Radio Trouble | FerrariChat
Radio Trouble
Discussion in '456/550/575' started by markbnj, Sep 25, 2007.
  1. markbnj
    markbnj Karting
    Feb 25, 2007
    62
    Central New Jersey
    All of a sudden the radio in my 550 stopped working. The radio unit powers up and operates normally, but no sound comes out of the speakers. I swapped out radio with a new one, but still no sound. I don't see a separate AMP that drives the speakers so I'm mystified. Any suggestions?
  2. SonomaRik
    SonomaRik F1 Veteran
    getting no static, nada?
    Can you pop one of the speakers to run an ohm meter across it?
    Seems the wires from the radio to the speaker system either blew a fuse [not sure they have one] or got cut...try to put a speaker on the rear of radio...that is, tap into output and see if you get sound...
    two radios having same problem makes one hope for the lottery.
  3. psmaia
    psmaia Karting
    Oct 26, 2005
    219
    greenwich, conn.
    Paul Marchese
    you listen to the radio?..in a v12 ferrari?..
