Radio conections in 355 | FerrariChat
Discussion in 'Technical Q&A' started by wlracing, Feb 9, 2005.
  1. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    I wish to replace the standard Ferrari ( Sony ) radio in my 355 with a Pioneer unit ( keh-p7020r ) but have difficulty converting the conections does anyone know how ?
  2. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    #2 Ferrari_tech, Feb 9, 2005
    Hope this helps, this is the factory wiring for the Sony set, so the wiring instructions for the Pioneer should be compatible.
    59014 = Radio / reciever
    59016 = Pre-amp
    Legend of connections from 59014 as shown in diagram..................
    1 = violet = L/H tweeter
    2 = green = R/H tweeter
    3 = grey/red = Front shunt ECU
    4 = violet/black = R/H tweeter
    5 = grey = L/H tweeter
    6 = black = Earth
    7 = red = Pre-amp
  3. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Thanks Malcom but I am more confused now I thought that all I needed was A switched live , A permanent live , An earth & two speaker leads .What is a front shunt ECU & do I have to use a Pre-amp ?
  4. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    947
    Europa
    Bob
    you need connect the pre-amp connector to a switched 12volts comming from the radio. It is the connection for the antenna amplifier. Without connection of this the antenna (which is in the windowscreen) is not work. Don't connect just stright onto the bettery, because is draining the battery when you no use the car for long time.
    The grey and red wire is 12volts swithced on byt he ignition key, but better to check double with a volts meter.
    Anyway, why you want a radio ? The engine is all the music any body needs to have, no ?
