Radiator Overflow- do or do not? | FerrariChat
Discussion in '308/328' started by RAM, May 18, 2008.
  1. RAM
    RAM Karting
    Sep 22, 2007
    66
    Keller, TX
    Rick Morris
    I have been having a small problem with my 308 having the occasional accident on my garage floor after she has been out and gotten warm. Today was the warmest day that she has been out, and after putting her back into the garage I came back to find that she had again piddled on the floor. I have tried explaining that this is not acceptable, but seeing as that has not worked I am considering an alternate approach. It seems that her radiator overflow hose just hangs down to just above the frame, so when she gets a little warm, she overflows wherever she is.
    So, is there any good reason to not add an overflow tank like most vehicles today have? I remember having to add one to my first vehicle many moons back, and it makes complete sense to have it there. Would there have been one there originally? There is not a large amount of space there for a tank, so are there any suggestions on where to place one?
  2. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Do it. I used a 2" dia x 16" billet tube from Summit if I remember correctly. Mine was only 16 ounce capacity and not quite big enough to catch it all. Ideally 30 to 60 ounces should work.
    I mounted it vertically on the aft firewall next to the header tank. Be sure to change to the proper tank cap designed for closed systems.
    Since I went to a closed system I never had the need to bleed air from the cooling system more than once a year, if that.
  3. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,273
    Seattle Area
    Dave
    The tanks back in 'my day' (70s) were for recirculation, with an overflow.
    So all the 'piddle' would be sucked back in when the system got cold again.
    But your car's piddle may be you just have a tad too much water. Once
    she pees (YOU started the analogy!) enough of it out, she should be
    able to hold the rest.
    But do NOT rub her nose in it! Your air dam will thank you
    :D
    Jedi
  4. Beta Scorpion
    Beta Scorpion Formula 3
    Jun 22, 2006
    1,379
    Your car is overflowing because air bubbles trapped in your system are expanding when it gets warm. If there is no air in the system (except the obvious air in the expansion tank), then the factory coolant level (6cm below the filler neck, or what ever your manual says) gives enough room so the thermal expansion of the coolant itself won't overflow. ie no overflow tank needed when working properly.
  5. RAM
    RAM Karting
    Sep 22, 2007
    66
    Keller, TX
    Rick Morris
    What I have done in the past is as zombee is familiar with- an overflow where the system can suck fluid back in when it cools. It was simply a plastic tank- just as that for the windshield washer- with the overflow hose into it right to the bottom. The small amount of overflow that I have seen (today being the worst, maybe 1/4 cup) should be more than handled by this.
    However, I would not be surprised if there is air trapped in the system (the car is great, but I am finding little things that were not done 'by the book' before I purchased). Is there anything special that I should know about bleeding the air from this system? Any suggestions?
    I will also try checking the mix, as it could be too lean.
  6. f355spider
    f355spider F1 World Champ
    18,044
    +1 The proper level is approximately 6cm below the filler neck that the cap seals to. Some cars may spit a bit even at that level, but they will find their equilibrium and stop after a few times. Make note of the level (cold) and that will be the appropriate level for your car.
  7. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Are you saying your 308 does not have an overflow/expansion/recirculation tank in the engine bay??
  8. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    #8 Brian Harper, May 19, 2008
    I added one to my 308GT4 to see how it would be. It sits right in front of the crank pulley mounted on the fender liner. I did have to drill four small holes in the fender liner, but I figured this was the easiest to fill and hide if the tank goes away. It is almost invisible in this position, it was hard to take a picture of it.
    It is a generic overflow tank from the local auto parts store. It works well, I've not gotten any air out of the bleeder vents since installing it. I find that the car will often flow to the bottle after shutdown when the engine is hot and the pump isn't circulating water. As it cools it draws water from the tank and refills the system.
    The car wasn't designed to have it, and it shouldn't need it, but never worrying about burping the radiator before each drive is nice.
  9. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #9 Spasso, May 19, 2008
    This is what I used. It's the polished "tube" next to the overflow tank.
    It collected overflow from the black header tank next to it and then it returned as the car cooled down. The overflow tube would spit on the hot days prompting thoughts a bigger reserve was needed, about 30 ounces.
    If done correctly a closed system should never purge onto the ground, EVER.
    If your 308 has an open system add the surge tank. It keeps the system from pulling air back in after a hot run.
    There is a very good reason why just about every car made after 1970 went to this system.
  10. Beta Scorpion
    Jun 22, 2006
    1,379
    The thermal expansivity of ethylene glycol is .00057/Deg C. The change in volume of 18 liters of a 50% solution of ethylene glycol when going from 20deg C to 100deg C is around 850 ml. If you fluid volume is expanding more than that there is a problem, such as overheating, boiling or most commonly air in the system. EPA mandated systems, such as catalytic converters, air pumps and catch tanks are not required for the proper function of the engine.
  11. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    From what I've heard a common cause of this kind of overflow is a bad radiator cap that can no longer contain they system pressure.
  12. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Rick,
    This may sound like a silly question, but after your car has "piddled", do you top up the reservior tank again? If you do, that could be the cause of the problem. The reservior should only be about 1/2 full. I've seen this happen with other people, and I've had it happen on my old Jaguars. If you over-fill the reservior, it will spit out the excess when it's hot. Once the reservior has found it's own level, it won't overflow, even after a hot run. This presumes that the system was properly filled and properly bled so there is no air in the radiator/lines. I've seen some guys who insist on opening up that reservior after every drive (or before every drive, when the engine is cold), and filling up the tank. Then they wonder why it overflows.
    Just a thought.
    Steve
  13. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Correct.
  14. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Also correct but a closed system with catch tank IS better. The requirement to "bleed" the cooling system was pretty much eliminated when I installed the catch tank.
    With the open system I had NO overheating problems with mine. It would piss after a hot run before finally attaining it's "operating level" in the header tank. I just got tired of the public pointing under my car and telling me something was "leaking". Note, I was only running 25% Ethylene Glycol at the time.
    Ideally there should be NO air in the system anywhere. Air in the system promotes corrosion and with an open system you WILL have air in the header tank to allow for expansion.
  15. RAM
    RAM Karting
    Sep 22, 2007
    66
    Keller, TX
    Rick Morris
    #15 RAM, May 19, 2008
    Okay, to avoid any confusion, I have taken a photo of the engine compartment. Where my problem lies is that the yellow hose in the pic just leads down to the bottom of the car and is open. Here is where our accidents on the garage floor occur from. I would expect that this hose should lead to an overflow container where it can run over when she gets hot, and suck back when she cools. As it stands now, she'll just suck back air (likely increasing the problem).
    Oh, and no, I do not top up after she cools down. I figure if she is already making a mess after a drive, but the temp gauges both show fine, that adding more coolant is not exactly going to solve the problem. But I understand the need to ask. After all, people do things without thinking sometimes. :)
  16. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,251
    Indiana/North Carolina
    JIM
    Start back at the begining....(this thread is slightly hijacked)
    Have you bled your system? Mine required bleeding 2 or 3 times before I got all the air out last year. She has not even dribbled a drop since. Once you have that done, then fill the expansion tank to the level that the manual states. I believe that my GT4 is 6cm below the top of the tank. I have that marked on a 2' long dowel that I keep in the trunk. At any time when the motor is cool, I just drop the dowel in and voila, I know if my level is correct or not.
    IF after bleeding a couple times she still spits up, then its off to step 2 of your troubleshooting.....
    FWIW, YMMV.....but this is what fixed my problem with spitting up last year.
    JIM
  17. RAM
    RAM Karting
    Sep 22, 2007
    66
    Keller, TX
    Rick Morris
    Consensus seems to be that if we get the air out, she should stop peeing on the floor. So what is the preferred method among F-car owners? Remove the radiator cap and fire her up for 10-15 minutes, then top it up? Or, is that a bit old-fashioned and raw for these cars?
  18. jimshadow
    Feb 19, 2006
    6,251
    JIM
    Fill expansion tank to the level recommended by the service manual.....warm her up with the cap on, then bleed from the screw at the thermostat housing AND at the radiator itself. Open slowly until fluid starts to flow, then close. Once you think she is bled, open the cap (on a cool motor), refill and repeat atleast once.
    The 308 motor tends to hold lots of air in the system once introduced, so you really should get used to bleeding it. Its super simple to do!
    ALSO, make sure your cap is good. If it looks old, then go buy a new one. They are cheap and they do fail. I bought a new one for mine right down at NAPA.
    JIM
  19. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    The black tank in your photo is your "overflow" tank (expansion tank). If you need an overflow tank for your overflow tank you have some other problem. The hose to the ground is for when there is a problem causing the cap to open. Excess coolant level, excess pressure, weak cap etc. It routes the water to the ground instead of spraying the engine compartment.
    The top half of your black tank is nothing but an air pocket when the coolant is not hot. It gives space for expansion of the coolant ("overflow") as things heat up. I would not worry about any air getting sucked back in. If this does actually occur it's only getting sucked back into the air space at the top of the tank.
    I've got two mid-engine cars (front mounted radiators) and when I change coolant or open the system to change a hose etc. I always run the engine to full temp. with the coolant tank cap off, then bleed. Increase engine speed a few times to increase water pressure. Then I put the cap on and bleed again. I've never had issues where I've had to bleed many times to remove air. You probably... know but always make sure your heater controls are open all the way (full heat) before starting the procedure.
    I think on more modern cars they use air blending to adjust temperature instead of regulating coolant flow (coolant flow always at max. in the cabin heater core) so turning heat to full is probably not needed.
  20. RAM
    RAM Karting
    Sep 22, 2007
    66
    Keller, TX
    Rick Morris
    Eulk328- so, you favor removing the radiator cap from the overflow tank and bringing the car up to temp to push out any air? When you say to put the cap back on and bleed again, are you referring to putting the cap on and opening the bleed at the radiator?
    I did not measure, but with a quick look the coolant in the tank certainly did not appear to be high, so it always could be the cap. For the small cost I will replace it to be safe.
  21. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #21 eulk328, May 20, 2008
    I do it both ways and of course start with cap off because you don't want to remove the cap when the engine is hot :-( It certainly can't hurt and you will never have an overheating problem with the cap off when you're not driving it (not loading the engine).
    Yes, then I put the cap on and bleed at the radiator AND at the thermostat outlet between the heads. A drive around the block is not a bad idea either just to make sure things get moved around well, but probably not essential. Again, with heater on full heat. Not sure if your car has a bleed point at the thermostat outlet or not. If not, that might explain why it seems more difficult to bleed 308's than 328's (from what I've read). Verrell make a better mousetrap (bleed screw) for the outlet. It allows you to bleed without removing the whole screw and getting sprayed.
    Finally if your cooling system is marginal I would run one third anti-freeze and two-thirds distilled water (instead of 50-50). Water transfers heat better than anti-freeze.
    You can also get a coolant system pressurizer from Mityvac and others. Great way to check for leaks or help expel air with the system cold. Only thing to keep in mind is if you're trying to track down one of those really elusive leaks the cold pressurizing of the system does not fully simulate an engine under normal circumstances (you don't get the expansion and contraction caused by heating and cooling).
  22. UpNorth
    UpNorth Formula 3
    Sep 30, 2006
    1,769
    Quebec, Canada
    Francois
    I definitely do not want to highjack this thread but I discovered I also have a pin hole in my 328 GTS 1986 radiator.
    What is the material for the original radiator? Is it aluminium?
    Just want to know so I can talk on the phone with radiator shop in my area.
    TIA to all.
  23. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #23 eulk328, May 20, 2008
    I would tend to think it's old school copper/brass. I really doubt it's aluminum. Well, one thing I can tell you for sure is that mine says Ferrari on it and also says "Made in Spain." (all embossed in the metal)
    If your radiator is otherwise known good (not clogged, no overheating) I would try some J-B Weld on the pinhole if you can reach it. Possibly a much cheaper/faster fix and definitely better than introducing some leak sealant into the cooling system.
  24. UpNorth
    UpNorth Formula 3
    Sep 30, 2006
    1,769
    Quebec, Canada
    Francois
    Yep, I agree. No liquid chewing gum will into that radiator and that's a fact!
    Thanks.
  25. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    Mine has the "made in spain" stamped on it as well. I would say it's made of brass/copper as its somewhat heavy, certainly not made of aluminum. As far as a pinhole leak, the best thing to do would be to take it to a good radiator shop and they can fix it right up, good as new.
