RADIO 355 | FerrariChat
RADIO 355
Discussion in '348/355' started by 285ferrari, Oct 18, 2006.
  1. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    Do I have to manually turn the radio on and off each time I get into the car??
  2. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Depends who? and how they? wired it up.
  3. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Mine is aftermarket (with bluetooth :) ) so it will not apply, but I have to manually turn mine off or it will stay on all night!
  4. 285ferrari
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    Stock Sony cassette player w, cd changer that came from the factory..
  5. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Almost every aftermarket / brand name stereo has a remote turn on lead (often blue in color) that should be wired to an ACC circuit wire in the car to turn the unit on only when the car is on. See if you can find the wire diagram for the unit you have on the net to see which color is the right one for your stereo, then just connect it to the acc lead in the stereo wiring bundle. Or you can buy the aftermarket adapter for the 355 and reqire the whole unit (this would be my choice).
    BT
  6. 285ferrari
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    Screw all that---time for a new Alpine 5" touchscreen w/ nav...Thanks PAP you just gave me an excuse to put a Alpine in the car...
  7. PAP 348
    Dec 10, 2005
    100,220
    Pap
    ;) Thats the go.......go bling or go home :p
  8. pino
    pino Karting
    Nov 1, 2003
    208
    South Central PA
    If its the awesome factory Sony unit, then yes you do.
    But more importantly, how in the hell do you even hear the radio?
  9. 285ferrari
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    stock exhaust
  10. bst1
    bst1 Formula 3
    Aug 13, 2005
    1,055
    MARYLAND
    BARRY T
    But not for long!!!!!!!!!!!!
  11. 285ferrari
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    u r correct---as soon as my buddy gets his lift cleared---we will attempt install of X-OST----FOW wanted $500 to install it, I told them I will do it myself...Can't be that hard--Remove bumper, etc....
  12. Dean355
    Dean355 Formula 3
    Sep 4, 2006
    1,101
    South Florida
    Dean
    285 your car is gorgeous!!!
  13. PAP 348
    Dec 10, 2005
    100,220
    Pap
    #13 PAP 348, Oct 19, 2006
    No stress, I'll be getting one too from Daniel soon, when I do i'll start a thread for the install of it from start to finish and also upload dyno performance links and pictures before and after install just for us ;) :p
  14. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Your not wrong there Dean ;)
  15. eric355
    eric355 Formula 3
    1,227
    Toulouse (France)
    Eric DECOUX
    Had the old Sony in mine too and i was obliged to switch it off every time. I do not like that ... a good way to forget it and drain the battery.
    I have upgraded to a new Pioneer (CD, MP3, ...) ... euh ... I do not listen very often, I do prefer the V8 symphony, but for long trip it can help! Not the question anyway.
    There is no "accessory" wire, in the original wiring, which can allow you to switch off automatically the radio when you remove the key. There is no wire because there is no "accessory" position. In fact there is a virtual one, which is used to power on the ABS as soon as possible. It is very easy to connect an extra wire at the master switch level and to route it to the radio. Have done it and it works great, am sure now that the radio is off (but the memory circuit) when i leave the car ... with keys in my pocket. Could show the wire to use on a diagram if you want.
  16. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Yeah that would be nice Eric ;)
  17. eric355
    eric355 Formula 3
    1,227
    Toulouse (France)
    Eric DECOUX
    #17 eric355, Oct 19, 2006
    Here it is!
    I use the ligh blue wire, made soldering on it without cutting it. Done in less than 1 hour, but need to remove the top and bottom plastic covers around the switch for a better access.
  18. PAP 348
    Dec 10, 2005
    100,220
    Pap
    The light blue wire on the stereo Eric :confused:
  19. eric355
    eric355 Formula 3
    1,227
    Toulouse (France)
    Eric DECOUX
    Yes the light blue wire.
    Splice a piece of wire on it and use this new wire as an "accessory" wire. You can see on the diagram that battery voltage is present on this wire when the key is position I (virtual), position II and Start, but not when the key is removed. It works!
  20. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Yeah thats what I thought, On you schematic I traced it back to a green wire that all, What brand head unit do you have? A Sony unit? I thought the light blue wire was for the remote on for the amp? Either way like you said you need to switch it off a accessories curcuit for it to turn on and turn off when you stop the engine and remove the key. On my 348TB my brother done the same as yourself and rewired it though a accessory circuit, don't remember which one off hand but mine was wired up wierd from the start, when ever you turned on the lights the power to the stereo would switch off, we bypassed that crap straight away when I bought it :D :D
  21. eric355
    eric355 Formula 3
    1,227
    Toulouse (France)
    Eric DECOUX
    I have now a Pioneer unit (will post a picture). When I talk about the light blue wire, I mean the CAR blue wire (A color for ... Azzuro).
  22. eric355
    eric355 Formula 3
    1,227
    Toulouse (France)
    Eric DECOUX
    No sorry my mistake, i misinterpreted the A close to the connector. The wire on the car is not A color but GN color which is not green but Giallo-Nero (yellow - black). The "ACC" wire on my head unit is yellow.
  23. eric355
    eric355 Formula 3
    1,227
    Toulouse (France)
    Eric DECOUX
    ... and the blue (or blue-white) from the head unit is effectively used to remote switch on the power amplifier and to switch on the antenna amplifier.
  24. PAP 348
    Dec 10, 2005
    100,220
    Pap
    #24 PAP 348, Oct 19, 2006
    Yeah no worries Eric ;) I thought something didn't add up.
