Radiator Heat Dissipation | FerrariChat
Discussion in '308/328' started by online-racer, Apr 5, 2018.
  1. online-racer
    online-racer Rookie
    Dec 1, 2008
    16
    My '84 QV is getting a lot of heat from the radiator into the cabin. Does anyone know how heat was designed to be dissipated in these cars?
    Thank you
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,667
    South East
    Jimmie
    Thro the cabin by design ! Legendarily ovens altho the slats on later 308 bonnet helped - you might want to check the foam sealing above the radiator
  3. thorn
    thorn F1 Rookie Silver Subscribed
    Aug 7, 2012
    3,324
    Tallahassee, FL
    Make sure you have proper foam in place to seal the radiator. Also, make sure the heater + ducts are closed.
  4. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,811
    Cerritos, CA.
    This is pretty common for all 308, my 84 QV has the same issue, but I know there’s a fix for this, do a search.
  5. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    California SF bay area
    Paul
    There's a foam strip on the hood aft of the vent that seals off the tire well and there is a panel on the belly below the steering rack and battery. Make sure they are both there. Make sure the heater core valves are closing all the way.
  6. Ferraridoc
    Ferraridoc F1 World Champ Owner Silver Subscribed
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    There is a seal around where the AC duct punches up under the dash. It can perish, allowing hot air to blow out from under the dash - have a look. This is worse if the radiator seal isn't installed.
  7. craiggo
    craiggo Formula Junior Silver Subscribed
    Nov 9, 2012
    416
    Redwood City
    Craig
    Actually, the heat comes out of the vent rides up the hood and windshield and into the car. If you place your hand there while driving, you can feel it. My dad (engineer by trade) had my 328 for a few months and figured this out in detail. He made a plastic deflector that fits inside the front groove and it makes a world of difference inside the cabin. I thought he was BS'ing when he explained all this to me until I drove in it and tried it for myself. It's just enough deflector to push the hot air over the cabin altogether.
    Craig
  8. EP328
    EP328 Formula Junior Silver Subscribed
    Sep 3, 2008
    622
    Northern California
    Ed
    Please post a photo of the deflector.
  9. Jonny Law
    Jonny Law F1 Rookie Silver Subscribed
    May 6, 2008
    3,203
    Over yonder.
    IT Guy
    A lot of the heat my be from the center console where both the supply and return pipes run through the center oval structure support pipe. Kinda like the old style radiators in houses. Also, there is no insulation between the pipe and the center console.
  10. MonsterCro
    MonsterCro Formula Junior
    Mar 4, 2014
    599
    Sydney Australia
    Steve
    I get heaps of heat blowing through the centre console in my 84 QV. Checking everything seems to be ok so still a mystery in my car
  11. online-racer
    online-racer Rookie
    Dec 1, 2008
    16
  12. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    waymar likes this.
  13. craiggo
    Nov 9, 2012
    416
    Redwood City
    Craig
  14. Ferraridoc
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
  15. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,807
    Australia
    Mark R
  16. craiggo
    Nov 9, 2012
    416
    Redwood City
    Craig
    It does! I was sure it was going to fly off the first time I drove it after he spent time making it but it stays snug in there. It kinda gets jammed under the gasket.
    Craig
  17. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,149
    SanFrancisco BayArea
    1983 US 308 GTS QV
    We were also chasing cabin heat a while back. "Jonny Law" had an infrared camera and made some interesting photos regarding heat sources. Here is a link to the thread with the photos:
    https://www.ferrarichat.com/forum/threads/308-footwell-temperature-measurements-where-the-heat-comes-from.438007/
    My car was missing the foam around the radiator and hood and I have been surprised at how much replacing it has helped reduce cabin heat. I need to get out my IR thermometer and compare my measurements from when I didn't have the foam in place.
  18. Banzairacer
    Banzairacer Formula Junior Silver Subscribed
    Aug 24, 2017
    486
    San Diego, CA
    Sanjeev Thohan
  19. Banzairacer
    Aug 24, 2017
    486
    San Diego, CA
    Sanjeev Thohan
  20. Albert-LP
    Albert-LP F1 Veteran Owner Rossa Subscribed
    Sep 1, 2010
    8,175
    around Modena, Italy
    Alberto Mantovani
