Radiant heat readings on a 355 after a drive | FerrariChat
Discussion in '348/355' started by Enzojr, Jul 8, 2015.
  1. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    So I went to Harbor Freight and bought a cheap $35 Centech Infared thermometer, felt my wheels one day after a drive and thought WTF ?
    Immediately after a drive got these readings:
    Wheels 125 and 135, all numbers in F degrees. 5 min later increase to 135 to 145 ?
    Top of both air boxes was 135.
    Top of coolant tank 175.
    Headers was mixed hard to hit all 8 pipes so will do it again but all between 250-380.
    I know these babies run hot, are these readings normal or are these excessive ?
    All gauge readings are normal, anybody else have a thought here ?
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,739
    Tires after coming off a race track:: 203dF
    Headers after coming off a race track:: 1100dF
    Water temperature on the last lap:: 228dF
    Oil temperature on the last lap:: 285dF
    Your readings are perfectly normal.
  3. Enzojr
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    Wow are those readings on a stock car, or a challenge/track car ?
    I will assume the oil and water readings are "gauge" readings ?
  4. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    I'd be interested to know if each cylinder is the same temperature. Can you measure each header right at the exhaust exit? I've been meaning to try that on my car.
  5. Enzojr
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    While running ?
    I will try that, I tried to slip that in after shutdown but was hitting different places on different pipes. Also thinking these cool off quick after shutdown.
    Did the right side after shutdown 250-380, then the left 280-300.
    But was checking other surfaces as I moved around the car, so will focus on exhaust next time.
  6. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Wouldn't a lean running cylinder run hotter than a healthy one? I'd think it would be a way to check the health of your engine.
  7. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    well I can say I have been working on my SDL.
    It does seem that Something is wrong with the system. My cats are outside temp right around operating temps so its not overheating. Im right in the 400f-500f range on them.
    But when I check the headers the RH side is showing me outside temps of 450 it is conciderably higher than the LH side.
    But you have the heat coming off the oil tank and the radiator fan blowing in that area so I am wondering if that reading is correct for the headers and not the ambient air temp in that area.
    With the Insulation and shields on the headers I think its very hard to get individual accurate readings with a IR temp gauge.
    I am going to smoke test mine and see what I find before I freak out or go any further on mine.
    I thought I had a Cat issue but I am not seeing abnormal temps with my cats.
    My temps were after a 20 Min drive and still running.
    My tool is not the one from harbor freight but I also don't know who made it off the top of my head.
  8. Mitch Alsup
    Nov 4, 2003
    9,739
    After running the proverbial snot out of the car for 25 minutes;
    and taking the temperatures without taking a slow-down lap immediately when stopped in the hot-pit area.
  9. Enzojr
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    So 20 mile drive tonight @ 84 degrees outside temp 9 pm.
    Drivers side front to rear
    650-800-560-475
    Pass side front to rear
    460-750-450-450
    It is seriously hot under the engine cover with the motor running.
    Numbers were jumping all over the place, drop or go up 50-100 and back and forth so not certain of the accuracy on these readings. Also the heat rolling and blowing around may affect the actual reading, will recheck next time out.
    Not to certain about the 2 nd one back on both sides the 800 and 750 readings.
    Fabspeed headers coated black, Nouvalari cats and pipe.
  10. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    That seems consistent with other threads that talk about the inside cylinders going bad sooner than the others with lower compression and worse leakdown numbers? Is this proving that the #2 and #7 cylinders run leaner than the others?
  11. Enzojr
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    I hope not ... Lol
    As mentioned the readings were all over the place and changing instantly.
    Thinking this is not accurate enough to determine much, thinking compression and leak down would produce something more accurate.
    I just turned over 33,000 miles.
  12. Rally guy
    Rally guy Rookie
    Aug 3, 2006
    36
    Toronto
    Robinson
    I too am seeing much higher exhaust header temps on the RH side, by about 100 degrees, topping out at 585 on a warm day, after shut down, and not a hard drive.
    Top of oil filter, 195 degrees.
    Maybe we should agree on a standard set of measuring points to be able to compare temps?
    Rk
  13. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    Sounds good.
    My Exhaust is completely stock so I have the heat shields and insulation still.
    Thats where I think we will have a hard time getting good readings.
  14. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    I did some readings today about 5 minutes after she came home and shut the car off. Fabspeed headers so possible to measure each one. I saw temps 50 degrees or more higher on the inside cylinders compared to the outer ones. It was only a quick check and I didn't write anything down or get real precise.
  15. Rally guy
    Rally guy Rookie
    Aug 3, 2006
    36
    Toronto
    Robinson
    If you've got the stock heatshields (I have the Ricambi rebuilds inside), perhaps the hollow between the front most and second exhaust outlet? I'll post a pic soon.
    I use the very top of the oil filter (for ease of aiming).
    Any other spots (or better than these) we can standardize on?
    RK
  16. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    You've got stock rebuilds with heat shields.....what temps are you getting across the heat shields?.....perhaps take 3 readings per side.
  17. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    #17 cf355, Jul 14, 2015
    for comparison, when I had the oem headers (with heat shields) I measured at 3 spots on the top of each header (evenly spaced) and my readings were between 500-575 degrees f per side....with the engine hot and running.
  18. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    and with unshielded but coated (2000 degree black coating) headers I consistently got 700-750 degree f on the individual header tubes per side......with the engine hot and running.
  19. MomentumWorx
    MomentumWorx Rookie
    Jul 14, 2015
    9
    It will be interesting to see different temperatures among different headers/cars/areas. Sub'd!
    I know numbers are going to vary depending on a multitude of factors, but maybe we can get a thread going comparing different headers and different styles of heat protection and their temperature readings?
  20. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    You think we're kidding when we tell you the 355 runs freaking hot?
    Heat management and dissipation should be the primary concern for any 355 owner. Your engine will last longer, I am sure.
    The good news is that goth is well aware of this and has made it his life's work to mitigate heat in the 355 engine bay.
