Radiator bleed procedure? | FerrariChat
Discussion in 'Technical Q&A' started by Dla, Mar 18, 2004.
  1. Dla
    Dla Karting
    108
    Jacksonville FL
    Lee Anderson
    I have a 88 328 and am in the process of reconnecting one of the heater cores. I have read several suggestions on the best way to 'bleed' the cooling system once I reconnect the heater core.
    Could anyone elaborate on the most efficient way? Can i just use the radiator bleed valve with the cap on the coolent tank and the heaters on, or do you suggest the thermostate 10 mm bleed as well?
    Thanks,
    Lee
  2. groovzilla
    groovzilla Karting
    Nov 28, 2003
    117
    seattle, wa.
    william
    eliminate having to unscrew and possibly loose or get burnt with hot coolant by removing the 10mm thermostate bolt..
    check the posts from a few days ago regarding this...
    good luck..
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    I used a pump from a radiator pressure test kit.
    1. Open the radiator bleeder screw, pump it until the coolant come out.
    2. Refill, close radiator bleed screw, pump it until it comes out the screw on to of the thermostat housing.
    3. Stop, tighten the screw, you are done.
    THe engine was never cranked on.
  4. DGS
    DGS Seven Time F1 World Champ
    74,043
    MidTN
    DGS
    I've also had good results with a "pressure bleed", as described by yelcab, above.
    But one caveat: Be sure you have the heater controls "open" (full hot), or you'll leave air trapped in the heater core.
    If you do the bleed cold, right after reassembly, you may need to repeat after the engine runs a bit, so the coolent flow can shake out any air bubbles lingering in the system.
    If you don't happen to have a radiator tester, you can improvise a bit. The cooling system doesn't take a whole lot of pressure. I've managed with a hand cranked air pump, a plastic bag, and a few rubber bands. ;)
  5. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    It's not my area of expertise, but wouldn't the thermostat being closed keep the coolant (or air) from properly flowing to the front radiator?
  6. yelcab
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    You are supposed to drill a 1/16 inch hole into the side frame of the thermostat before installation just for this purpose, you do know that, right?
