Radiator bleeder screw solution? | FerrariChat
Discussion in '308/328' started by timk1230, Nov 12, 2017.
  1. timk1230
    timk1230 Rookie
    Jul 6, 2009
    43
    Boca Raton Florida
  2. johnhunt
    johnhunt Formula Junior
    Aug 9, 2013
    343
    Washington
    John Hunt
    Looks interesting but I would keep the original screw in the tool bag just in case
  3. Pero
    Pero Formula Junior
    825
    Sweden
    Peter R
    Tried it in my GT4. Works, no problems detected. Not sure if the brand is the same, bought mine from England.
    /Peter
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    I'd just buy a new 50 cent crush washer. ;)
  5. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    I have one on my 308. Works fine, but hold on to your original...
    obertRo likes this.
  6. Skippr1999
    Skippr1999 F1 Rookie
    4,513
    I’m currently using the auto-bleeder in my 328. It works well.
    obertRo likes this.
  7. moysiuan
    moysiuan F1 Rookie
    4,187
    Canada
    Also using the auto bleeder on my Mondial 3.2, works fine.
    obertRo likes this.
  8. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I ordered an auto-bleeder for both the engine side, and the radiator.
    Engine side, works 100% great. Radiator - it didn't fit ... different threads. So I'm still using the stock part. But, it's not the fault of the vendor - I have an aftermarket radiator, and I guess the bleed screws are different. One day I'll figure out some brass adapter solution.
    Tip: If you ever have to pressure-test your coolant system for air leaks, don't forget to put the factory parts back on. You'll feel a moment of "oh... that was dumb" if you don't. ;)
    obertRo likes this.
  9. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    I'm thinking about installing one on the thermostat housing as some air gets trapped in there.
    obertRo likes this.
  10. Fiat4Fun
    Fiat4Fun Formula Junior
    Jul 1, 2008
    315
    Sunriver OR
    Bob
  11. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    If its necessary to constantly bleed air out, it must be getting in somewhere. Surely a constant throughput of air into and out of the system cant be a good thing long-term. It would be better to fix the issue.
    On a working system, on my 328 and also Lotus Esprit (exactly the same layout) a small amount of air does build up in the top of the rad after initial bleed but its a finite and small amount and doesnt keep increasing so can stay in there.
  12. SJP 5
    SJP 5 Karting
    Jun 7, 2015
    93
    There was a thread on here sometime ago about these bleeders or maybe Clubscuderia but in England these bleeders are commonly used on domestic central heating systems and were being offered for sale with an adaptor for the different thread by the poster at the time.I have bought one but have not fitted so am unable to pass any judgement at the present time but know they are cheaper to buy from a plumbers merchant directly.
  13. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    obertRo likes this.
  14. Skippr1999
    4,513
    I was waiting for this one.....
    There have been discussions on this topic in the past. It seems the 3x8 sucks air into the system through the overflow hose on shutoff. Some folks were mounting an extra fluid catch tank that would catch the fluid that gets burped out and thus suck that fluid back into the system rather than air. I pressurize the system every time I do a coolant flush and have no leaks. This is simply a phenomenon of the cars that the auto bleeder remedies.
  15. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,149
    SanFrancisco BayArea
    1983 US 308 GTS QV
    #15 Brian A, Nov 13, 2017
    I am no expert, so am writing this to confirm (or correct) my understanding of how the system works.
    The 3x8 expansion tank cap is an “vented” cap (e.g Stant 10231). As I understand it, this means that the cap vents gas or liquid through the cap when the pressure rises to the threshold pressure indicated on the cap (usually 0.9 or 1.1 bar).
    The volume and pressure of the coolant and air filling the top half of the coolant tank rises as the engine warms. First the air gets vented, then, if there is too much coolant in the expansion tank, the car pees coolant. The car naturally finds its equilibrium point which is the level of cold coolant in the expansion tank where the car no longer pees when hot. The Owner’s Manual says that this level is about 6 cm below the neck of the expansion tank.
    On the opposite side of the cycle, when the vehicle is shut off and engine cools, the expansion tank cap allows gas or liquid to reenter the expansion tank and equilibrate at atmospheric pressure (0 bar). There is no pressure in the system when the expansion tank cap is removed when the engine is cool.
    The consequence of this “vented” system is that air is purged as the engine heats and fresh air is ingested back into the expansion tank every time the engine cools. This means fresh corrosive CO2 is introduced every time and, I suspect, using a coolant with lots of corrosion inhibitors is important.
    When I first got my car, I had radiator air pocket neurosis and I bled out that small pocket of air all of the time. Eventually I realized the volume stayed constant (didn’t increase over time) and I stopped bleeding because it didn’t seem to matter; the 6 cm air space in the expansion tank seemed to be designed to accommodate the small air pocket in the radiator. If you watch the fluid flow with the expansion tank cap off while the engine is cold, you can see the turbulence in the expansion tank and it is easy to imagine how some air gets into the system and gets trapped in the radiator.
    Improper bleeding of the system when changing coolant is a whole different matter. The system will pee a huge amount of coolant. Personally, I have had no problem bleeding the air out of the system the 4 times now that I have changed the coolant and my system reaches an equilibrium (my car: coolant level is 6.5 cm below top of expansion tank). I don’t feel like I need an auto-bleeder.
    Again, this is all my understanding/interpretation of how the system works. Please correct me if I am wrong.
  16. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I had one on my GTB years ago. It's easy to understand how it works and for all purposes if it was required by the designers they would have put one in. But none the less they didn't and I used one. After the 1st couple of uses the system stabilized and this unit most likely wasn't needed. But no harm no foul so I left it on and never had a problem with air in the system or over heating.
    obertRo likes this.
  17. timk1230
    timk1230 Rookie
    Jul 6, 2009
    43
    Boca Raton Florida
    I ordered one from Clark and Clark speciality products. $30.00 including shipping. I had never heard of Clark and Clark as I usually order from aw Italian however I did not see a bleed screw on their web site so I thought I'd give Clark and Clark a try. I'll post how it worked out once I install it if anyone is interested. I will keep the original screw however not sure where I would find a crush washer that fits right. I struck out at lowes and Home Depot
    obertRo likes this.
  18. obertRo
    obertRo Formula Junior
    Dec 20, 2014
    343
    Holland, Michigan
    Robert Clark
    Clark & Clark is just me!
    I got my 308 QV a few years ago and love it! Like Verell, I like to design and make products. I'm hoping to make lots more good stuff. I'm working on a 308 cup holder now...
    My background is Mechanical Engineering. I work from a home office.
    Thanks to everyone who ordered--I appreciate the support!
    thorn likes this.
  19. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,149
    1983 US 308 GTS QV
    1 inexpensive Target clock
    + 1 inexpensive Clark & Clark shield
    = 1 very cool Ferrari garage clock.
    obertRo and thorn like this.
  20. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    You can go ahead and put me on the list of "people that will probably order this." Trying to grab that bottle of Gatorade I wedge behind the passenger seat gets old. ;)
    obertRo likes this.
