Radiator Question. | FerrariChat
Radiator Question.
Discussion in '308/328' started by LE06, May 5, 2025.
  1. LE06
    LE06 Karting
    226
    Lee
    I am about to flush my cooling system and run a new heater hose. I plan on taking my radiator to a shop to have it cleaned and checked. I noticed on flea bay I could get an aluminum one for around 350. The other parts suppliers want around 1200. Does anyone have experience with these?
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,804
    Cerritos, CA.
    The problem buying a radiator from flea bay is the fitment I know the one that Nick Forza sells for $1200 is an exact fee without any modification. It’s like plug-in play.
    ZikZak and LE06 like this.
  3. LE06
    LE06 Karting
    226
    Lee
    Is there a big advantage to the aluminum ones? To me it seems like the fan set up sucks on these cars.
  4. miketuason
    Feb 24, 2006
    15,804
    Cerritos, CA.
    Not so much of a advantage but two disadvantages is not original and expensive. One other choice if you can do is have your original Radiator recore and upgrade your fan to the latest more modern SPAL.
    LE06 likes this.
  5. LE06
    LE06 Karting
    226
    Lee
    Ok thinks. Recore and upgrade the fans seems like what I want.
    miketuason likes this.
  6. Imatk
    Imatk Formula Junior
    May 6, 2007
    764
    Good luck finding someone to actually do a recore. I couldn't. I wound up buying an aluminum one from Superformance. Also did the Spal fan upgrade.
    LE06 likes this.
  7. Tiltrider1
    Tiltrider1 Rookie
    Jul 26, 2022
    41
    David Regula
    For a recore you can contact Greenwood Radiators in Seattle Wa. I am sure there are plenty of other shops in the world. These are the only people that I can vouch for. They did all my radiators and tanks when I brought my 308 back to life. I have know Ron for 30 years and I know I can always trust him.
    LE06 likes this.
  8. Aus_yz
    Aus_yz Karting
    Sep 5, 2015
    52
    Australia
    Mika
    Ive been running a Ebay aluminum radiator for 6 plus years , works/fits fine . I still have original radiator to recore one day .
    LE06 likes this.
  9. Dr Tommy Cosgrove
    36,373
    Birmingham, AL
    Tommy
    When I bought my QV in 97 I had the radiator out twice to rod , clean etc. It helped a little I guess. I installed a larger aluminum one years later and that was about 50% better but you still didn't want to get caught in Atlanta downtown traffic on I85 in the summer.
    I installed larger spal fans on those little mounts that look like stock motors and that seems to have finally done the trick. That was a pretty good upgrade because I modified nothing in the car. total swap only.
    Imatk and LE06 like this.
  10. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    736
    Omaha, NE area, US
    Steve
    I bought the alloy one from Superformance, and it fit, sort of. The top mounting brackets were off by about 10mm per side, the bottom condenser brackets were moved inboard about 30mm per side compared to my original, and the drain tap thread was wrong. All things I could deal with, and better than paying return freight, but very annoying given the price.
    Andreas Engesvik and LE06 like this.
  11. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    #11 ferrariowner, May 6, 2025
    Nick's radiator is produced by Wizard Cooling. It works great with 2- 10in electric fans (12in will fit as well). Add shrouds for better performance. Also a good time to upgrade the AC condenser. Don't forget to replace the foam around the radiator and the hood. Install your battery cover.
  12. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,102
    Atlanta
    Tom Spiro
    My 328 never had any cooling issues in summer Atlanta weather. however my 308 was horrible always close to overheating. I think the 328 standard radiator is very good, as long as its all working right. I'd go with Nick's as a very good upgrade, that protects the engine. Flushing it every year helps as well.
    LE06 likes this.
  13. LE06
    LE06 Karting
    226
    Lee
    My 308 does not like sitting still. If the rest of the system looks like what I saw in the heater hose I am changing then it is full of crud.
    I think there is a shop here in town that will still do a recore. If the fans had shrouds that would help. I saw a radiator that came with fans but that may have been on flea bay. Are you guys getting fans local or from one of the Ferrari parts suppliers?
  14. Imatk
    May 6, 2007
    764
    If I were you, I'd take a look at every coolant hose you have. If they haven't been changed, change them.
    It took me two flushes AFTER I replaced all the coolant hoses to get the crap out of the system.
    Remember to drain the block as well to get all the coolant (or most of it) out.
    My car simply doesn't overheat now. I had to sit in 100 degree Texas weather behind an accident for about an hour and it never even got close to overheating.
    LE06 likes this.
  15. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Try the Spall 10 or 12in fans. Image Unavailable, Please Login
    LE06 and Imatk like this.
  16. Imatk
    May 6, 2007
    764
    Yeah I priced out doing it separately, buying the adapters and then fan. It worked out to within 20 bucks or so, so I just bought the whole thing from the guy. I don't mind throwing him a little profit.
  17. chris_columbia
    chris_columbia Formula Junior
    858
    Columbia MD
    Chris
    I got tired of starring at the temp gauge wondering if it would creep too much beyond 1/2 way. I used the "big hammer" and did everything at once. Cored radiator (at local shop in Baltimore), new fan thermostat(lower temp), new water pump t-stat(lower temp), new seal at radiator bleed valve, removed a/c condenser, added overflow tank(so that factory tank can be kept full). No issues at all now. In fact the fans don't run at all unless it's a very hot day. Temp stays at 1/2 way mark. I really like the overflow tank; much easier to see what system is doing. Radiator shop said the old core looked fine. I think core was $400 5 yrs ago?
    LE06 likes this.
  18. LE06
    LE06 Karting
    226
    Lee
    The car had the water pump changed about 3 years ago, very few miles on it. I have a new thermostat to go on it also. Also I am changing the temp switch on the radiator, it does not work.
  19. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Nick sells a much better version of the water pump if anyone needs to replace their pump. It is much improved design with better water moving capacity and a larger bearing.
  20. Dr Tommy Cosgrove
    36,373
    Birmingham, AL
    Tommy
    Does that part even matter?
  21. lopena
    lopena Formula Junior
    759
    Leo6:
    If you’re on the east coast I would suggest you send your radiator to FINGERS RADIATOR SHOP for recore. They’ve been around for almost 100 years and do lots of exotics, hotrods, and classics. Here’s their contact information:
    Fingers Radiator Shop
    2006 Route U.S. 1
    North Brunswick Township, N.J. 08902
    (732) 297-3563
    good luck,
    Alan
    N.J.
    LE06 likes this.
  22. 26street
    26street Formula Junior
    Jan 30, 2021
    465
    Westchester New York
    Mark k
    Where are you located --- i have a place in Westchester ny alot of guys in my area uses
    LE06 likes this.
  23. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I certainly has a much better vain design and larger bearing than the original, it also spins slower than stock. Is it needed? I don't know. However, I don't need to replace the pump every 5-7 years now as I did prior. It does cost more.
