Radio dead in 550 | FerrariChat
Radio dead in 550
Discussion in '456/550/575' started by Zanzibar, Jun 2, 2013.
  1. Zanzibar
    Zanzibar Karting
    Jul 17, 2004
    119
    The radio in my 550 went dead. It does not seem to get any power. The unit is the standard issue "Ferrari" model (actually Sony, I suspect), with an internal cassette player and a CD changer in the trunk. I could not find a separate fuse for the radio, but I found here in FerrariChat that it shares a fuse with the A/C compressor. The A/C compressor works fine, so it cannot be the fuse. Is there another (perhaps inline) fuse? If not, I suppose I will have to pull the radio unit and send it in for repair.
    Thanks for the feedback!
  2. maranello72
    maranello72 Formula Junior
    Jul 4, 2009
    354
    Munich, Germany
    Stefano
    I had the same radio as yours, and when I replaced it I found an in-line fuse on the adapter cable between the radio and the car's wiring loom.
    Slide the radio out using the extraction tools provided and check if you also have a fuse in there.
    Stefano
  3. Zanzibar
    Zanzibar Karting
    Jul 17, 2004
    119
    Thanks, Stefano. I will try to find the inline fuse you mention.
  4. BobH
    BobH F1 Rookie
    3,164
    Morristown, NJ
    Robert H
    I defer to those who really know this vehicle but I seem to remember one member trying to remove the radio with the proper disconnect tools and it still wouldn't budge. apparently there was a nut on the back of the receiver securing it to a bracket for further grounding or stabilization purposes. If for some reason the radio doesn't slide out using the procedure noted in the prior reply, do a search on dashboard or radio removal and you should find an image of the receiver with some small bracket attached to the back. I believe the post I remember was in response to the dashboard removal instructions.
  5. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    I know this to be the case with the carbon console. You must lift the whole console out with radio attached.
