Radio question | FerrariChat
Radio question
Discussion in 'Technical Q&A' started by wfo900, May 30, 2007.
  1. wfo900
    wfo900 Formula Junior
    Aug 19, 2003
    530
    Annapolis
    Rich C
    My 355 has one of those Sony detachable faceplate radios. As it gets older there seems to be a problem - whenever I go over bumps the radio shuts off and then restarts. My guess is that the electrical connection at the back of the faceplate is losing connection. Any suggestions on repair?
  2. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,053
    Could also be the connections to the back of the radio...in fact that may be more likely. Try removing the faceplate, and cleaning the connectors on the face plate and radio with some electrical contact cleaner on small swabs. If that doesn't help, hunker down and check the connections on the back of the radio...or pull it out.
  3. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    I agree with Dave, but it sounds like it a likely source could be the ground. You may want to try to prove this by clipping a supplemental ground wire to the back of the unit with alligator clips.
    You could maybe push on the faceplate to help isolate a faceplate problem.
    Mark
  4. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Grounds are so often overlooked in favor of the 'hot' side of components, and Ferrari manuals always recommend good ground maintenance. I'm not saying this is the case here necessarily--Just don't leave them out in troubleshooting.
    Good Post!
  5. MJT328GTS
    MJT328GTS Formula Junior
    Mar 30, 2005
    374
    St. Louis
    MJT
    For the flat contacts at the face plate and the bent contact, try contact cleaner. Don't just spray it on but wipe the contacts, both of them.
    Even though they are gold plated, it's usually only about 30 microns thick and they can still get dirty and develop a film over time.
    If you don't have contact cleaner, a simple trick is cleaning the flat contacts with a pencil eraser.
