buy and use R12 regularly and am in every way in compliance with all applicable laws.
    Alden, rumen1 and flash32 like this.
  3. raemin
    raemin Formula 3
    Jan 16, 2007
    2,411
    Lyon (FR)
    R. Emin
    The OP is based in Europe, so cannot source freon "legaly" (was still legal in Switzerland a few years ago, not even sure it still is).
    I would rather let a proper AC shop refill the car with a legal gas rather than refill the car on my own with a gas of dubious origin. Refilling on your own usually mean you do not have the tools to pull the vacuum, you cannot acurarely monitor the amount of gas filled in, no way to check the oil, etc...
    r12 cools better but if the refill is not properly done, it will work much worse than the legal stuff and may damage the AC in the long run (as the 40 years old oil cannot be replaced in this case).
    Professional service will work better regardless of the gas used.
  4. Rifledriver
    37,350
    Been doing it for 48 years professionally.
  5. moysiuan
    moysiuan F1 Rookie
    4,319
    Canada
    I redid my Mondial 3.2 with R134 many years ago. You have to flush the old system, put in a new compatible oil, change the hose O rings to the green ones, and it cools as well as it did with the R12. I added two extension hoses so I can test pressures and top up easily from the engine bay of the car. The downside is the old long rubber hoses from the engine to the front of the car will diffuse some of the coolant out, so after a year it needs a can of R134 to top up. The replacement of hoses with barrier hoses seems like a difficult project, there are no proper kits to do this and the routing of the hose with the fittings on looks problematic. I have no evidence of anyone having actually done a barrier hose replacement on a Mondial that would solve for the loss of coolant as noted. But that would be required for a gold standard conversion. Maybe the hoses on the Testarossa are easier to route and replace, so I can't speak to your specific model.
    The propane formulas (R12a) that can be used in the old R12 systems absolutely work without any modifications to the system and cool very well. The issue is a propane leak in a frontal collision where the condensor would likely be damaged, so I think it is not legal in the US. It is legal in Europe, Canada, etc.
    Our old 80's cars with body on frame actually have good frontal crash protection, albeit generally poor side impact protection. It would be a shame to get into a minor front end collision, only to have your car blow up. Probably a fluke low risk scenario, but as with anything low probability, that still statistically means it can/will happen.
    So after all the consideration, I accepted the r134 with an annual top up as my solution. Maybe some day I will set the barrier hose replacement precedent for my model.
  6. rumen1
    rumen1 Formula 3
    Jun 23, 2012
    1,853
    Bulgaria
    Well, I think today my problem has definitely been resolved. I remember about an old friend of mine, who was a refrigerator mechanic for many years and I called him. It turned out he has a brand new 7 kg bottle with brand new R12 freon in it, which I bought. So I'm pretty sure I can consider this matter done now :)
    Thanks everyone for your opinions. Keeping in mind what the hypocrites running the strongest econimies worldwide (and especially the clowns in the EU) are doing, I don't really think we should argue about some of us using some leftovers of R12 for our precious cars. ;)
  7. raemin
    raemin Formula 3
    Jan 16, 2007
    2,411
    Lyon (FR)
    R. Emin
    Are you planing to replace the dryer and check the oil volume? Checking the proper operation of the 40 years old expansion valve would also make sense.
    Rotary compressor and parrallel flow condensers are much more delicate than a piston compressor mated to a serpentine. You don't want such setup to swallow desicant from a failed dryer.
  8. rumen1
    rumen1 Formula 3
    Jun 23, 2012
    1,853
    Bulgaria
    I charged the system with R12 freon 3 years ago (then I found an A/C workshop, that still got some available) and it worked flawlessly since this autumn. Unfortunately my fuse for the cooling fans of the A/C radiator has blown for some reason, which I guess caused the system to overheat and the compressor blew the freon out. So that is my main problem. The system itself is absolutely OK , as it worked perfectly for 3 years. And I was advised especially to NOT replace the dryer filter if it works OK, which can be easily checked.
  9. where & how did they ship? Ebay pulled my freon add, after I sold 3 cans in one sale. I have a pile of it, including a 30 pound jug. Also shipping is terrible. I could not get the post office or UPS to ship it, ground.
