Radiator | FerrariChat
Radiator
Discussion in '308/328' started by kman369, Dec 10, 2014.
  1. kman369
    kman369 Karting
    Nov 21, 2014
    99
    Winnipeg, MB
    Barry
    Anybody ever have a little anti freeze along the top lip of the rad (the side facing the spare tire) there are no leaks or puddles under the car. Just a little wet. Do these rads sweat or seep at all? Thanks
  2. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I had that just before I pulled it and had it cleaned and re-soldered. It's leaking and no they should not weep.
  3. Sigmacars
    Sigmacars Formula 3
    1,218
    I had that on mine to ,bring the rad up to temp.and you will see a small pin hole with steam comming out mark it let it cool and solder it in the car very small job did mine 2years ago and no problem.make sure the water level is below you soldering point.
  4. kman369
    kman369 Karting
    Nov 21, 2014
    99
    Winnipeg, MB
    Barry
    Great thanks for the reply. Is there any special solder I should be using? I appreciate the advice and help. I'd rather not have to pull the rad out if I don't need to.
  5. Dr Tommy Cosgrove
    May 4, 2001
    36,431
    Birmingham, AL
    Tommy
    Yep
    That happened to me about a year after I bought my 84. I had it pulled and rodded (i think twice) and "fixed". Few months later I started getting a green spray on my windshield through the hood vents. I had it removed and fixed a third time along that top edge.
    That was 1998. Never leaked again.
  6. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    If I don't sufficiently tighten my radiator bleed screw then there is a little seepage that accumulates along the top seam of the radiator.
  7. jon s
    jon s Formula Junior
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    rosin core solder should work but if the leak is through steel i usually use acid core solder - hardware store or plumbing supply. easy fix in the car if it's just a pinhole. jon s
