Radiator Hose and cooling circuit problems on F12 and 812 | FerrariChat
Discussion in 'F12/812' started by 575joe, Jul 3, 2018.
  1. 575joe
    575joe Formula Junior
    Aug 27, 2006
    324
    The radiator hose on my new (2000 kms) 812 suddenly let go while I was driving on the highway, spilling all the antifreeze in spectacular fashion.
    It turned out to be a problem with the hose clamp that holds the lower radiator hose to the engine, just below the front crankshaft pulley. The fitting there is very smooth, and the hose just slipped off given the pressure of the hot cooling fluid. Note the car was operating well within its temperature limits..
    New clamp installed by the dealer, but after a few days, I can see the hose trying to slip off again.
    Anyone else have a similar issue? Seems like a design problem to me.
    ( I have heard this may have happened on F12s also). Image Unavailable, Please Login Image Unavailable, Please Login
    spyderman likes this.
  2. jumpinjohn
    jumpinjohn F1 Veteran
    7,591
    Texas
  3. spyderman
    spyderman Formula 3
    1,622
    Toronto - Canada
    Spyderman
    I have an 812 as well. I will look to see if the hose clamp is coming loose.
    Thank you for the heads up!
  4. jumpinjohn
    7,591
    Texas
    Let us know what you find!
    Ours is due in the next four weeks or so...
  5. Solid State
    Solid State F1 World Champ
    10,598
    Maximus Decimus Meridius
    Do you think you may just have a short cut hose? The clamp looks good but it doesn't look like the hose originally seats up all the way when attached and then pulls back a little. Some hoses actually use a sealant that stops it from pulling back and leaking but its SUPER tough to replace an old hose after that stuff was used. Maybe have them measure up with a new hose. Maybe also check the seat distance with another 812.
  6. speedbird1000
    speedbird1000 Rookie
    Jun 29, 2008
    41
    Europe
  7. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    945
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    No excuse for a poor design--where is the lip?
  8. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    Same problem on my 812. I will have to get a longer hose on there.
    AEHaas
  9. italiafan
    italiafan F1 World Champ
    16,121
    Stickbones Swagglesmith
    Wish I had a longer hose too! :(
    :p
    SeattleStew likes this.
  10. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    I fixed it. It looks as a short hose but is actually a long custom contoured hose. There is plenty there. I removed the original clamp. Cut it off actually and replaced with a new quality clamp that cannot pinch the hose - important as the hose is thin. It's a 15 minute job, easy access once the lower engine cover is removed. But there is that issue. Wow, what a pain, best done with two people as it is awkward being very long and wide.
    AEHaas
  11. FerrAli
    FerrAli Rookie
    Jan 25, 2020
    23
    Germany
    Thanks for this info, i checked it on my 812, which was delivered in may 2020, even one of the hoses slipped out a few millimeters.
    Gesendet von iPhone mit FerrariChat
  12. ryalex
    Aug 6, 2003
    26,000
    Las Vegas, NV
    Ryan Alexander
    Great to see you around these parts! I saw in your profile, finally sold the Enzo, eh?
