Radiator fans on '95 355 | FerrariChat
Discussion in 'Technical Q&A' started by RichardGilmore, Dec 30, 2003.
  1. RichardGilmore
    RichardGilmore Karting
    Nov 9, 2003
    57
    Atlanta, Ga.
    Richard Gilmore
    My right side fan comes on whenever the thermostat gets to I think about 200 but the left side never seems to come on. Should I be worried? How to diagnose?
  2. vref
    vref Karting
    Dec 18, 2003
    214
    1 Hr North of Housto
    Jim
    SD1 computer at a ferrari Dealer near you.
    Turn the airconditioning on and see if it comes on.
  3. Ferrari Fanatic
    Ferrari Fanatic Formula 3
    Apr 2, 2003
    1,317
    SoCal
    I had the same problem. It ended up being the thermoswitch. Each fan has a seperate one. The left side is supposed to come on first, then the right side.
  4. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,858
    The Cold North
    Tom
    theses fans are also bad for seizing.
  5. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,274
    Switzerland (NW)
    I think I have the same problem, frequent starts of the left fan. How much does the thermoswitch cost to replace ?
  6. Ferrari Fanatic
    Apr 2, 2003
    1,317
    SoCal
    I remeber it being right around $150. Realley easy to replace. The parts guy said he sold quite a few of them in the past. The right fan should come on at a higher temp or anytime the AC is on. The left fan should come on first (right around 185-190 degrees f.). The right fan should come on around 200 degrees F.
  7. Gregg Willhoit
    Nov 1, 2003
    42
    Houston, Texas
    Gregg Willhoit
    I've had the same problem twice. First time, it was the LH Radiator
    switch, 2nd time it was the LH Radiator fuse which is located in the
    passenger footwell fuse box. I live in Houston, and it is my opinion that
    the cooling system is a tad weak for this climate.
    Gregg
