Radiator tank mounting crossbar | FerrariChat
Discussion in '206/246' started by racerboy9, Apr 21, 2017.
  1. racerboy9
    racerboy9 F1 Rookie
    2,645
    Looking for the crossbar the radiator tank mounts to. The one I have has the number from a rare Dino that is being restored and should be re-united with it but that leaves me needing one.
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    superformance do good reproduction ones
  3. Ken Ivey
    Ken Ivey Formula Junior
    255
    Portland, OR, USA
    Ken Ivey
    I have a related question. On my car the expansion tank has a small braided hose going forward from the end of the tank. I can't get it loose to repair the tank without destroying it, (or shortening it too much). Does someone have a direct replacement or what is the size of the hose?
  4. swift53
    swift53 F1 Veteran
    8,285
    E.S.
    Alberto
    I am certain we can make one...
    Please write: alberto.guirola at gmail.com
    Regards, Alberto
  5. swift53
    swift53 F1 Veteran
    8,285
    E.S.
    Alberto
    Tony, cannot find it.
    Regards, Alberto
  6. racerboy9
    racerboy9 F1 Rookie
    2,645
    The fellow with the rare Dino has offered to make me a new one but I thought someone might have a spare they could let go.
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    It should be reinforced rubber (same as the heater) hose and is used to provide vacuum relief. Not sure on the size. Try to slide a small screwdriver under the hose, they get very hot and trend to weld themselves to the metal............
  8. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
  9. swift53
    swift53 F1 Veteran
    8,285
    E.S.
    Alberto
    #9 swift53, Apr 22, 2017
    Wrong part Tony, it is the long 30mm pipe, threaded at the ends and with the expansion tank mounted to it.
    We already made one I was missing.
    Regards, Alberto
  10. swift53
    swift53 F1 Veteran
    8,285
    E.S.
    Alberto
    Spares ought to be rare, and I don't have a spare, but can zip one up for you.
    I have the original to copy from, and I am certain, will be less expensive. Are you in extreme urgency?
    Regards, Alberto
  11. racerboy9
    racerboy9 F1 Rookie
    2,645
    Alberto, Thanks for the offer but part of the deal is making me the bar. I thought if I could find an original would be best for me if possible. It is a fairly simple part to make.
  12. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Sorry Alberto I didn't read the original post correctly, I now know the part you are referring to. Simple to remake I would have thought.
    Tony
  13. swift53
    swift53 F1 Veteran
    8,285
    E.S.
    Alberto
    You are welcome, it is easy to make, but finicky to make look proper.
    Regards, Alberto
  14. Ken Ivey
    255
    Portland, OR, USA
    Ken Ivey
    Tony,
    Thanks for the input. I tried to loosen it with a screwdriver, just couldn't get under it enough. I guess I'll just use plain cooling system hose until I can find appropriate, cloth braided hose.
    Thanks again...
  15. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    It happens Ken, if there is no slack in the hose then its best to renew, if you do get the old hose off then it may not reseal when you refit it.
    If you have some slack then just put a small slit in the hose with a utility knife and cut back the hose by an inch.
    tony
