Radio Interference | FerrariChat
Radio Interference
Discussion in 'Technical Q&A' started by Skindiver, Jun 14, 2004.
  1. Skindiver
    Skindiver Karting
    Apr 22, 2004
    203
    JHB SA.
    Greg
    I have some sort of interference on my '89 "ABS" 328's Radio. After 10 - 15 km on each drive i start to get a blipping interference over the radio that often starts after a hard turn. It seems to be related to the turning wheels ? and only occurs when i'm moving even with the clutch in.
    At low speed it cuts out the radio in staccato type blips, this increasing or decreasing with speed to a rising and falling whine over the speakers.
    If i stop the car carefully i can actually stop on a "blip' which then totally blanks the radio out untill i roll forward a smidge again. Revving the engine does not affect it.
    Any ideas to fix it ?
    Skin.
  2. Tod328gts
    Tod328gts Formula Junior
    Jul 23, 2003
    626
    River Forest, IL
    Tod Whitmore
    I would first guess a loose ground wire somewhere. But you could have a faulty radio too???? The radio may have a bad component, such as a filter CAP in the power supply section. Could be a number of things, first i would check all the ground wires for the radio. If those look ok, try adding a filter on the power going to the radio, you can get those at a radio shack. There could also be something in the ignition system causing this problem too???
    My 2 cents...
    Tod
  3. f355spider
    f355spider F1 World Champ
    18,055
    I would agree with Tod. It sounds like an intermittent connection somewhere, and grounds on these older cars can get questionable. Also, check the ground on the antenna. I had an annoying problem with engine alternator whine coming through my AM radio. The fix was to actually replace the semi-automatic antenna. Even though the ground was good, tight and clean. Not sure what was bad in my antenna, but a new one fixed the problem.
